robertoj Posted November 4, 2024 Author Posted November 4, 2024 If anyone needs h264 acceleration in opiz3, it is possible quickly with a version of Armbian from mid 2024, as shown in this thread: https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/?do=findComment&comment=205516 (in opi zero, h264 is already possible with official debian debs) There are a few suggestions to make it work in the latest Armbian... I am bumping this thread because I have limited time with my opiz3, but you may be able to do it (and share). More references of success: https://forum.armbian.com/topic/31848-cant-use-ffmpeg-hardware-accelration-v4l2-orange-pi-4-lts/?do=findComment&comment=175688 ^ Actually, if you see that link, you will see a way to compile your own Armbian image, with some linux patches that allow ffmpeg-v4l2request do its work. 0 Quote
robertoj Posted November 11, 2024 Author Posted November 11, 2024 Success story for h264 hardware acceleration, thanks to Jock, NickA and Armbian https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/?do=findComment&comment=205855 0 Quote
RimYT Posted February 4, 2025 Posted February 4, 2025 i tried your dts for opiz2w, and thank you, its helped me! but i have two problems: first - screen size is not 320x240 for my system (somewhere the line is being moved, although there is still space further on the screen, and the beginning of the line vertically is not at the very top of the screen, but in the middle), and second - bgr... i tried bgr = <0> and bgr = <1> and rgb = <0> etc... do you know, how to fix at least one of it? 0 Quote
RimYT Posted February 4, 2025 Posted February 4, 2025 oke, i found out, that system defines display in 240x320 mode, but i need 320x240, idk i tried to change height and weight values in dts 0 Quote
robertoj Posted February 4, 2025 Author Posted February 4, 2025 I can't understand your situation can yoiu send a photo of the LCD, the kernel version, and do some of the tests that I wrote in this thread? Start with the DTS here: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-205335 The bgr and rgb parameters are among the last things to fix (applies to only some LCD drivers)... do you even get a picture in the LCD with wrong colors? 0 Quote
robertoj Posted May 13, 2025 Author Posted May 13, 2025 Is anyone using the orange pi zero LTS or 3, with any ilitek LCD, with spi-gpio driver? I had my LTS working with ili9341 and spi-gpio last year... but the touch is not working now... I think I changed the wiring or the DTS in the running system but I can't tell. 0 Quote
robertoj Posted June 14, 2025 Author Posted June 14, 2025 (edited) I was having some trouble with newer ili9488 LCD v2.1, and I didn't have ili9488 LCD v1.1, so I decided to experiment again with ili9341 LCD v1.2. I found that this DTS https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204672 Doesn't work with the touch chip. By accident, I ran the ili9488 driver on this ili9341, and I saw garbled graphics... but the good news: touch was working. Something in the ili9488 DTS which doesn't work for the ili9488 LCD, works for ili9341. I found the difference was not in the ads7846 section, but in the spi speed for the ili9xxx part. I switched back to the ili9341 DTS (with adafruit driver), but changed the SPI speed from 24MHZ to 40MHz.... then the ili9341 DTS was working with graphics and touch again ALTHOUGH the graphics have some flashing pseudo-colors in some places. Maybe the 40MHZ is too much, but I re-gained touch in ili9341 LCD v1.1. I will keep doing experiments. Playing with the SPI Mhz didn't help with the ili9488 Edited June 15, 2025 by robertoj 0 Quote
Minh Tiến Nguyễn Posted June 16, 2025 Posted June 16, 2025 Hello @robertoj I think i have the same problem with @RimYT above about wrong color with ili9486, i'm using screen MPI3501 which is clone screen of waveshare tft35 I apply the same device tree and guide in https://github.com/dev-null2019/orangepizero2w35tft. The screen work but i wrong color, it seem revered Red. —> blue Green —> red Blue. —> green I also write detail in here I know my problem not totally related to your topic, but can you suggest me what i should to check more 0 Quote
Minh Tiến Nguyễn Posted June 16, 2025 Posted June 16, 2025 About wrong color i think the driver cause it. Driver for render image in this kernel sunxi is ili9486drmtft. I get right color in raspberry pi 4 but raspberry pi 4 use fb_ili9486. On this orangepi zero 2 w, i try 3 different OS but still get same wrong color after adding dts for ili9486 1. Orangepi OS Kernel 6.1 2. Armbian OS Kernel 6.1 3. Debian Bookworm 12 Kernel 6.1 All using ili9486drmtft and get wrong color I also try to change bgr value in dts, but it only create change in .../spi@1.0.../bgr not the color on screen I try to get source code https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-6.1-sun50iw9 to change the bgr field in driver, but i can't insmod the module i build. It say invalid symbol I see someone comment that after kenel 5.4 in repo sunxi remove fbtft_device, so we can't add the fb_ili9486 . The Offical OS supported by Orangepi has Kernel 5.4 Debian, i use it, but after add overlays and reboot, it seem wrong setup, ethernet not working, and i don't know why. 0 Quote
