NanoPi DUO2 microUSB serial stop working on 24.11.0
Go to solution Solved by nickycakes,
I'm using Nanopi DUO2 for few IoT projects. Using the microUSB serial console connection is very convenient and fast method to manage this SBC.
Unfortunately with latest version of Armbian (tested with v24.11.0) it not working any more. Version 23.11.1 works fine out from the box, but after
sudo apt update && sudo apt full-upgrade
the microUSB serial console is not available.
Any suggestion how to switch it back will be very appreciated.
Slawek
If still not working, install the newest OS image in a different microSD card, verify that you have the USB-serial function.
Then check the differences in armbianEnv.txt, and the result of "lsmod", against your old microSD.
If you succeed or not, post your results here, because that's how we build up the knowledge base.
Hi I did following steps:
install fresh Armbian_23.11.1_Nanopiduo2_jammy_current_6.1.63.img.xz. After boot the COM19 is available:
Armbian_23_11.1_Nanopiduo2_jammy_current_6.1_63.img-COM19.png.699caaa5d9e06adb2f562061ea241caf.png
root@nanopiduo2:~# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=usbhost0 usbhost2 usbhost3
fdtfile=sun8i-h3-nanopi-duo2.dtb
rootdev=UUID=0cff826e-57ba-4014-a11e-8827efd9a1a0
rootfstype=ext4
root@nanopiduo2:~# lsmod
sunrpc                339968  1
hci_uart               61440  0
btbcm                  16384  1 hci_uart
bluetooth             540672  3 hci_uart,btbcm
lz4hc                  16384  0
lz4hc_compress         24576  1 lz4hc
brcmfmac              188416  0
ecdh_generic           16384  1 bluetooth
ecc                    28672  1 ecdh_generic
brcmutil               16384  1 brcmfmac
lz4                    16384  0
lz4_compress           32768  1 lz4
sunxi_cedrus           40960  0
sun4i_gpadc_iio        16384  0
industrialio           61440  1 sun4i_gpadc_iio
cfg80211              573440  1 brcmfmac
v4l2_mem2mem           20480  1 sunxi_cedrus
videobuf2_dma_contig    20480  1 sunxi_cedrus
videobuf2_memops       20480  1 videobuf2_dma_contig
videobuf2_v4l2         20480  2 sunxi_cedrus,v4l2_mem2mem
sun8i_thermal          16384  0
videobuf2_common       45056  5 sunxi_cedrus,videobuf2_dma_contig,videobuf2_memops,v4l2_mem2mem,videobuf2_v4l2
rfkill                 20480  5 bluetooth,cfg80211
videodev              167936  4 sunxi_cedrus,videobuf2_common,v4l2_mem2mem,videobuf2_v4l2
mc                     40960  5 sunxi_cedrus,videobuf2_common,videodev,v4l2_mem2mem,videobuf2_v4l2
evdev                  20480  1
cpufreq_dt             20480  0
uio_pdrv_genirq        20480  0
uio                    16384  1 uio_pdrv_genirq
zram                   24576  3
binfmt_misc            20480  1
sch_fq_codel           20480  3
usb_f_acm              20480  1
u_serial               24576  3 usb_f_acm
g_serial               16384  0
libcomposite           45056  2 g_serial,usb_f_acm
ip_tables              24576  0
x_tables               28672  1 ip_tables
autofs4                36864  2
ac200_phy              16384  1
pwrseq_simple          16384  1
dwmac_sun8i            28672  0
stmmac_platform        24576  1 dwmac_sun8i
stmmac                172032  2 stmmac_platform,dwmac_sun8i
pcs_xpcs               20480  1 stmmac
phylink                36864  2 pcs_xpcs,stmmac
mdio_mux               16384  2 dwmac_sun8i
sunxi                  16384  0
phy_generic            20480  2 sunxi
gpio_keys              20480  0
then I run: apt update && apt full-upgrade and reboot
the COM19 is gone from my Windows PC
verbosity=1
bootlogo=false
console=serial
rootfstype=ext4
no difference to previous one
and
sunrpc                339968  1
hci_uart               61440  0
lz4hc                  16384  0
brcmfmac              188416  0
lz4                    16384  0
evdev                  20480  1
cpufreq_dt             20480  0
zram                   24576  3
binfmt_misc            20480  1
usb_f_acm              20480  1
g_serial               16384  0
ip_tables              24576  0
autofs4                36864  2
ac200_phy              16384  1
dwmac_sun8i            28672  0
sunxi                  16384  0
gpio_keys              20480  0
Should I test also installation of latest Armbian_community_24.11.0-trunk.66_Nanopiduo2_noble_current_6.6.44.img.xz
before_upgrade.txt after_upgrade.txt
I cant see the problem XD
In this latest-working setup, run "armbianmonitor -u" to get a snapshot of the boot execution, and copy the resulting link here. Also, show the result of "dmesg | grep g_serial" (the ko driver that enables the USB-serial-device function in the CPU.
