Orima Posted December 9, 2025 Posted December 9, 2025 @robertoj Thank you very much for your reply! I sincerely apologize for any misunderstanding. When I mentioned the 16-bit option, I was referring to the selection made when setting up the Armbian image. This option is located in the same menu as the mipi_panel_dbi support option. I mentioned this in my comment because I was a bit confused by the "but the greeter is not" part of your response. I probably just needed to enable the mipi_panel_dbi support parameter and continue building without adding any additional parameters. I use a screen with a red board on the ili9488 driver, the Chinese version for sure. I'd also like to clarify with someone who's already done this, whether I'm following all the steps correctly. If that's possible, please let me know within this forum thread. - I'm building a minimal image. - First, I use the DTS file from the thread you provided as a response. - After I see the image on the screen, if the colors are incorrect, I use the file provided by Pancake. Please forgive me again. In the thread you provided as a solution, I don't understand the sequence of actions and where I should start. Once again, I apologize for my meticulousness. 0 Quote
robertoj Posted December 9, 2025 Posted December 9, 2025 (edited) Yes, that is the correct sequence of actions: 1. Build armbian minimal with panel-mipi-dbi kernel module 2. Use DTS so that the kernel links the GPIO, SPI to the panel-mipi-dbi kernel module 3. Use the bin file (originally provided by Kungfu pancake) <-mandatory, not optional 4. If you see console text successfully in the LCD during boot, you have successfully installed your LCD 5. Tell us here, for the next step in GUI installation The "greeter" is the graphical login screen. Labwc is the wayland-based compositor and window manager (I think). Edited December 9, 2025 by robertoj 0 Quote
Orima Posted December 12, 2025 Posted December 12, 2025 Hi I was able to build an image with the panel-mipi-dbi module enabled. My previous image had the module disabled, so it took me a couple of days to figure it out. As I found out, for my version of the board, which uses the 618 chip, I needed to adjust a line in the bootconfig to build my board. It specified the 616 chip. But that's probably not the reason for the success. After I built the image, applied the binary, and dts, the screen was still white after rebooting. user@orangepizero3:~/v0_ips_touch_display$ cd user@orangepizero3:~$ sudo modinfo panel-mipi-dbi filename: /lib/modules/6.16.8-edge-sunxi64/kernel/drivers/gpu/drm/tiny/panel-mipi-dbi.ko license: GPL author: Noralf Trønnes description: MIPI DBI compatible display panel driver alias: of:N*T*Cpanel-mipi-dbi-spiC* alias: of:N*T*Cpanel-mipi-dbi-spi alias: spi:panel-mipi-dbi-spi depends: drm_mipi_dbi,backlight intree: Y name: panel_mipi_dbi vermagic: 6.16.8-edge-sunxi64 SMP preempt mod_unload aarch64 user@orangepizero3:~$ dmesg | grep spi [ 2.466658] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 2.467167] sun6i-spi 5011000.spi: cannot register SPI host [ 2.474140] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 2.474558] sun6i-spi 5011000.spi: cannot register SPI host [ 3.584770] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 3.603713] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 3.603960] panel-mipi-dbi-spi spi1.0: Direct firmware load for panel-mipi-dbi-spi.bin failed with error -2 [ 3.603975] panel-mipi-dbi-spi spi1.0: No config file found for compatible 'panel-mipi-dbi-spi' (error=-2) [ 3.603983] panel-mipi-dbi-spi spi1.0: probe with driver panel-mipi-dbi-spi failed with error -2 [ 12.001666] OF: /soc/spi@5011000/ads7846@1: Read of boolean property 'ti,swap-xy' with a value. [ 12.001860] ads7846 spi1.1: supply vcc not found, using dummy regulator [ 12.004761] ads7846 spi1.1: touchscreen, irq 77 [ 12.007680] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input10 [ 12.018707] spi-nor spi0.0: supply vcc not found, using dummy regulator [ 12.018953] spi-nor spi0.0: supply vdd not found, using dummy regulator 0 Quote
robertoj Posted December 15, 2025 Posted December 15, 2025 Can you clarify that you made a custom H618 board ?? (not exactly Orange Pi Zero 3?). If I remember correctly, you had previous success with an ili9341 and the same linux board? You need to compare the DTS that worked for you (with ilitek, ili9341, right?) and the new DTS you are trying to modify (with panel-mpi-dbi, for ili9488). Make sure you haven't changed the GPIO in the DTS, and the connections in the LCD and your Linux board. If the ili9341 was working for you with the H616 armbian configuration, changing to H618 might need changes in the LCD DTS from that change.... to make those SPI pins to be addressed correctly. That previous H616 armbian configuration... what Linux board was it meant for? Change back to the configuration that made your board work with the ili9341. 0 Quote
Orima Posted December 15, 2025 Posted December 15, 2025 Good afternoon. Thank you for your reply. Unfortunately, I haven't had a positive experience. My apologies for misleading you, but my motherboard originally had a 618 processor. I tried creating an image for the 616 many times until I noticed that my processor was a 618. After several attempts, I was able to create an image for the 618. After receiving an image for the 618 with the panel-mipi-dbi module, I tried connecting a screen with an ili9488 chip. I can say I've taken the first step toward implementing this project. Now I need to get the screen working with the resulting image. 0 Quote
robertoj Posted December 16, 2025 Posted December 16, 2025 Alright Did you ever make this LCD work with your H618 motherboard, with another kernel driver? 0 Quote
Orima Posted December 16, 2025 Posted December 16, 2025 Sorry, I've never done anything like this before. I tried setting it up according to instructions in various GitHub threads, but it always failed. You're the only person who helps me with advice, and thanks to you, I've only been able to build an image with the required kernel module. I haven't achieved anything else, except for the white screen. 0 Quote
