atp update changed kernel from 6.10.6-current-rockchip-rk3588 to 6.1.75-vendor-rk35xx and failed
Go to solution Solved by robnielsen,
How can I recover from this? I haven't rebooted:
    _             _    _
   /_\  _ _ _ __ | |__(_)__ _ _ _
  / _ \| '_| '  \| '_ \ / _` | ' \
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|
 v24.8.4 for Orange Pi 5 running Armbian Linux 6.10.6-current-rockchip-rk3588
 Packages:     Debian stable (bookworm)
 IP addresses: (LAN) 192.168.1.2 10.8.0.1 (WAN) xxx.xxx.xxx.xxx
 Performance:
 Load:         1%               Up time:       21 days 23:00
 Memory usage: 10% of 15.35G
 CPU temp:     41°C             Usage of /:    21% of 233G
 Tips:
 Support our work and become a sponsor https://github.com/sponsors/armbian
 Commands:
 System config  : sudo armbian-config
 System monitor : htop
Last login: Tue Oct 15 13:16:59 2024 from 192.168.1.28
rob@orangepi5:~$ sudo apt update
[sudo] password for rob:
Hit:1 http://deb.debian.org/debian bookworm InRelease
Get:2 http://security.debian.org bookworm-security InRelease [48.0 kB]
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:5 http://deb.debian.org/debian bookworm-backports InRelease [59.0 kB]
Get:6 https://packages.adoptium.net/artifactory/deb bookworm InRelease [7,517 B]
Get:4 http://mirrors.jevincanders.net/armbian/apt bookworm InRelease [53.3 kB]
Get:7 http://security.debian.org bookworm-security/main arm64 Packages [186 kB]
Get:8 http://security.debian.org bookworm-security/main armhf Packages [186 kB]
Get:9 http://deb.debian.org/debian bookworm-backports/main arm64 Packages.diff/Index [63.3 kB]
Get:10 http://deb.debian.org/debian bookworm-backports/main armhf Packages.diff/Index [63.3 kB]
Get:11 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb).diff/Index [63.6 kB]
Get:12 http://deb.debian.org/debian bookworm-backports/main all Contents (deb).diff/Index [63.6 kB]
Get:13 http://deb.debian.org/debian bookworm-backports/main armhf Contents (deb).diff/Index [63.6 kB]
Get:14 http://deb.debian.org/debian bookworm-backports/main arm64 Packages T-2024-10-21-1409.06-F-2024-10-15-2009.57.pdiff [11.0 kB]
Get:15 http://mirrors.jevincanders.net/armbian/apt bookworm/main all Packages [13.5 kB]
Get:16 http://mirrors.jevincanders.net/armbian/apt bookworm/main armhf Packages [345 kB]
Get:17 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 Packages [935 kB]
Get:18 http://deb.debian.org/debian bookworm-backports/main armhf Packages T-2024-10-21-1409.06-F-2024-10-15-2009.57.pdiff [10.9 kB]
Get:19 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 Contents (deb) [14.9 MB]
Get:20 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) T-2024-10-19-0204.47-F-2024-10-15-2009.57.pdiff [265 B]
Get:21 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-utils arm64 Packages [22.6 kB]
Get:22 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-utils armhf Packages [52.5 kB]
Get:23 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-utils arm64 Contents (deb) [28.4 kB]
Get:24 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-utils armhf Contents (deb) [24.7 kB]
Get:25 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop armhf Packages [10.2 kB]
Get:26 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop all Packages [5,802 B]
Get:27 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop arm64 Packages [9,992 B]
Get:28 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop armhf Contents (deb) [29.4 kB]
Get:29 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop all Contents (deb) [1,309 B]
Get:30 http://mirrors.jevincanders.net/armbian/apt bookworm/bookworm-desktop arm64 Contents (deb) [29.4 kB]
Get:31 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) T-2024-10-21-1409.06-F-2024-10-15-2009.57.pdiff [5,774 B]
Get:32 http://deb.debian.org/debian bookworm-backports/main armhf Contents (deb) T-2024-10-19-0204.47-F-2024-10-15-2009.57.pdiff [263 B]
Fetched 17.3 MB in 7s (2,576 kB/s)
Reading package lists... Done
Building dependency tree... Done
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
rob@orangepi5:~$ sudo apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-config armbian-firmware armbian-plymouth-theme armbian-zsh linux-dtb-vendor-rk35xx linux-image-vendor-rk35xx
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 138 MB of archives.