Jeffrey Posted December 6, 2025 Posted December 6, 2025 Does this still work with current armbian version? I am using v25.11.2 for Orange Pi Zero3 running Armbian Linux 6.12.58-current-sunxi64 and I can't even get the display to turn on. Now I'll admit I am a complete noob when it comes to linux so I am most likely doing something wrong. I know am doing something that's way over my head but I enjoy researching and learning things but it's hard to find things on the subject. I am using the DTS from this comment: - copied it into ~ili9341 then did: - cd ili9341 armbian-add-overlay ili9341-spi1-opiz3.dts I rebooted and notice the screen didn't come on, so I did: dmesg and then following message came up: sun6i-spi 5011000.spi: cannot register SPI host It's a cheap ili9341 tft from aliexpress, it says it's using ST7789V for display drivers, is that maybe why it isn't working? driver ili9341.ko does show up in /lib/modules/6.12.58-current-sunxi64/kernel/drivers/gpu/drm/tiny any help would be appreciated. 0 Quote
Jeffrey Posted December 7, 2025 Posted December 7, 2025 (edited) Well I got it to display something, it isn't exactly what I want but I am just happy I got it to do something. I decided to try with the orangepi image from their website "Orangepizero3_1.0.2_ubuntu_jammy_desktop_xfce_linux6.1.31.img". I was going to share image from what it's displaying but for some reason I keep getting an error trying to upload. Basically it's showing the orangepi boot logo but then all messed up, it's all over the place. ------ edit got image to upload. ------ Edited December 7, 2025 by Jeffrey 0 Quote
robertoj Posted December 8, 2025 Author Posted December 8, 2025 That photo tells me that you have the SPI and GPIO configuration right. Keep that. The completed solution for orange pi zero 3 and ili9341 is: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#comment-204672 Copy the parts within the ili9341:ili9341@0 {} section, while keeping your gpio 0 Quote
Jeffrey Posted December 9, 2025 Posted December 9, 2025 @robertoj Thank you for being willing to help. It was actually because my jumper wires were too long. I now can see the everything fine on the screen. The only issue that remains is loading the desktop environment, I can't seem to get in nomatter what I try. I've tried multiple image but every single time it just fails. Any ideas?or is there an image available that is known to work that I can download? 0 Quote
robertoj Posted December 9, 2025 Author Posted December 9, 2025 Jeffrey, Is your DTS using this in the "compatible" line: adafruit,yx240qv29 ? Are you trying to use an X11 or Wayland greeter and desktop? (I can't remember what commands to use to check that right now). I didn't know about X11 problems with adafruit,yx240qv29 (only with the other driver panel-mipi-dbi) There's no available image to download with all the required parts. 0 Quote
Jeffrey Posted December 9, 2025 Posted December 9, 2025 At this point I've tried with and without adafruit,yx240qv29. I also have tried with X11 and Wayland. I am at the point where I am using Gemini to figure out what is wrong but not making much progress. I have found people with similar issues but no solutions. 0 Quote
robertoj Posted December 10, 2025 Author Posted December 10, 2025 If you have X11 installed, then boot with only the LCD and try: sudo systemctl stop lightdm (the greeter, which requires X11) sudo startx Show me what errors you see If you have Trixie, boot with only the LCD and: sudo apt install labwc labwc (as a regular user) Large language models are just google on steroids. They can only give good answers, if hundreds of people have typed and published solution similar to your problem. 0 Quote
Jeffrey Posted December 10, 2025 Posted December 10, 2025 So I have tried all the different images for the Opiz3 from the Orange pi website with the dts, I have tried 2 of the desktop images for the opiz3 from armbian. All of them result in the desktop environment not booting correctly. with Armbian I even got to the point where there are no errors in the lightdm logs, yet still a black screen. However with all those different images, a simple manual restart of lightdm (systemctl restart lightdm.service, will fix it and make the desktop show up. 0 Quote
robertoj Posted December 10, 2025 Author Posted December 10, 2025 That's good news You are using lightdm with the default greeter GUI, right? That means that your LCD driver can support X11. Are you still using adafruit,yx240qv29? Maybe the lightdm service is getting confused about which display to use. What do you get with: $ ls /dev/fb* ? Make sure that you don't connect an HDMI LCD at the same time. Which desktop(s) do you use? XFCE and Gnome? 0 Quote
