Go to solution Solved by robertoj,
If anyone needs h264 acceleration in opiz3, it is possible quickly with a version of Armbian from mid 2024, as shown in this thread:
https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/?do=findComment&comment=205516
(in opi zero, h264 is already possible with official debian debs)
There are a few suggestions to make it work in the latest Armbian... I am bumping this thread because I have limited time with my opiz3, but you may be able to do it (and share).
More references of success: https://forum.armbian.com/topic/31848-cant-use-ffmpeg-hardware-accelration-v4l2-orange-pi-4-lts/?do=findComment&comment=175688
^ Actually, if you see that link, you will see a way to compile your own Armbian image, with some linux patches that allow ffmpeg-v4l2request do its work.
i tried your dts for opiz2w, and thank you, its helped me! but i have two problems: first - screen size is not 320x240 for my system (somewhere the line is being moved, although there is still space further on the screen, and the beginning of the line vertically is not at the very top of the screen, but in the middle), and second - bgr... i tried bgr = <0> and bgr = <1> and rgb = <0> etc... do you know, how to fix at least one of it?
oke, i found out, that system defines display in 240x320 mode, but i need 320x240, idk i tried to change height and weight values in dts
I can't understand your situation :( can yoiu send a photo of the LCD, the kernel version, and do some of the tests that I wrote in this thread?
Start with the DTS here: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-205335
The bgr and rgb parameters are among the last things to fix (applies to only some LCD drivers)... do you even get a picture in the LCD with wrong colors?
Is anyone using the orange pi zero LTS or 3, with any ilitek LCD, with spi-gpio driver?
I had my LTS working with ili9341 and spi-gpio last year... but the touch is not working now... I think I changed the wiring or the DTS  in the running system but I can't tell.
Posted (edited)
I was having some trouble with newer ili9488 LCD v2.1, and I didn't have ili9488 LCD v1.1, so I decided to experiment again with ili9341 LCD v1.2.
I found that this DTS https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204672
Doesn't work with the touch chip.
By accident, I ran the ili9488 driver on this ili9341, and I saw garbled graphics... but the good news: touch was working. Something in the ili9488 DTS which doesn't work for the ili9488 LCD, works for ili9341.
I found the difference was not in the ads7846 section, but in the spi speed for the ili9xxx part.
I switched back to the ili9341 DTS (with adafruit driver), but changed the SPI speed from 24MHZ to 40MHz.... then the ili9341 DTS was working with graphics and touch again :) ALTHOUGH the graphics have some flashing pseudo-colors in some places.
Maybe the 40MHZ is too much, but I re-gained touch in ili9341 LCD v1.1. I will keep doing experiments.
Playing with the SPI Mhz didn't help with the ili9488
Edited by robertoj
Hello @robertoj
I think i have the same problem with @RimYT above about wrong color with ili9486, i'm using screen MPI3501 which is clone screen of waveshare tft35
I apply the same device tree and guide in https://github.com/dev-null2019/orangepizero2w35tft. The screen work but i wrong color, it seem revered
Red. —> blue
Green —> red
Blue. —> green
I also write detail in here
I know my problem not totally related to your topic, but can you suggest me what i should to check more
About wrong color i think the driver cause it.
Driver for render image in this kernel sunxi is ili9486drmtft. I get right color in raspberry pi 4 but raspberry pi 4 use fb_ili9486.
On this orangepi zero 2 w, i try 3 different OS but still get same wrong color after adding dts for ili9486
1. Orangepi OS Kernel 6.1
2. Armbian OS Kernel 6.1
3. Debian Bookworm 12 Kernel 6.1
All using ili9486drmtft and get wrong color
I also try to change bgr value in dts, but it only create change in .../spi@1.0.../bgr not the color on screen
I try to get source code https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-6.1-sun50iw9 to change the bgr field in driver, but i can't insmod the module i build. It say invalid symbol
I see someone comment that after kenel 5.4 in repo sunxi remove fbtft_device, so we can't add the fb_ili9486 . The Offical OS supported by Orangepi has Kernel 5.4 Debian, i use it, but after add overlays and reboot, it seem wrong setup, ethernet not working, and i don't know why.
