I got my OPi PC2 last week and flashed the latest armbian server version. Every time I enter "reboot" on SSH to reboot the system,  or plug in the power cable.  The system can not boot up with a great probability.  My power source is the charger for SAMSUNG smartphone.  The specification indicates it can provide 5V/2A current.
With the UART,  I found the uboot process was stuck after the statement "INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9".  The LED is OFF in that moment.
Quote
[89805.284271] reboot: Restarting system
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State ON
INFO:      AffInst: Level 0, MPID 0x2, State ON
INFO:      AffInst: Level 0, MPID 0x3, State ON
U-Boot SPL 2017.01-rc1-g5df570f-dirty (Jun 13 2017 - 21:51:43)
DRAM: 1024 MiB
Trying to boot from MMC1NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):aa75c8d
NOTICE:  BL3-1: Built : 21:51:42, Jun 13 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
After plugging out/in the power cable multiple times,  the system can be boot up successfully finally and works very well.
I'd like to know anyone has the same problem?  How can I solve this issue?
I would suggest that you look at getting a different power supply, as mobile phone chargers are notorious for being unreliable for SBCs. They tend to either not provide their full current until the phone has *handshaked/negotiated* with the charger, are noisy, or drop their voltage they are loaded to below usable levels (as phone charging needs aren't that demanding). I would suggest you look at getting something like the white power supply (with interchangeable international plugs) for the raspberry pi.
Also, please refrain from making multiple posts... someone *will* reply eventually ;)
Thank you.  I will try to change a new power supply.
I was not intent to making multiple posts,  it was just an accident :)  Maybe my network issue, the edit page didn't have any response after my first clicking on the submit button.  So I clicked twice...  And I didn't find how to delete the duplicate one.
No worries, I'll remove it (actually, I think another mod beat me to it!). Please do report back and let us know how you go. And someone else might post in the meantime with more info or more ideas. :D
I have tested it with a power supply of raspberry pi (5v/1.5a). But still get the same issue.  I also measured the electric current is about 300mA during the system boot.  Even during the stress test (stress -c 4 -i 4 -m 2),  the peak current is less than 600mA.
I find another phenomenon:
If the uboot has about 3 second pause after printing "Trying to boot from MMC1".  it will get stuck at the statement "INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9" later.
For a success boot up,  there is no pause after printing "Trying to boot from MMC1".
Only other thing I can suggest is maybe the microSD is corrupt or faulty? (yes, clutching at straws with my limited knowledge ;) ) If you can try re-writing the Armbian image using Etcher. And please keep in mind this warning from the download page: "All currently available OS images for H5 boards are experimental". I would be surprised if the images were that unstable that they wouldn't even boot, but the warning still stands... murky waters ahead!
Other than that, I'll have to bow out and leave it for more experienced folks to chip in ;)
I will try to find another mircoSD to write a new image. Will report back later.   Thanks for your help.
Weyou, It may be obvious, but are you using a barrel type power supply? Looks like you are using an OTG (USB type) power supply, since you Are talking about Samsung and Raspberry Pi chargers. I have an orange Pi pc 2 and I use the manufacturer recommended AC adapter 3A, barrel type.
I'm using the Samsung/RaspberryPi chargers with a USB to barrel connector cable.  I didn't use the OTG(MicroUSB) interface .
Weyou,
OPI PC2 is very stringent regarding power requirements. Failing the SD card replacement, You should try with the manufacturer recommended AC adaptor, 5V/3A, 4.0*1.7 barrel plug...I also tested other adaptors with my board, but none of them worked, until I ordered the recommended adaptor via Xulong Aliexpress page.
8 hours ago, joselalf said:
Weyou,
Thank you, joselalf.  I will try to order the recommended AC adapter If I failed the SD card replacement.
