ARM_Bruzzler Posted October 8 Share Posted October 8 I want to use GPIO Pi16 on the 13 pin expansion header of the board. This pin is claimed by the kernel for the ethernet MAC. According to the SOC Datasheet this pin has the option to provide a 25 MHz clock signal for the ethernet MAC, which is not relevant for this board. Thanks to this Topic https://forum.armbian.com/topic/30274-armbian-build-how-to-modify-dts-file-to-change-gpio-mapping/ and the device tree source files https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h618-orangepi-zero3.dts, https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero.dtsi and https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h616.dtsi i managed to create an overlay named sun50i-h616-fix-emac-pin.dts to release the GPIO pin from the ethernet MAC/kernel. /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target=<&pio>; __overlay__{ ext_rgmii_pins: rgmii-pins { pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15"; function = "emac0"; drive-strength = <40>; }; }; }; fragment@1 { target = <&emac0>; __overlay__ { pinctrl-0 = <&ext_rgmii_pins>; }; }; }; sudo armbian-add-overlay /boot/sun50i-h616-fix-emac-pin.dts Even though I don't really understand how to write device tree overlays, surprisingly I could compile and apply the overlay to the kernel with the command above and it did its job. The GPIO is available now and the ethernet connection still works. Can someone who actually understands this subject review my code and include this change in the right form at the right spot? 0 Quote Link to comment Share on other sites More sharing options...
going Posted October 9 Share Posted October 9 19 часов назад, ARM_Bruzzler сказал: i managed to create an overlay named sun50i-h616-fix-emac-pin.dts to release the GPIO pin from the ethernet MAC/kernel. Unfortunately, you did not write which version of the kernel you wrote the overlay for. I checked it out. For the EDGE kernel (v6.11.2), this is present. No overlay is required. 0 Quote Link to comment Share on other sites More sharing options...
ARM_Bruzzler Posted October 9 Author Share Posted October 9 (edited) Thank you very much for checking. I use the Debian (minimal/iot) image from https://www.armbian.com/orange-pi-zero-3/. At the moment I have the kernel version 6.6.44. I ran sudo apt update && sudo apt upgrade and verified the overlay is still required after the latest update. So will the correction eventually be distributed over apt in a couple of days or weeks? Edited October 9 by ARM_Bruzzler 0 Quote Link to comment Share on other sites More sharing options...
Solution going Posted October 10 Solution Share Posted October 10 15 часов назад, ARM_Bruzzler сказал: So will the correction eventually be distributed over apt in a couple of days or weeks? Just stay tuned. Will be included in the kernel version v6.6.54 or later 0 Quote Link to comment Share on other sites More sharing options...
ARM_Bruzzler Posted October 10 Author Share Posted October 10 Thank you for the information. 0 Quote Link to comment Share on other sites More sharing options...
going Posted October 11 Share Posted October 11 08.10.2024 в 23:58, ARM_Bruzzler сказал: I want to use GPIO Pi16 on the 13 pin expansion header of the board. This pin is claimed by the kernel for the ethernet MAC. According to the SOC Datasheet this pin has the option to provide a 25 MHz clock signal for the ethernet MAC, which is not relevant for this board. I think I've misled you. For some reason I thought you wanted to add the whole node. But you want to replace it with the same one but without the PI16 pin. It's not in my power. I don't have this board to check. I apologize. 0 Quote Link to comment Share on other sites More sharing options...