Try again with the Armbian_community_24.11.0-trunk.66_Nanopiduo2_noble_current_6.6.44.img.xz. Verify that the USB-serial-device function is working. Don't update, and run the 2 tests as above: armbianmonitor and dmesg|grep g_serial
Sir Yes Sir 😉 .... but not until a few hours later, I have to do some urgent work now. Thank you very much for your effort. Will be back with reports soon.
Voila:
root@nanopiduo2:~# armbianmonitor -u
Collecting info and sending to paste.armbian.com, wait...
https://paste.armbian.com/jareyilapa
root@nanopiduo2:~# dmesg | grep g_serial
[    7.735341] g_serial gadget.0: Gadget Serial v2.4
[    7.735366] g_serial gadget.0: g_serial ready
/usr/bin/armbianmonitor: line 976: iostat: command not found
https://paste.armbian.com/hogapesowi
[    6.003420] UDC core: g_serial: couldn't find an available UDC
[    8.984241] g_serial gadget.0: Gadget Serial v2.4
[    8.984274] g_serial gadget.0: g_serial ready
first line above looks suspicious IMHO ....
Looks like UDC is a part of the g_serial that fails to load.
Not an easy problem for me. Just revert to working OS, and reinstall your applications :(
Similar problems: https://support.xilinx.com/s/question/0D52E00006iHmGwSAK/usb-udccore-couldnt-find-an-available-udc-added-gmassstorage-to-list-of-pendi?language=en_US
https://stackoverflow.com/questions/65012555/how-to-enable-usb-gadget-mode-from-menuconfig
https://github.com/gokrazy/kernel/issues/418
I hope i didnt lose this functionality in my orange pi zero
When the SBC is connected to the WiFi network I can ssh - not a problem, but in my setup I'm using most of the pins of NanoPi duo2 including debug uart. So in case of maintenence the mini-usb serial was only option. So I have to be very careful and at any cost avoid upgrading my system.
Do you have spare opi zero "on the drawer" to run the test?
I spent the better part of the last 2 days taking a crash course in arm device trees and armbian to fix this for myself because I don't want to solder pin headers on every new board and I think I have found the problem.
The device tree between 23.11.1 and 24.2.1 changed from what appears to be this commit: ARM: dts: sunxi: H3/H5: Add phys property to USB HCI0
In the most recent bookworm minimal image (Armbian_community_25.2.0-trunk.195_Nanopiduo2_bookworm_current_6.6.62_minimal.img) I decompiled/edited/compiled the device tree via:
cd /boot/dtb
dtc -I dtb sun8i-h3-nanopi-duo2.dtb -O dts -o sun8i-h3-nanopi-duo2.dts
nano sun8i-h3-nanopi-duo2.dts
#remove those 4 lines
dtc -I dts -O dtb sun8i-h3-nanopi-duo2.dts -o sun8i-h3-nanopi-duo2.dtb
reboot
After reboot the OTG serial shows up on boot and can be used as normal.
I'm not experienced enough yet to know what other implications this has on other things, but someone with more experience can probably read that commit message and figure it out.
My next step I think is figuring out how to turn this into a device tree overlay to use in my custom build or figure out how to submit this as some sort of fix for armbian.
