@going
out put off the command:
johan@rk322x-box:~$ sudo apt-get install build-essential git dkms
Reading package lists... Done
Building dependency tree... Done
build-essential is already the newest version (12.10ubuntu1).
git is already the newest version (1:2.43.0-1ubuntu7.1).
dkms is already the newest version (3.0.11-1ubuntu13).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
johan@rk322x-box:~$
2 минуты назад, JOHAN VAN DER MERWE сказал:
Everything is set.
@going
Im still getting no such file directory when i run the first command in this instruction could that be the problem
How to install
sudo apt-get install build-essential git dkms linux-headers-$(uname -r)
git clone https://github.com/kelebek333/rtl8188fu
sudo dkms install ./rtl8188fu
sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/
Configuration
Disable Power Management
Run following commands for disable power management and plugging/replugging issues.
sudo mkdir -p /etc/modprobe.d/
sudo touch /etc/modprobe.d/rtl8188fu.conf
echo "options rtl8188fu rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=0" | sudo tee /etc/modprobe.d/rtl8188fu.conf
Disable MAC Address Spoofing
Run following commands for disabling MAC Address Spoofing (Note: This is not needed on Ubuntu based distributions. MAC Address Spoofing is already disable on Ubuntu base).
sudo mkdir -p /etc/NetworkManager/conf.d/
sudo touch /etc/NetworkManager/conf.d/disable-random-mac.conf
echo -e "[device]\nwifi.scan-rand-mac-address=no" | sudo tee /etc/NetworkManager/conf.d/disable-random-mac.conf
Blacklist (alias) for kernel 5.15 and 5.16 (No needed for kernel 5.17 and up)
If you are using kernel 5.15 and 5.16, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in r8188eu module.
echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/r8188eu-blacklist.conf
Blacklist (alias) for kernel 6.2 and up
If you are using kernel 6.2 and up, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in rtl8xxxu module.
echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/rtl8xxxu-blacklist.conf
Then you must update initramfs
For initramfs
sudo update-initramfs -u
For dracut
sudo dracut -q --force
Enable rtl8188fu module
how do I install these drivers for my wifi chip
this is the output of the 3 lines that you said i need to install this is the last deb line.
johan@rk322x-box:~/debs$ sudo dpkg -i linux-image-edge-rockchip_24.11.0-trunk_ar        mhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb
(Reading database ... 175770 files and directories currently installed.)
Preparing to unpack linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-        D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' starting        .
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' finishin        g.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' starti        ng.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' finish        ing.
Unpacking linux-image-edge-rockchip (24.11.0-trunk) over (24.11.0-trunk) ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' startin        g.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' finishi        ng.
Setting up linux-image-edge-rockchip (24.11.0-trunk) ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' start        ing.
 * dkms: running auto installation service for kernel 6.11.4-edge-rockchip
 * dkms: autoinstall for kernel 6.11.4-edge-rockchip                     [ OK ]
update-initramfs: Generating /boot/initrd.img-6.11.4-edge-rockchip
W: Possible missing firmware /lib/firmware/mrvl/sdiouart8997_combo_v4.bin for bu        ilt-in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built-        in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdiouartiw416_combo_v0.bin for b        uilt-in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built-        in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8801_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8786_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/rt73.bin for built-in driver rt73usb
W: Possible missing firmware /lib/firmware/bfubase.frm for built-in driver bfusb
W: Possible missing firmware /lib/firmware/intel/ibt-12-16.ddc for built-in driv        er btintel
W: Possible missing firmware /lib/firmware/intel/ibt-12-16.sfi for built-in driv        er btintel
W: Possible missing firmware /lib/firmware/intel/ibt-11-5.ddc for built-in drive        r btintel
W: Possible missing firmware /lib/firmware/intel/ibt-11-5.sfi for built-in drive        r btintel
W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built-        in driver btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built-        in driver btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8688.bin for built-in driver b        tmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8688_helper.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw_v2.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_config.bin for buil        t-in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723a_fw.bin for built-in d        river btrtl
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.11.4-edge-rockchip
Image Name:   uInitrd
Created:      Tue Oct 22 21:03:27 2024
Image Type:   ARM Linux RAMDisk Image (gzip compressed)
Data Size:    14944180 Bytes = 14593.93 KiB = 14.25 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.11.4-edge-rockchip to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.11.4-edge-rockchip'
update-initramfs: Armbian: done.
Armbian: update last-installed kernel symlink to 'zImage'...
'/boot/zImage' -> 'vmlinuz-6.11.4-edge-rockchip'
Armbian: Debian compat: linux-update-symlinks install 6.11.4-edge-rockchip boot/vmlinuz-6.11.4-edge-rockchip
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' finishing.
@going
Im trying a method on the armbian forum as follows.
I made the line bold that I should change to my version where can I find out.
4. For the USB dongle with RTL8188FTV :
git clone https://github.com/kelebek333/rtl8188fu.git
cd rtl8188fu
we need to change some EXTRA_CFLAGS too and I think it is self explanatory, just add the missing lines, remove #:
nano Makefile
EXTRA_CFLAGS += -Wno-error=incompatible-pointer-types
EXTRA_CFLAGS += -Wno-incompatible-pointer-types
EXTRA_CFLAGS += -Wno-vla
EXTRA_CFLAGS += -Wno-error=date-time
(exit with ctrl+x)
And now second difference form post above - we use different image so we have lib/modules/5.3.0-aml-g12 but we can use uname -r
make ARCH=arm64 KSRC=../Amlogic_s905-kernel CONFIG_POWER_SAVING=n
sudo install -p -m 644 rtl8188fu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
/sbin/depmod -a
sudo modprobe rtl8188fu
@going
we have done it finally.
wlx00e0372f872e: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.141  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::5acf:cb45:6c14:ce63  prefixlen 64  scopeid 0x20<link>
        ether 00:e0:37:2f:87:2e  txqueuelen 1000  (Ethernet)
        RX packets 100  bytes 14923 (14.9 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 112  bytes 11935 (11.9 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Dont know what it was but when i used nmuti I saw my wifi and network.
thank you soooo much im very happy now.
now if I can only restore android back to this box i still dont know how to convert the gz file to a img i managed to decompress it folder is showing 7.8gig so that I can install arbian on a mxq box because it has more usb ports
again thannnnnnkkk youuuuuuu for all the patience
@going
okay small problem but not that big
everytime after shut down or reboot it disconnects the wifi and i need to connect again with nmuti how can I set it so it always connects and I dont have to do it manually because now I have to plug in the lan the connect wifi and can then remove the lan
@going
okay deeper in the disconnecting
to get wifi again if i reboot or shut down I need to plug in the lan cable remove usb the wifi is back up I tried by only removing the usb and plug it back in with out lan cable but then still no wifi its as if i need to add the lan cable then remove dongle then reinsert to get wifi back.
I however don't need to go in to nmuti to connect again.
13 часов назад, JOHAN VAN DER MERWE сказал:
There are several ways to force a WIFI-USB device to be detected in the OS.
You can write and add a node to the DTS. That is, to use an overlay.
You can write a rule and add it to the initialization scripts.
Or a combination of these methods.
Please reach out to people who have already succeeded in this.
There are publications on this topic here on the forum.
