Rui Ribeiro Posted November 24, 2015 Share Posted November 24, 2015 Dears, I have done the last update. I lost dkms, and when trying to recompile/reinstall it, I started get strange errors. It seems binaries in linux-headers are compiled for Intel. I would even the kernel is configure for Intel. Was not able to compile the module actually. Was there some mishap? Rui Link to comment Share on other sites More sharing options...
wildcat_paris Posted November 25, 2015 Share Posted November 25, 2015 Rui, there is probably a workaround as root to get back dkms working to compile make scripts in gr@bpi:/usr/src/linux-headers-4.3.0-sunxi$ sudo make scripts HOSTCC scripts/basic/fixdep HOSTCC scripts/basic/bin2c HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf scripts/kconfig/conf --silentoldconfig Kconfig HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/dtc CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o CC scripts/mod/devicetable-offsets.s GEN scripts/mod/devicetable-offsets.h HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/sumversion.o HOSTLD scripts/mod/modpost HOSTCC scripts/kallsyms HOSTCC scripts/conmakehash HOSTCC scripts/sortextable HOSTCC scripts/asn1_compiler HOSTCC scripts/extract-cert gr@bpi:/usr/src/linux-headers-4.3.0-sunxi$ file scripts/basic/fixdep scripts/basic/fixdep: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=e21986187584d701fa8f4d5d987a9cee808208c8, not stripped Armbian will provide a better solution. Link to comment Share on other sites More sharing options...
