I would like to create an ubuntu desktop image for a rk3066-based dongle (measy u2a). Is there anything in this website where start from? Or something ready-to-try?
Will the docs here be helpful?
I managed to run armbian on a measy u1a (which has a Allwinner A10) by simply flashing sdcard with an image (Lime A10) found here, I would like to do the same with rk3066.
Thanks,
Antonio
Edited by zador.blood.stained
Moved from Rockchip section since this SoC is not supported
Here you can't find anything about that SoC.
Are you Spanish or Spanish speaker?
The RK3066 can run Picuntu ubuntu versión and can be uptated til Ubuntu 14.04
Here you can find a lot of information
https://raspberryparatorpes.net/tag/picuntu/
including the instructions to install the bootloader inside the Recovery partition and run Ubuntu from a microSD card.
Here the final step to run headless and links to all the process
https://raspberryparatorpes.net/instalacion/picuntu-en-modo-headless-sin-monitor/
Regards