robertoj Posted December 16, 2025 Posted December 16, 2025 Can you get an orange pi zero 3? As a hardware beginner, you need a very stable, well known linux board. 0 Quote
Orima Posted December 17, 2025 Posted December 17, 2025 I was able to get it out. I'm pretty good at Linux, but not at screens. Maybe I'm missing something? 0 Quote
robertoj Posted December 17, 2025 Posted December 17, 2025 All this time, I thought you were using a custom H618 board hardware. Now it is clear to me, that you have an Orange Pi Zero 3, In armbian build, make sure you don't add any configuration files. Just do "./compile.sh" and when you get the menu for board selection, press the button "Unsupported/CSC" (or something like that). The text menu will turn red. Press OK and you will see a list of more Linux boards. Press "P" to quickly scroll down, then "UP" to find Orange Pi Zero 3. Then choose the option for Linux edge, and choose that you want to configure linux. 0 Quote
Orima Posted December 17, 2025 Posted December 17, 2025 Thank you very much for your reply. That's exactly what I did. I have a custom Armbian image. When compiling, I selected my board for the 618 processor, as I couldn't find it in the standard section. I also found the panel-mipi-dbi parameter in the module selection menu. However, after compiling, writing the image to the flash card, and checking the module, the system didn't find it. I was able to build the image and include the module after correcting the boardconfig. It may have mistakenly listed the 616 processor, but I changed it to 618, and the image built successfully. After writing it to a flash drive and checking it in the system, I was finally able to find the required module. It was also displayed in the /boot/config(uname) configuration file. 0 Quote
robertoj Posted December 17, 2025 Posted December 17, 2025 (edited) If you use your own boardconfig file, or edit another boardconfig file, you may be missing some configs or device tree overlay, and make problems in configuring SPI and GPIO pins. I always use boardconfig that's included in armbian-build, specifically for Orange Pi Zero 3, by following the text menu, and not editing any file. Edited December 17, 2025 by robertoj 0 Quote
Orima Posted December 18, 2025 Posted December 18, 2025 I'll try building the image again today with a new git clone, without changing anything except the userpatchers configuration. If I don't add the module this way, it won't be enabled in the text menu. I'll report back on my progress later. 0 Quote
Orima Posted December 20, 2025 Posted December 20, 2025 (edited) I'll try building the image again today with a new git clone, without changing anything except the userpatchers configuration. If I don't add the module this way, it won't be enabled in the text menu. I'll report back on my progress later.I created an image without changing the boardconfig. I used the default configuration for userpatches, which is used for compilation. I added one line, CONFIG_DRM_PANEL_MIPI_DBI=m, and the image built successfully. Afterwards, I booted and checked the kernel module with the command modinfo panel-mipi-dbi; the module is enabled. I also checked the configuration in /boot/config(umane); the module is enabled there too. I added DTS with the command sudo armbian-add-overlay , and also added the binary from the Pancake repo. After rebooting, the result didn't change at all; the screen was white. The output of dmesg | grep spi shows the same as in the previous post. I'm not sure about the pinout. Could you send me your pinout? What awg wires are you using? I use a combination of 28awg for VCC, DC, and GND, and 32awg for the rest. Edited December 20, 2025 by Orima 0 Quote
Orima Posted December 24, 2025 Posted December 24, 2025 @robertoj I apologize, perhaps you missed the message. 0 Quote
Orima Posted January 21 Posted January 21 @robertoj Hello. I was able to get some DuPont wires and test them directly without soldering. The result was zero. I tried using ChatGPT to get it working.He suggests that my display isn't initializing. In some cases, it's either that the reset isn't working, or that the frequency is too high for a Chinese display. I tried using fbtft, but the result was zero. I followed your configuration and pinout. Are there any steps I might have missed? 0 Quote
robertoj Posted January 21 Posted January 21 Is your LCD at least turning white on powerup? Did you connect the "LED" pin in the LCD, to 3.3V? Send a drawing of how you are connecting the LCD to the orange pi zero 3. 0 Quote
Orima Posted January 21 Posted January 21 (edited) @Робертс My screen is constantly white. Here's my wiring diagram. Display-Orangepi zero 3 VCC-5v GND-GND CS-PH9(spi1) RST-PC14 D/C-PC7 SDI-PH7(mosi) SCK-PH4 BL-3.3v SDO-PH8(miso) Also, there might be a typo. The specified dc-gpio in your dts is described as PHC7. I don't quite understand, is it PC7 or PH7? Edited January 21 by Orima 0 Quote
robertoj Posted January 22 Posted January 22 (edited) Yes, that's a typo. The dc (data/command) should be PC7, and the MOSI (LCD's SDI) is PH7 Edited January 22 by robertoj 0 Quote
Orima Posted January 22 Posted January 22 @Робертс I've been following this pinout from the very beginning, but I'm having trouble setting it up. I think I should wait for instructions from you, which you might create. I would be incredibly happy and grateful if you could provide a step-by-step description of the steps for setting up the Chinese ili9488 display and the OrangePi Zero 3 board.Maybe then I will understand where I am making a mistake.Thank you very much for your patience. 0 Quote
robertoj Posted January 22 Posted January 22 Yes. Please wait. I was busy with other personal projects, so I haven't been doing armbian stuff for a few weeks. 1 Quote
Orima Posted 1 hour ago Posted 1 hour ago @robertojGood afternoon. How are you? How is your health? Excuse me, but have you made any progress on writing the manual? 0 Quote
