[Armbian newsletter] - Armbian Weekly Highlights
Dear Armbians, welcome to this weekโ€™s newsletter! Here, youโ€™ll find updates on the latest release and community contributions.
๐Ÿš€ New Additions and Improvements
  1. Raydium Display Compatibility
    • Orientation and Timing Enhancements: Raydium displays now read orientation and timing directly from the DTS (device tree source), improving display support for more consistent visuals. (Contributor: @ginkage)
  2. PWM Fan Fix for RetrOLED CM5
  3. SHELLFMT Tool Upgrade
    • Developer Tooling Update: SHELLFMT_VERSION has been updated from 3.9.0 to 3.10.0, streamlining shell formatting and enforcing a unified style across Armbian projects. (Contributor: @igorpecovnik)
  4. Enhanced GitHub Workflow
    • Automation and Workflow Updates: A new log cleaner, revised naming conventions, and an improved labeling system have been added to GitHub Actions. These refinements streamline the development process for contributors. (Contributor: @igorpecovnik)
๐Ÿ“˜ Documentation and Build System Updates
  1. Boot Configuration Simplification
    • Duplicate Entries Removed: The BOOTPATCHDIR variable was refined to eliminate duplicate entries, leading to a more organized boot process and better maintainability. (Contributor: @mr-toolcraft)
  2. U-Boot Update
    • Mainline U-Boot 2024.10: Switched to the latest mainline U-Boot, incorporating the newest bootloader features for enhanced compatibility across supported boards. (Contributor: @mr-toolcraft)
  3. Kernel Config Synchronization
    • Automatic Config Updates: Kernel configurations are now automatically rewritten to include new updates, ensuring consistency across various Armbian builds. (Contributor: @igorpecovnik)
  4. Linux-UEFI Edge Config Update
    • Configuration Refinement: Updated linux-uefi-arm64-edge.config for improved ARM64 device support under UEFI, enhancing compatibility and user experience. (Contributor: @bmilde)
๐Ÿš  Armbian Config and Board-Specific Updates
  1. User Experience Fix
    • First-Run Warning Correction: A bug causing unsupported userspace warnings on first run has been resolved, leading to a smoother initial setup experience. (Contributor: @igorpecovnik)
  2. Automatic Board Config Synchronization
  3. OnePlus Kebab Edge Build Adjustment
    • Edge Build Disabled: The edge build for OnePlus Kebab has been disabled to improve stability and optimize resource allocation. (Contributor: @amazingfate)
  4. RK3576 Boot Improvements
    • Switch to boot.scr: Booting on the RK3576 platform has been updated to use boot.scr instead of extlinux, and an additional boot fix has been applied, resolving previous booting issues. (Contributor: @amazingfate)
Join the Armbian Community
Armbian thrives on community involvement. Your contributions are essential to the ongoing development and success of Armbian. Whether youโ€™re interested in development, documentation, testing, or other areas, we welcome your support.
Thank you for being a part of Armbian!
The Armbian Team
The post Armbian Weekly Highlights first appeared on Armbian.
View the full article
  • Igor pinned this topic
  • Igor unpinned this topic
ร—
ร—