Does this still work with current armbian version? I am using  v25.11.2 for Orange Pi Zero3 running Armbian Linux 6.12.58-current-sunxi64 and I can't even get the display to turn on.
Now I'll admit I am a complete noob when it comes to linux so I am most likely doing something wrong.  I know am doing something that's way over my head but I enjoy researching and learning things but it's hard to find things on the subject.
I am using the DTS from this comment:
- copied it into ~ili9341
then did:
- cd ili9341 armbian-add-overlay ili9341-spi1-opiz3.dts
I rebooted and notice the screen didn't come on, so I did: dmesg and then following message came up:
 sun6i-spi 5011000.spi: cannot register SPI host
It's a cheap ili9341 tft from aliexpress, it says it's using ST7789V for display drivers, is that maybe why it isn't working?
driver ili9341.ko does show up in /lib/modules/6.12.58-current-sunxi64/kernel/drivers/gpu/drm/tiny
any help would be appreciated.
Posted (edited)
Well I got it to display something, it isn't exactly what I want but I am just happy I got it to do something.  I decided to try with the orangepi image from their website "Orangepizero3_1.0.2_ubuntu_jammy_desktop_xfce_linux6.1.31.img".
I was going to share image from what it's displaying but for some reason I keep getting an error trying to upload.
Basically it's showing the orangepi boot logo but then all messed up, it's all over the place.
------ edit got image to upload. ------
Edited by Jeffrey
@robertoj Thank you for being willing to help.
It was actually because my jumper wires were too long. I now can see the everything fine on the screen. The only issue that remains is loading the desktop environment, I can't seem to get in nomatter what I try. I've tried multiple image but every single time it just fails. Any ideas?or is there an image available that is known to work that I can download?
Jeffrey,
Is your DTS using this in the "compatible" line: adafruit,yx240qv29 ?
Are you trying to use an X11 or Wayland greeter and desktop? (I can't remember what commands to use to check that right now).
I didn't know about X11 problems with adafruit,yx240qv29 (only with the other driver panel-mipi-dbi)
There's no available image to download with all the required parts.
At this point I've tried with and without adafruit,yx240qv29. I also have tried with X11 and Wayland. I am at the point where I am using Gemini to figure out what is wrong but not making much progress. I have found people with similar issues but no solutions.
If you have X11 installed, then boot with only the LCD and try:
sudo systemctl stop lightdm (the greeter, which requires X11)
sudo startx
Show me what errors you see
If you have Trixie, boot with only the LCD and:
sudo apt install labwc
labwc (as a regular user)
Large language models are just google on steroids. They can only give good answers, if hundreds of people have typed and published solution similar to your problem.
So I have tried all the different images for the Opiz3 from the Orange pi website with the dts, I have tried 2 of the desktop images for the opiz3 from armbian. All of them result in the desktop environment not booting correctly. with Armbian I even got to the point where there are no errors in the lightdm logs, yet still a black screen.
However with all those different images, a simple manual restart of lightdm (systemctl restart lightdm.service, will fix it and make the desktop show up.
That's good news :D
You are using lightdm with the default greeter GUI, right? That means that your LCD driver can support X11. Are you still using adafruit,yx240qv29?
Maybe the lightdm service is getting confused about which display to use.
What do you get with: $ ls /dev/fb*  ?
Make sure that you don't connect an HDMI LCD at the same time.
Which desktop(s) do you use? XFCE and Gnome?
Posted (edited)
Yeah I am glad that atleast I can get into desktop environment by manually doing a lightdm restart.
ls /dev/fb* returns: /dev/fb0
I feel like I've tried everything possible and ended up just making a custom script that restarts lightdm a few seconds after booting, it's not ideal and it bothers me that it isn't working properly but yeah.