After this operation, 15.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://armbian.tnahosting.net/apt bookworm/main arm64 armbian-config all 24.8.4 [136 kB]
Get:6 http://armbian.chi.auroradev.org/apt bookworm/main arm64 linux-image-vendor-rk35xx arm64 24.8.4 [32.6 MB]
Get:2 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 armbian-firmware all 24.8.4 [91.6 MB]
Get:3 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 armbian-plymouth-theme all 24.8.4 [108 kB]
Get:4 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 armbian-zsh all 24.8.4 [11.8 MB]
Get:5 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 linux-dtb-vendor-rk35xx arm64 24.8.4 [2,135 kB]
Fetched 138 MB in 3s (44.6 MB/s)
(Reading database ... 109457 files and directories currently installed.)
Preparing to unpack .../0-armbian-config_24.8.4_all.deb ...
Unpacking armbian-config (24.8.4) over (24.8.3) ...
Preparing to unpack .../1-armbian-firmware_24.8.4_all.deb ...
Unpacking armbian-firmware (24.8.4) over (24.8.3) ...
Preparing to unpack .../2-armbian-plymouth-theme_24.8.4_all.deb ...
Unpacking armbian-plymouth-theme (24.8.4) over (24.8.3) ...
Preparing to unpack .../3-armbian-zsh_24.8.4_all.deb ...
Unpacking armbian-zsh (24.8.4) over (24.8.3) ...
Preparing to unpack .../4-linux-dtb-vendor-rk35xx_24.8.4_arm64.deb ...
Armbian 'linux-dtb-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'preinst' starting.
Armbian 'linux-dtb-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'preinst' finishing.
Unpacking linux-dtb-vendor-rk35xx (24.8.4) over (24.8.2) ...
Preparing to unpack .../5-linux-image-vendor-rk35xx_24.8.4_arm64.deb ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'prerm' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'prerm' finishing.
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'preinst' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'preinst' finishing.
Unpacking linux-image-vendor-rk35xx (24.8.4) over (24.8.2) ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postrm' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postrm' finishing.
Setting up linux-dtb-vendor-rk35xx (24.8.4) ...
Armbian 'linux-dtb-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postinst' starting.
Armbian: DTB: FAT32: moving /boot/dtb-6.1.75-vendor-rk35xx to /boot/dtb ...
renamed 'dtb-6.1.75-vendor-rk35xx' -> 'dtb'
Armbian 'linux-dtb-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postinst' finishing.
Setting up linux-image-vendor-rk35xx (24.8.4) ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postinst' starting.
dkms: autoinstall for kernel 6.1.75-vendor-rk35xx was skipped since the kernel headers for this kernel do not seem to be installed.
update-initramfs: Generating /boot/initrd.img-6.1.75-vendor-rk35xx
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.1.75-vendor-rk35xx
Image Name:   uInitrd
Created:      Tue Oct 22 06:34:02 2024
Data Size:    16110316 Bytes = 15732.73 KiB = 15.36 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.1.75-vendor-rk35xx to /boot/uInitrd
ln: failed to create symbolic link '/boot/uInitrd': Operation not permitted
update-initramfs: Symlink failed, moving /boot/uInitrd-6.1.75-vendor-rk35xx to /boot/uInitrd
renamed '/boot/uInitrd-6.1.75-vendor-rk35xx' -> '/boot/uInitrd'
update-initramfs: Armbian: done.
Free space after deleting the package linux-image-vendor-rk35xx in /boot: 78.5M
Armbian: FAT32 /boot: move last-installed kernel to 'Image'...
renamed '/boot/vmlinuz-6.1.75-vendor-rk35xx' -> '/boot/Image'
Armbian 'linux-image-vendor-rk35xx' for '6.1.75-vendor-rk35xx': 'postinst' finishing.
Setting up armbian-zsh (24.8.4) ...