As far as I can tell, Orange PI's should be supplied with a voltage of 5.4V. I use a metal case Mean Well RS-25-5 and have to fine tune the output to 5.4V. Below, random no booting issues occurs (It suppllies power to four unit of PC2's)
@Yuan I can't say I'd agree with that voltage... I think it's a little too high. 5.3v is the highest I generally go at the power supply.  Keeping in mine the USB spec tolerances of 4.75V-5-25V, so if the 5v rail is also providing the USB voltage (and it often does), you're in danger of pushing a higher voltage than what devices are expecting, unless you get enough of a voltage sag over the leads. Whether that is enough to blow up a USB device when you plug it in, I couldn't say as I haven't tested every device under the sun. However, I would expect it to shorten the live of some devices.  What I would recommend is also measuring the voltage at the device, both with no load, and when the CPU is loaded, and making sure the voltage doesn't fall below 5.00v minimum, maybe even 5.10v, depending what it shoots back up to when not loaded.
I did some measurements on both PC (connected to a plastic case wall plug 5V2A rated voltage power supply, actual output voltage is 5.36V), and PC2's (connected to the SMPS mentioned above, actual voltage is 5.40V) from GPIO pins and USB cable ends under load (running stress command):
  • I get exact same 5.36V on bot GPIO pins and USB cable ends on PC
  • I get regulated 5.23V on GPIO pins and 5.23V on USB cable ends on PC2 (5.40V->5.23V)
As I use these SBC's for headless server use with no USB device attached to them, haven't encountered to any problem. But you may be right that 5.36V is dangerous for USB devices though.
I got an new SD card today.
At first,  I flashed the latest nightly build of armbian.  Reboot it with "reboot" command or power cycle multiple times. The same issue happened again and again.  The  probability of occurrence is about 60%.
Then, I flashed the stock image Debian_Server_jessie_PC2_V0_9_1.img which is downloaded from the office website of OPi.
Reboot the OPi PC2 20 times,  every time it can boot up successfully.   Does this mean the u-boot used by armbian has some issue?
Quote
[  170.953010] Restarting system.
INFO:      AffInst: Level 2, MPID 0x0, State ON
INFO:      AffInst: Level 1, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
HELLO! BOOT0 is starting!
boot0 commit : 8
boot0 version : 4.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x0000000f
rtc[3] value = 0x0000a102
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM BOOT DRIVE INFO: V0.6
the chip id is 0x00000001
axp not exist
DRAM CLK =672 MHZ
DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM zq value: 0x003b3bf9
DRAM SIZE =1024 M
DRAM simple test OK.
dram size =1024
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2016-03-15 20:40
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 30528 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sum=710a857c
src_sum=710a857c
read boot-pkg from emmc 32800 sector
Succeed in loading uboot from sdmmc flash.
Entry_name        = u-boot
Entry_name        = monitor
Entry_name        = scp
set arisc reset to de-assert state
Ready to disable icache.
▒R▒=▒    Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):3ffd944
NOTICE:  BL3-1: Built : 11:09:10, Aug 30 2016
NOTICE:  BL3-1 commit: 3ffd9442d4769d7fc0002770e3b69b55150a288e
ERROR:   Error initializing runtime service tspd_fast
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07 (Nov 09 2016 - 15:49:10) Allwinner Technology
uboot commit : 8
secure enable bit: 0
i2c: secure monitor exist
[      0.714]pmbus:   ready
u0:48105000
[      0.718][ARISC] :arisc initialize
[      0.748][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc version: [sun8iw5_v0.03.00-244-gb750b8e]
[SCP] :sunxi-arisc driver v1.20 is starting
[      0.764][ARISC] :sunxi-arisc driver startup succeeded
axp: get node[charger0] error
[SCP ERROR] :message process error
[SCP ERROR] :message addr   : 48105080
[SCP ERROR] :message state  : 5
[SCP ERROR] :message attr   : 2
[SCP ERROR] :message type   : 80
[SCP ERROR] :message result : f3
[SCP WARING] :callback not install
[SCP ERROR] :arisc twi read pmu reg 0x3 err
probe axp806 failed
axp_probe error
[      0.945]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz MBus=400Mhz
run key detect
no key found
no uart input
DRAM:  1 GiB
fdt addr: 0x76e9f0e0
Relocation Offset is: 35ef2000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[box standby] read rtc = 0xf
[box standby] start_type = 0x1
[box standby] to kernel
boot_init_gpio used
ir boot recovery not used
workmode = 0,storage type = 1
[      1.149]MMC:        0
[mmc]: mmc driver ver 2016-05-20 17:18:00-test0
[mmc]: get card2_boot_para:sdc_ex_dly_used 0
[mmc]: no mmc-hs400-1_8v!