Jeffrey Posted December 11, 2025 Posted December 11, 2025 (edited) Yeah I am glad that atleast I can get into desktop environment by manually doing a lightdm restart. ls /dev/fb* returns: /dev/fb0 I feel like I've tried everything possible and ended up just making a custom script that restarts lightdm a few seconds after booting, it's not ideal and it bothers me that it isn't working properly but yeah. - I am using adafruit,yx240qv29 - Yes I am using XFCE currently but I've tried Gnome too. - the Slick greeter - Orangepizero3_1.0.2_ubuntu_jammy_server_linux6.1.31 / but have tried MANY others. Also what might be useful for others, just the DTS wasn't enough for things to work, also had to create a config in /etc/X11/xorg.conf.d/ and add these lines: Section "Device" Identifier "ILI9341-Device" Driver "fbdev" Option "fbdev" "/dev/fb0" EndSection However things aren't super stable yet, the screen sometimes will randomly stop working, first I though maybe there is a screensaver or something but that doesn't seem to be the issue. Leaves me to think it's maybe power related and need to use shorter cables and a better 3.3v power supply (currently using the 3.3v from the opiz3). Lastly maybe shortening my jumper wires might make a difference. Previously the screen was all the way glitched as seen in my earlier post, I had shortened the dc, miso, mosi and SCLK jumpers but maybe I should make them even shorter. What makes me think it might be power related is also because sometimes the screen seems to go slightly dimm and then brighten back up, it's subtle but visible. Lastly I might have the depth or spi frequency not dialed in yet. Edited December 11, 2025 by Jeffrey 0 Quote
robertoj Posted December 12, 2025 Author Posted December 12, 2025 Check out the learning experience in this thread: https://forum.armbian.com/topic/27457-connecting-banana-pi-m2-zero-with-ili9341-display-over-spi-on-latest-armbian-image/#comment-162359 In an ssh session, do this: $ tail -f /var/log/Xorg.0.log And see what happens when the X11 server crashes 0 Quote
Jeffrey Posted December 15, 2025 Posted December 15, 2025 (edited) Sorry for taking so long to try this, I decided to solder thicker and shorter wires onto the board to make sure that isn't the issue. Unfortunately it still crashes after a short while but nothing is seen in ssh session: ~# tail -f /var/log/Xorg.0.log [ 34.652] (II) event1 - sunxi-ir: device is a keyboard [ 34.722] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 34.722] (II) Using input driver 'libinput' for 'sunxi-ir' [ 34.722] (**) sunxi-ir: always reports core events [ 34.722] (**) Option "Device" "/dev/input/event1" [ 34.722] (II) libinput: sunxi-ir: is a virtual subdevice [ 34.722] (**) Option "config_info" "udev:/sys/devices/platform/soc/7040000.ir/rc/rc0/input1/event1" [ 34.722] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 😎 [ 34.722] (**) Option "xkb_model" "pc105" [ 34.722] (**) Option "xkb_layout" "us" I am going to mess with the SPI frequency and see if that makes any difference. ----- edit ----- I actually found out that the desktop only freezes whenever I stop using the mouse for 5 seconds. Edited December 15, 2025 by Jeffrey 0 Quote
robertoj Posted December 15, 2025 Author Posted December 15, 2025 (edited) Now that you can replicate the crash anytime. Right after it crashes: $ dmesg $ journalctl -u lighdtm Also, try another application that will use the LCD continuously, without starting X11: $ mplayer -vo fbdev2:/dev/fb0 videofile.mp4 (use a 320x240 approx video, so it will be smooth without hardware acceleration) If it works, then maybe X11 is the problem, not the LCD driver. I wish more people switched to 100% Wayland in their HDMI monitors and LCDs. I have a method. If you want it too: https://forum.armbian.com/topic/55882-critique-or-improve-my-method-to-get-a-lightweight-labwc-desktop/#comment-227469 Edited December 15, 2025 by robertoj 0 Quote
Jeffrey Posted December 15, 2025 Posted December 15, 2025 4 hours ago, robertoj said: I wish more people switched to 100% Wayland in their HDMI monitors and LCDs. I have a method. If you want it too: https://forum.armbian.com/topic/55882-critique-or-improve-my-method-to-get-a-lightweight-labwc-desktop/#comment-227469 I will definitely look into that. "mplayer -vo fbdev2:/dev/fb0 videofile.mp4" with desktop disabled worked perfectly by the way, no issues. I've used both X11 and wayland though and also there is nothing in the logs which I find extremely weird. However I will look into it further the upcoming week, I am most definitely missing something. 0 Quote
robertoj Posted December 16, 2025 Author Posted December 16, 2025 Try the X11 windowing manager or the Wayland compositor without lightdm (or another display manager). 0 Quote
autumn Posted January 12 Posted January 12 On 12/9/2025 at 1:40 AM, robertoj said: hello! i'm still relatively new to this kind of stuff. i got the ili9341 working using the dts i found in this thread. my next thought is it possible to have it display an image? thanks! 0 Quote
robertoj Posted January 12 Author Posted January 12 If you don't have X11 or Wayland, try using the linux command "fbi" (frame buffer image). I think I put an example in this trhead or in the Banana Pi ili9341 thread (in this allwinner forum section). 0 Quote
Orima Posted Wednesday at 12:14 PM Posted Wednesday at 12:14 PM @robertoj Could you post a step-by-step guide on setting up the Chinese ili9488 screen on a red board and OrangePi Zero 3? I think this forum will receive many thanks for your work. 0 Quote
robertoj Posted Wednesday at 06:39 PM Author Posted Wednesday at 06:39 PM Yes. Probably this week. 0 Quote