Setting up armbian-config (24.8.4) ...
Setting up armbian-firmware (24.8.4) ...
Setting up armbian-plymouth-theme (24.8.4) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.142+deb12u1) ...
ln: failed to create hard link '/boot/initrd.img-6.10.6-current-rockchip-rk3588.dpkg-bak' => '/boot/initrd.img-6.10.6-current-rockchip-rk3588': Operation not permitted
update-initramfs: Generating /boot/initrd.img-6.10.6-current-rockchip-rk3588
grep: /boot/config-6.10.6-current-rockchip-rk3588: No such file or directory
E: gzip compression (CONFIG_RD_GZIP) not supported by kernel
update-initramfs: failed for /boot/initrd.img-6.10.6-current-rockchip-rk3588 with 1.
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
rob@orangepi5:~$ ls -l /boot
total 104816
-rwxr-xr-x 1 root root      213 Sep 30 07:31 armbianEnv.txt
-rwxr-xr-x 1 root root     3404 Feb 18  2023 boot.cmd
-rwxr-xr-x 1 root root     3476 Feb 18  2023 boot.scr
-rwxr-xr-x 1 root root   244731 Oct 18 04:11 config-6.1.75-vendor-rk35xx
drwxr-xr-x 3 root root     4096 Oct 22 06:33 dtb
-rwxr-xr-x 1 root root 39152128 Oct 18 04:11 Image
-rwxr-xr-x 1 root root 28272711 Sep 30 07:29 initrd.img-6.10.6-current-rockchip-rk3588
-rwxr-xr-x 1 root root 16110316 Oct 22 06:34 initrd.img-6.1.75-vendor-rk35xx
-rwxr-xr-x 1 root root  7371703 Oct 18 04:11 System.map-6.1.75-vendor-rk35xx
-rwxr-xr-x 1 root root 16110380 Oct 22 06:34 uInitrd
rob@orangepi5:~$
  • Solution
I was able to recover. Here's what I did:
  1. copied /boot/config-6.1.75-vendor-rk35xx  to /boot/config-6.10.6-current-rockchip-rk3588 and was able to get apt upgrade to complete successfully.
  2. ran sudo apt list --installed | egrep "linux-dtb|linux-image" used apt remove to removed the packages listed except for linux-dtb-current-rockchip-rk3588 linux-image-current-rockchip-rk3588
  3. ran sudo apt install --reinstall linux-dtb-current-rockchip-rk3588 linux-image-current-rockchip-rk3588 to reinstall both packages
  4. froze Armbian kernel upgrades in armbian-config
  5. rebooted
I installed this kernel on a Rock 5B. Although the above fixed the issue for the original poster the failure of configure stage is not addressed. I think there is something wrong with this kernel. On my Home Assistant server some containers were failing to start and the errors pointed towards some resource/limits issue even for processes running as root. The errors were something like - fork failed, resource temporarily not available.
I think update-initramfs ran into this issue producing the errors in the post.
I don't have any logs since it has hard to do anything at this point, commands failing when trying to diagnose. I rolled back to 5.10 manually to get my server up and running.
I think the maximum number of processes was being limited artificially low despite nothing being in /etc/security/limits* - I did see for not root users this limited to around 2k processes via ulimit -u - cant remember the exact number.
If anyone is running this kernel you can check the limits for various processes - user and root alike by looking at /proc/<PID>/limits On my rolled back 5.10 legacy kernel this is 61790
I upgraded to 6.1.75-vendor-rk35xx and now my m2 ssd is not recognized anymore and the system is unresponsive and unstable. Once I remove the ssd, I am able to use it again.
I tried to revert to a previous kernel using armbian-config but that didn't work.
How can I revert back to 6.1.43?
Here's how I reverted back to an older kernel:
sudo apt install linux-dtb-vendor-rk35xx=24.5.2 linux-image-vendor-rk35xx=24.5.2
sudo reboot
The system is stable again, including pci ssd.
The other issue with the vendor kernels is that the DTB seems to contain every rockchip dtb known - hundreds of them not just rk35xx - the default 256MB boot partition fills up as there is no room to have two kernel/overlay versions
