Mike R9FT Posted July 22, 2017 Posted July 22, 2017 Hi I connect 7" hdmi display from waveshare to orange pi one on mainline dev kernel. http://www.waveshare.com/wiki/7inch_HDMI_LCD When it is powered before orange, it works ok. But it don't work if it is powered at the same time. I am tried to add hpd_delay at the top of boot.cmd: setenv video-mode sunxi:1024x768-24@60,monitor=hdmi,hpd=1,hpd_delay=20000,edid=1 saveenv the do mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr But still no lack, display shows "no cable connected" Also when board start up, u-boot show on serial console this if display powered up before board: CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 In: serial Out: vidconsole Err: vidconsole And this if display powered same time with board: CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 In: serial Out: serial Err: serial How can I debug this? Also I tried another 5" hdmi display, that is working correctly (it have another hdmi chip, so it starts more quickly)
jernej Posted July 22, 2017 Posted July 22, 2017 Actually you can't do much except patch U-Boot. H3 and newer chips uses driver in U-Boot which doesn't consider video-mode variable. Since kernel relies on U-Boot to set up HDMI for now, the only thing you can do is to create U-Boot patch and rebuild the image on your own. You only need to change line 131. 1
Mike R9FT Posted July 22, 2017 Author Posted July 22, 2017 Thank you. It is working now with this patch: diff --git a/drivers/video/sunxi/sunxi_dw_hdmi.c b/drivers/video/sunxi/sunxi_dw_hdmi.c index 33920a2..9ae547a 100644 --- a/drivers/video/sunxi/sunxi_dw_hdmi.c +++ b/drivers/video/sunxi/sunxi_dw_hdmi.c @@ -122,13 +122,14 @@ static int sunxi_dw_hdmi_get_plug_in_status(void) static int sunxi_dw_hdmi_wait_for_hpd(void) { ulong start; + mdelay(3000); start = get_timer(0); do { if (sunxi_dw_hdmi_get_plug_in_status()) return 0; udelay(100); - } while (get_timer(start) < 300); + } while (get_timer(start) < 5000); return -1; } Is it possible to set timeouts from environment variable?
Mike R9FT Posted July 22, 2017 Author Posted July 22, 2017 Touch screen is also working with following tune up sun8i-h3-spi-ads7846.dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { ads7846_pins: ads7846_pins { pins= "PA2"; function = "irq"; }; }; }; fragment@1 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; ads7846@0 { compatible = "ti,ads7846"; reg = <1>; /* Chip Select 0 */ status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ads7846_pins>; spi-max-frequency = <500000>; interrupt-parent = <&pio>; interrupts = <0 2 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */ pendown-gpio = <&pio 0 2 0>; /* PA7 */ /* driver defaults, optional */ ti,x-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <4095>; ti,y-min = /bits/ 16 <0>; ti,y-max = /bits/ 16 <4095>; ti,swap-xy = <1>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <255>; /* ti,x-plate-ohms = /bits/ 16 <180>; */ ti,x-plate-ohms = /bits/ 16 <100>; ti,debounce_max = /bits/ 16 <15000>; ti,debounce_tol = /bits/ 16 <65535>; ti,debounce_rep = /bits/ 16 <100>; ti,vref-delay-usecs = /bits/ 16 <450>; ti,keep_vref_on = <1>; ti,settle_delay_usecs = /bits/ 16 <100>; ti,penirq-recheck-delay-usecs = /bits/ 16 <100>; }; }; }; }; /etc/X11/xorg.conf.d/99-calibr.conf Section "InputClass" Identifier "calibration" MatchProduct "ADS7846 Touchscreen" Option "Calibration" "154 3975 3933 66" Option "SwapAxes" "0" EndSection
jernej Posted July 22, 2017 Posted July 22, 2017 2 minutes ago, Mike R9FT said: Is it possible to get it from environment variable? Of course, consider following line in drivers/video/videomodes.c char *p = getenv("video-mode"); Please note that video drivers are loaded very quickly, before U-Boot command line, so variable has to exist before. This can be achieved by setting variable and save it with "saveenv" command.
