It was the only image I could get working. The 25.02 doesn't boot, the older versions from the archive 23.8.1 don't work either for some reason. Unfortunately I deleted the image and the rolling release moved on to 25.02.
I understand that, it's just that the release from 3 weeks ago: 24.11.0-trunk.351 was working fine on the jetson nano. I just deleted the image and upgraded to 25.02 by accident. So I was wondering, if someone still had an image saved somewhere.
Thank you for the github release link Igor, and bringing attention to the issue ArmOnJetson!   Using 24.11.0-trunk.351 also solved my boot issue (originally I tried with 25.5.0 -- which was leading to a black screen after the Nvidia logo).
Can I still find the image somewhere? I would like to run Armbian on my Jetson Nano 2 GB, but
Armbian_community_25.11.0-trunk.367_Jetson-nano_trixie_current_6.12.54_minimal.img
 and older images won't boot. I have tried images repeatedly over the past six weeks, but none of them will boot.
It would be a shame if the Jetson Nano 2 GB ended up as electronic waste.
Well, the source code is still on github so you could try building it.
I can't find that tag in `armbian/build`, but did find `v24.11.0-trunk.303`
It does build [I guessed at jammy, maybe it should be noble]
time ./compile.sh build BOARD=jetson-nano BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes RELEASE=jammy KERNEL_CONFIGURE=no KERNEL_GIT=full ARTIFACT_IGNORE_CACHE=yes
[🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img (4.07GiB) ]
[🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img.sha (202.00B) ]
[🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img.txt (19.29KiB) ]
