My STB run latest Armbian from ophub Armbian_24.11.0_amlogic_s905x3_noble_6.6.58_server_2024.11.01.img.gz. it run on microsd with change the dtb file location in uEnv. But i made mistake with remove partition on eMMC and format it to BTRFS. Now my box is just bootlop.
I try to recover using USB Burning Tool with oem Firmware but it always end with romcode error. I Try using TWRP with boot maker it can enter TWRP. i need to press the toothpick on AV jack. When i try to install the oem Firmware it say that emmc is 0mb. I try to change the file system with advance wipe option but got error that the storage can not mount. I guess the TWRP not recognize the BTRFS.
Is there any way to boot using microsd with something like TWRP Recovery but can recognize the eMMC?
2 hours ago, benidiktus kurniawan said:
ophub
You are not using Armbian. You are using a fork that uses the name Armbian without permission. They do not participate in the core development process and trick you inkt thinking you'd get some sort of support at official place (here to say). Ask for help where you got the image from.
  • Werner locked this topic