- I am using adafruit,yx240qv29
- Yes I am using XFCE currently but I've tried Gnome too.
- the Slick greeter
- Orangepizero3_1.0.2_ubuntu_jammy_server_linux6.1.31 / but have tried MANY others.
Also what might be useful for others, just the DTS wasn't enough for things to work, also had to create a config in /etc/X11/xorg.conf.d/ and add these lines:
Section "Device"
    Identifier "ILI9341-Device"
    Driver     "fbdev"
    Option     "fbdev" "/dev/fb0"
EndSection
However things aren't super stable yet, the screen sometimes will randomly stop working, first I though maybe there is a screensaver or something but that doesn't seem to be the issue. Leaves me to think it's maybe power related and need to use shorter cables and a better 3.3v power supply (currently using the 3.3v from the opiz3). Lastly maybe shortening my jumper wires might make a difference. Previously the screen was all the way glitched as seen in my earlier post, I had shortened the dc, miso, mosi and SCLK jumpers but maybe I should make them even shorter. What makes me think it might be power related is also because sometimes the screen seems to go slightly dimm and then brighten back up, it's subtle but visible. Lastly I might have the depth or spi frequency not dialed in yet.
Edited by Jeffrey
Posted (edited)
Sorry for taking so long to try this, I decided to solder thicker and shorter wires onto the board to make sure that isn't the issue.
Unfortunately it still crashes after a short while but nothing is seen in ssh session:
~# tail -f /var/log/Xorg.0.log
[    34.652] (II) event1  - sunxi-ir: device is a keyboard
[    34.722] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall"
[    34.722] (II) Using input driver 'libinput' for 'sunxi-ir'
[    34.722] (**) sunxi-ir: always reports core events
[    34.722] (**) Option "Device" "/dev/input/event1"
[    34.722] (II) libinput: sunxi-ir: is a virtual subdevice
[    34.722] (**) Option "config_info" "udev:/sys/devices/platform/soc/7040000.ir/rc/rc0/input1/event1"
[    34.722] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 😎
[    34.722] (**) Option "xkb_model" "pc105"
[    34.722] (**) Option "xkb_layout" "us"
I am going to mess with the SPI frequency and see if that makes any difference.
----- edit -----
I actually found out that the desktop only freezes whenever I stop using the mouse for 5 seconds.
Edited by Jeffrey
Posted (edited)
Now that you can replicate the crash anytime. Right after it crashes:
$ dmesg
$ journalctl -u lighdtm
Also, try another application that will use the LCD continuously, without starting X11:
$ mplayer -vo fbdev2:/dev/fb0 videofile.mp4 (use a 320x240 approx video, so it will be smooth without hardware acceleration)
If it works, then maybe X11 is the problem, not the LCD driver.
I wish more people switched to 100% Wayland in their HDMI monitors and LCDs. I have a method.
If you want it too: https://forum.armbian.com/topic/55882-critique-or-improve-my-method-to-get-a-lightweight-labwc-desktop/#comment-227469
Edited by robertoj
I will definitely look into that.
"mplayer -vo fbdev2:/dev/fb0 videofile.mp4" with desktop disabled worked perfectly by the way, no issues.
WhatsAppImage2025-12-15at22_30.34_26f1460d.thumb.jpg.8d6307a5a28de70a70b122840728f85d.jpg
I've used both X11 and wayland though and also there is nothing in the logs which I find extremely weird. However I will look into it further the upcoming week, I am most definitely missing something.
On 12/9/2025 at 1:40 AM, robertoj said:
hello! i'm still relatively new to this kind of stuff. i got the ili9341 working using the dts i found in this thread. my next thought is it possible to have it display an image? thanks!
If you don't have X11 or Wayland, try using the linux command "fbi" (frame buffer image). I think I put an example in this trhead or in the Banana Pi ili9341 thread (in this allwinner forum section).
