I use the serial library but when I import it. it will show an error. why?
File "test.py", line 1
SyntaxError: Non-ASCII character '\xe2' in file test.py on line 1, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
when i change coding, with the following code, it has the error again
# coding: utf-8
how can i solve it??
Your problem's description is not clear ...
Can you show us what your test.py contains ?
If you have utf-8 issues, you probably need to do a "export PYTHONIOENCODING=UTF-8" before starting your script.