Edited by nickycakes
On 12/26/2024 at 6:31 PM, robertoj said:
check that there are no uboot errors related to loading that dtbo (right before loading the kernel).
i didn't use an overlay because apparently overlays cannot remove lines, only add or modify.  I used a patch file on the kernel dtsi and recompiled.
uboot logs are identical.  here is the fixed version:
U-Boot SPL 2024.01-armbian-2024.01-S866c-Pe31d-Ha5c2-Vb835-Bdacf-R448a (Dec 13 2024 - 09:33:36 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2024.01-armbian-2024.01-S866c-Pe31d-Ha5c2-Vb835-Bdacf-R448a (Dec 13 2024 - 09:33:36 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: FriendlyARM NanoPi NEO
DRAM:  512 MiB
Core:  64 devices, 19 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial,usbkbd
Out:   serial
Err:   serial
Starting SCP...
Net:   SCP/INF: Crust v0.6.10000
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
5475 bytes read in 2 ms (2.6 MiB/s)
U-boot loaded from SD
273 bytes read in 1 ms (266.6 KiB/s)
Load fdt: /boot/dtb/sun8i-h3-nanopi-duo2.dtb
10758303 bytes read in 442 ms (23.2 MiB/s)
8995680 bytes read in 385 ms (22.3 MiB/s)
35930 bytes read in 6 ms (5.7 MiB/s)
Working FDT set to 43000000
504 bytes read in 3 ms (164.1 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4185 bytes read in 4 ms (1021.5 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0x894360 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Data Size:    10758239 Bytes = 10.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 495bd000, end 49fff85f ... OK
   Loading Device Tree to 4954b000, end 495bcfff ... OK
Working FDT set to 4954b000
Starting kernel ...
here is the patch:
From 8e3bdad04af35210a4f4b694212351b2c94b119d Mon Sep 17 00:00:00 2001
Date: Fri, 27 Dec 2024 04:58:02 +0000
Subject: [PATCH] fix nanopi duo2 otg serial
 arch/arm/boot/dts/allwinner/sunxi-h3-h5.dtsi | 4 ----
 1 file changed, 4 deletions(-)
diff --git a/arch/arm/boot/dts/allwinner/sunxi-h3-h5.dtsi b/arch/arm/boot/dts/allwinner/sunxi-h3-h5.dtsi
index ade1cd50e445..fef6f6de097b 100644
--- a/arch/arm/boot/dts/allwinner/sunxi-h3-h5.dtsi
+++ b/arch/arm/boot/dts/allwinner/sunxi-h3-h5.dtsi
@@ -302,8 +302,6 @@ ehci0: usb@1c1a000 {
                        interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
                        clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
                        resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
-                       phys = <&usbphy 0>;
-                       phy-names = "usb";
                        status = "disabled";
@@ -314,8 +312,6 @@ ohci0: usb@1c1a400 {
                        clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>,
                                 <&ccu CLK_USB_OHCI0>;
2.34.1
23 minutes ago, Slawek said:
is there compiled img available? Or I should just compile it myself?
you can compile it yourself by putting the patch i posted above into something like /userpatches/kernel/archive/sunxi-6.6/fix-nanopiduo2-otg-serial.patch and then building, but that will force a recompile of the kernel which takes a while.  i would first test it out by editing your device tree in a live system like i did here
  • Solution
ok, i'm also happy to report that if you simply build with the 'edge' kernel option (6.11.9 atm) instead of 'current' that it is fixed without having to go through all this trouble.  tested on debian 12 and 13.  apparently they've fixed it since linux 6.6.65
Ufffffff after one week battle (many enemies against me ..... wsl2/wrong kernel/Hyper-V/docker) I was able to compile Armbian. I can confirm that 'edge' version of noble and oracular are working fine. We can close the topic IMHO. Thanks guys.
Before I'll open new topic @nickycakes can you reboot system from command line with 'edge' kernel option (6.12.6 atm)? Mine behave like shutdown - I have to unplug/plug the board 🤥
no, i think there are individual patches for the stable kernels that do this that wouldnt be automatically applied to the edge kernel, see
/patch/kernel/archive/sunxi-6.11/patches.armbian/ARM-dts-sun8i-nanopiduo2-Use-key-0-as-power-button.patch
in the armbian build repo
Hi @nickycakes this patch is related to hardware button I have a problem with console reboot now command. I make some investigation which kernel version from edge branch has boot and serialUSB. Here are the results:
but I have no idea what is source of problem. For the moment will play with 6.10.9 ver.
Maybe I should open new topic on the forum?
