ag123 Posted February 24 Posted February 24 I think rotation is managed by some LCD commands, see MADCTL in the datasheet. https://www.hpinfotech.ro/ILI9488.pdf so the driver probably needs to implement it to have rotation 0 Quote
Solution WDR_s Posted February 25 Author Solution Posted February 25 LCD and Touch working 😊 All that's left is to calibrate it, but it's working normally. Thank you, robertoj, for helping me so far. Updated DTS Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 5 0>,<&pio 2 15 0>; /*PH5=CS0 for lcd, PC15=CS1 for touch*/ display: display@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <20000000>; rotate = <270>; bgr = <0>; fps = <30>; buswidth = <8>; regwidth = <16>; height = <480>; width = <320>; reset-gpios = <&pio 2 14 1>; /* PC14 */ dc-gpios = <&pio 2 6 0>; /* PC6 */ debug = <3>; init = <0x10000b0 0x00 // Interface Mode Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x10000C0 0x0D 0x0D // Power Control 1 0x10000C1 0x43 // Power Control 2 0x10000C5 0x00 0x48 0x80 // VCOM Control 1 0x10000C7 0x00 // VCOM Control 2 0x1000036 0x28 // Memory Access Control (Rotação) 0x100003A 0x55 // Pixel Format Set (16bit) 0x10000B1 0xB0 0x11 // Frame Rate Control 0x10000F0 0x01 // Enable Extended Comand Set 0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control 0x1000026 0x01 // Gamma Set 0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00 // Positive Gamma Correction 0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F // Negative Gamma Correction 0x10000B6 0x02 0x02 0x3B // Display Function Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x1000029>; // Display ON }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; /* PC10 - IRQ */ pendown-gpio = <&pio 2 10 1>; /* PC10 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; 0 Quote
WDR_s Posted February 25 Author Posted February 25 running directly on the board, the LCD and Touch, in this dts: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 5 0>,<&pio 2 10 0>; /*PH5=CS0 for lcd, PC10=CS1 for touch*/ display: display@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <20000000>; rotate = <270>; bgr = <0>; fps = <30>; buswidth = <8>; regwidth = <16>; height = <480>; width = <320>; reset-gpios = <&pio 2 7 1>; /* PC7 */ dc-gpios = <&pio 2 14 0>; /* PC14 */ debug = <3>; init = <0x10000b0 0x00 // Interface Mode Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x10000C0 0x0D 0x0D // Power Control 1 0x10000C1 0x43 // Power Control 2 0x10000C5 0x00 0x48 0x80 // VCOM Control 1 0x10000C7 0x00 // VCOM Control 2 0x1000036 0x28 // Memory Access Control (Rotação) 0x100003A 0x55 // Pixel Format Set (16bit) 0x10000B1 0xB0 0x11 // Frame Rate Control 0x10000F0 0x01 // Enable Extended Comand Set 0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control 0x1000026 0x01 // Gamma Set 0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00 // Positive Gamma Correction 0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F // Negative Gamma Correction 0x10000B6 0x02 0x02 0x3B // Display Function Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x1000029>; // Display ON }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 6 2>; /* PC6 - IRQ */ pendown-gpio = <&pio 2 6 1>; /* PC6 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; 0 Quote
robertoj Posted February 25 Posted February 25 Nicely done!! How are you going to use it? X11? Wayland? What window manger and desktop? Is your mouse cursor jumpy or stable? Is there RGB noise when you drag windows on the desktop? I have those issues. My setup: orange pi zero3, ili9488, drm, x11, openbox and idesk. I wonder if my problem comes from sharing the SPI bus with 2 chip selects... but if you have one SPI and 2 chip selects, but no noise problems, then SPI is not my problem. 0 Quote
WDR_s Posted February 26 Author Posted February 26 i installed xfce to test the touch, the touch is stable when dragging the window there is a noise, but i think it's because of the frequency. maybe I can help you. 0 Quote
