Hello guys
I have a question regarding H3 overlays. I see that during build "overlay" folder is created in arch/arm/boot/dts  and H3 overlays are copied there.
Can you point, please, where build framework takes those file from and how to customize this ?
The goal here is to add an extra overlay.  I see that the structure is very similar to https://github.com/armbian/sunxi-DT-overlays but I can't find in build scripts if you copy files from there or any other repository.
Thanks.
https://github.com/armbian/build/blob/master/patch/kernel/sun8i-dev/add-h3-overlays.patch
It's not customizable in a simple way (without adding or editing kernel patches). It should be possible to compile or copy precompiled overlays in "customize-image.sh"
and 1 more question:
what is meaning of line
MODULES="8189es #w1-sunxi #w1-gpio #w1-therm #gc2035 #vfe_v4l2 #sunxi-cir"
in the file config/boards/*.conf ?
1 hour ago, ssuloev said:
one more question: how can I add my overlay into armbianEnv.txt file in a resulting image automatically?
By using sed or echo in customize-image.sh
List of entries added to /etc/modules, in this case - for the default (legacy) kernel.
46 minutes ago, ssuloev said:
can you explain please how to add an extra module (i.e. wm8731 codec) module in legacy kernel ?
Sorry, activating third party hardware on legacy kernel is complicated since these drivers need palform data to specify I2C/SPI bus and audio routing parameters. As far as I know there is no ready to use solution for this or most of the other drivers.