[mmc]: no mmc-hs200-1_8v!
[mmc]: no mmc-ddr-1_8v!
[mmc]: delete max-frequency from dtb
SUNXI SD/MMC: 0
[mmc]: 50 MHz...
[mmc]: sample: 63 - 158(ps)
[mmc]: 100 MHz...
[mmc]: sample: 33 - 151(ps)
[mmc]: 200 MHz...
[mmc]: sample: 17 - 147(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 1b PSN dcf20421
[mmc]: PNM 00000 -- 0x30-30-30-30-30
[mmc]: PRV 1.0
[mmc]: MDT m-10 y-2014
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 4 bit
[mmc]: user capacity  : 30528 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size      : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature      : 0x0
[mmc]: secure_removal_type : 0x0
[      1.347]sunxi flash init ok
[      1.361]start
drv_disp_init
tv_init:
tv_probe:000
no report hpd work,you need support the switch class!
screen 0 don't support TV!
tv_init:
fetch tv1 err.
drv_disp_init finish
hdcp is closed by sys config.
no the part:Reserve0
hpd_dev_num=2, id of def_output_dev is 0
hdmi hpd out, force open?
fdt_setprop_u32 disp.init_disp(0x20b0404) code:<no error>
fb_id=0, size=3686400, gd->ram_size=1073741824, SUNXI_DISPLAY_FRAME_BUFFER_SIZE=16777216
[      1.931]end
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery, limit to dc
no battery exist
sunxi_bmp_logo_display
[boot disp] can not find the partition Reserve0
** Bad device size - sunxi_flash 0 **
sunxi bmp info error : unable to open logo file bootlogo.bmp
fail to find part named env
Using default environment
--------fastboot partitions--------
mbr not exist
base bootcmd=run mmcbootcmd
bootcmd set setargs_mmc
no misc partition is found
to be run cmd=run mmcbootcmd
cann't get the boot_base from the env
read item0 copy0
Item0 (Map) magic is bad
the secure storage item0 copy0 is bad
read item0 copy1
the secure storage item0 copy0 == copy1, the data is good
the secure storage map is empty
check user data form private
the private part isn't exist
update dtb dram start
update dtb dram  end
serial is: 8400503640184c22044c
[      2.099]inter uboot shell
Hit any key to stop autoboot:  0
Loading orangepi uEnv.txt from 40000000 ...
reading uEnv.txt
[mmc]: blkcnt should not be 0
140 bytes read in 3 ms (44.9 KiB/s)
Loading boot environment ...
Loading orangepi bootscript ...
reading boot.scr
** Unable to read file boot.scr **
Booting with defaults ...
Loading orangepi orangepi/OrangePiH5orangepi.dtb from 44000000 ...
reading orangepi/OrangePiH5orangepi.dtb
56524 bytes read in 7 ms (7.7 MiB/s)
Loading orangepi orangepi/uImage from 4007ffc0 ...
reading orangepi/uImage
12200584 bytes read in 522 ms (22.3 MiB/s)
reading initrd.img
1090786 bytes read in 48 ms (21.7 MiB/s)
Loading orangepi initrd.img from 44300000 ...
bootm kernel:4007ffc0 initrd:44300000 ...
bootm initd_size:10a4e2 fdt_addr:44000000 ...
## Booting kernel from Legacy Image at 4007ffc0 ...
   Image Name:   OrangePiH5
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    12200520 Bytes = 11.6 MiB
   Load Address: 40080000
   Entry Point:  40080000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
   reserving fdt memory region: addr=40020000 size=800
   reserving fdt memory region: addr=48000000 size=1000000
   reserving fdt memory region: addr=48100000 size=4000
   reserving fdt memory region: addr=48104000 size=1000
   reserving fdt memory region: addr=48105000 size=1000
   Loading Ramdisk to 76d85000, end 76e8f4e2 ... OK
   Using Device Tree in place at 44000000, end 44015dbf
Starting kernel ...
Go find the getting start guide and read it then come back. You need tell us you know what's what. H5 is a wip