robertoj Posted February 26 Posted February 26 Do you use x11's evdev component? Does it make any difference of stability before and after running xcalibrate/xinput_calibrator? I find that xinput_calibrator does not do anything toward pressure sensitivity. I need to make it less sensitive... anyone knows a good way of doing this? 0 Quote
WDR_s Posted February 27 Author Posted February 27 I also felt that xinput_calibration didn't change anything. I was configuring it here, because the touch didn't reach the corner of the LCD and it was stable, but now it's shaking too, but now the touch reaches the corner of the screen. So it's probably just the settings, I'll see if I can sort it out. 0 Quote
robertoj Posted February 27 Posted February 27 For touch calibration, the straighforward intuitive way does not work. Try this procedure: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204741 The copy location /etc/X11/xorg.conf.d/ might be different. The xinput calibration text output will tell you that directory. The DTS also has some pressure and resistivity parameters, but I don't know how they work exactly. 0 Quote
robertoj Posted March 4 Posted March 4 My 60 MHz SPI connection is 1 m long, the cable was made with a CAT5 ethernet cable. The problem was reduced by making a 50 cm cable. Maybe I need termination resistors too. I could start with 1000ohms between MOSI and GND in the LCD wire ends. If it doesn't work, reduce the resistance, until I don't see noise. 0 Quote
robertoj Posted March 27 Posted March 27 (edited) i dont know if this is new, but i see a ili9486 driver in the kernel config, which is unselected by default. Warning.... I just looked at some of the code in the linux mailing list discussion, and it looks like it is made specifically for 2 raspberry LCD hats * PISCREEN 3.5" 320x480 TFT (Ozzmaker 3.5") * RPILCD 3.5" 320x480 TFT (Waveshare 3.5") Which have a SPI->parallel chip on the circuitboard https://patchwork.kernel.org/project/dri-devel/patch/eb5672abbdb89d7018793c76d7193bfb78a2ea88.1580059987.git.kamlesh.gurudasani@gmail.com/ WDR_s: are you still having good experience with the ili9341 driver for the ili9486 LCD? Edited March 27 by robertoj 0 Quote
WDR_s Posted Wednesday at 05:57 AM Author Posted Wednesday at 05:57 AM (edited) I was missing because I was testing the ili9486. So, I used the conversion from ili9341 to ili9486, for a while and it worked well, however, it was slow because it did not support more than 21mhz, so I tried to make the ili9486 work, after a few days I managed to make it work, but I had to disable the “dma-names” because it was making the screen not update, I am now using the ili9486 at 48mhz, working well. I'm using the LCD directly on the board. Edited Wednesday at 06:28 AM by WDR_s 0 Quote
robertoj Posted Wednesday at 09:36 AM Posted Wednesday at 09:36 AM Thank you... that is what I need: a 480x320 LCD that works with a driver other than panel-mipi-dbi Do you keep having problems with cursor shakiness? Any screen redraw "garble"? 0 Quote
WDR_s Posted Thursday at 12:38 AM Author Posted Thursday at 12:38 AM my dts for reference: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; dma-names = ""; cs-gpios = <&pio 7 9 0>,<&pio 2 10 0>; /*PH9=CS0 for lcd, PC15=CS1 for touch*/ ili9486: ili9486@0 { compatible = "waveshare,rpi-lcd-35"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <46000000>; rotate = <270>; bgr = <0>; fps = <30>; buswidth = <8>; reset-gpios = <&pio 2 7 0>; /* PC7 */ dc-gpios = <&pio 2 14 0>; /* PC14 */ debug = <3>; }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 6 2>; /* PC6 - IRQ */ pendown-gpio = <&pio 2 6 1>; /* PC6 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; ti,invert-x = <0>; ti,invert-y = <1>; }; }; }; }; my touch is still shaking, but I was focusing on the lcd, I'll try the touch later. 0 Quote
robertoj Posted 11 hours ago Posted 11 hours ago It is too bad that the cursor is shaking even if the driver panel-mipi-dbi is not used.... Now I have a feeling that using a separate software SPI for touch would be the best solution. 0 Quote
