gene1934 Posted November 28, 2024 Posted November 28, 2024 uptodated today, jammy on bpi-m5 running 3d printer with klipper etc. With snapd frozen, so is firefox. possible fix? passwd f-u, I am that other contributing member but finally got it reset. 0 Quote
gene1934 Posted November 28, 2024 Author Posted November 28, 2024 looks like the github key has changed how do I refresh it? 0 Quote
Igor Posted November 28, 2024 Posted November 28, 2024 23 minutes ago, gene1934 said: looks like the github key has changed how do I refresh it? Not with Armbian. Please provide logs. 0 Quote
gene1934 Posted November 28, 2024 Author Posted November 28, 2024 gene@bpi51e5p:~/kiauh-master$ sudo apt list --upgradable Listing... Done snapd/jammy-updates 2.66.1+22.04 arm64 [upgradable from: 2.65.3+22.04] thunderbird/jammy 9:128.5.0+build1-0ubuntu0.22.04.1~mt1armbian1 arm64 [upgradable from: 9:128.4.4+build1-0ubuntu0.22.04.1~mt1armbian1] 0 Quote
gene1934 Posted November 28, 2024 Author Posted November 28, 2024 Err:1 https://cli.github.com/packages stable InRelease The following signatures were invalid: EXPKEYSIG 23F3D4EA75716059 GitHub CLI <opensource+cli@github.com> 0 Quote
Igor Posted November 28, 2024 Posted November 28, 2024 14 minutes ago, gene1934 said: Err:1 https://cli.github.com/packages stable InRelease The following signatures were invalid: EXPKEYSIG 23F3D4EA75716059 GitHub CLI <opensource+cli@github.com> This package is hosted at our repository, you can delete the list: sudo rm -f /etc/apt/sources.list.d/githubcli.list For the Firefox, I have to check. Our package should be snapd free. Perhaps try to uninstall firefox, remove snapd and install firefox again (should be downloaded from armbian repo). 0 Quote
gene1934 Posted November 29, 2024 Author Posted November 29, 2024 I'll give that a shot after the weekend when the current new dirt addition to this printer should be working. Right now I'm torture testing the relay that will control the motor driver, waiting on Amazon to deliver some 30 amp 50 volt schotkey's to make a flywheel diode. Otherwise the back emf fry's the bugs in a 300 watt buck kit at turnoff time, that limits the start up currant to something the OEM 24 volt supply can handle. I am a 90 yo, long retired CET, we teach EE's stuff their profs didn't but getting rusty now. Thanks Igor. 0 Quote
gene1934 Posted November 29, 2024 Author Posted November 29, 2024 its my understanding that both fire-fox and t-bird are only snaps these days. Being a little paranoid, I didn't delete that file but renamed it to .last which apt barked about but didn't use. then the usual reload & full-upgrade procedure replaced both snapd and t-bird. t-bird I could probably remove as that is a printer and has never sent/received an email. My network does not disallow that as all other net stuff still works. Firefox apparently has its own update mechanim, all I need to do is stop it for an hour or so, and get the new version when it announces its availability in the upper right corner of its workspace. Thank you Igor. 0 Quote
gene1934 Posted November 29, 2024 Author Posted November 29, 2024 I assume this was the expected result: Preparing to unpack .../snapd_2.66.1+22.04_arm64.deb ... Unpacking snapd (2.66.1+22.04) over (2.65.3+22.04) ... Preparing to unpack .../thunderbird_9%3a128.5.0+build1-0ubuntu0.22.04.1~mt1armbian1_arm64.deb ... Unpacking thunderbird (9:128.5.0+build1-0ubuntu0.22.04.1~mt1armbian1) over (9:128.4.4+build1-0ubuntu0.22.04.1~mt1armbian1) ... Setting up snapd (2.66.1+22.04) ... snapd.failure.service is a disabled or a static unit not running, not starting it. snapd.snap-repair.service is a disabled or a static unit not running, not starting it. Setting up thunderbird (9:128.5.0+build1-0ubuntu0.22.04.1~mt1armbian1) ... plz advise it not. Thanks Igor. 0 Quote
Igor Posted November 29, 2024 Posted November 29, 2024 10 hours ago, gene1934 said: ts my understanding that both fire-fox and t-bird are only snaps these days. By default, with Ubuntu, yes, with Armbian no. We pull snap free version from Mozilla PPA team: https://github.com/armbian/os/blob/main/external/firefox-noble.conf and apply hack - repack with higher version then provided by Ubuntu: https://github.com/armbian/scripts/blob/main/.github/workflows/download-and-test-external.yml#L258-L269 following by pushing to our repositories. This is control file: Package: thunderbird Version: 9:128.5.0+build1-0ubuntu0.24.04.1~mt1armbian1 Architecture: armhf Maintainer: Ubuntu Mozilla Team <ubuntu-mozillateam@lists.ubuntu.com> Installed-Size: 247933 Depends: libasound2t64 (>= 1.0.16), libatk1.0-0t64 (>= 1.12.4), libc6 (>= 2.38), libcairo-gobject2 (>= 1.10.0), libcairo2 (>= 1.10.0), libdbus-1-3 (>= 1.9.14), libfontconfig1 (>= 2.12.6), libfreetype6 (>= 2.3.5), libgcc-s1 (>= 4.3), libgdk-pixbuf-2.0-0 (>= 2.22.0), libglib2.0-0t64 (>= 2.38.0), libgtk-3-0t64 (>= 3.13.7), libharfbuzz0b (>= 0.6.0), libpango-1.0-0 (>= 1.14.0), libpangocairo-1.0-0 (>= 1.14.0), libstdc++6 (>= 12), libx11-6, libx11-xcb1 (>= 2:1.8.7), libxcb-shm0, libxcb1, libxcomposite1 (>= 1:0.4.5), libxcursor1 (>> 1.1.2), libxdamage1 (>= 1:1.1), libxext6, libxfixes3, libxi6, libxrandr2 (>= 2:1.4.0), libxrender1, zlib1g (>= 1:1.1.4) Recommends: myspell-en-us | hunspell-dictionary | myspell-dictionary, libcanberra0, libdbusmenu-glib4, libdbusmenu-gtk3-4 Suggests: thunderbird-gnome-support, ttf-lyx, libotr5 Conflicts: mozilla-thunderbird Breaks: enigmail (<< 2:2.2), jsunit (<< 0.2.2-2ubuntu1), thunderbird-gnome-support (<= 3.0.4+nobinonly-0ubuntu3), tinyjsd (<< 1.2+git1-1ubuntu1) Replaces: mozilla-thunderbird, thunderbird-gnome-support (<= 3.0.4+nobinonly-0ubuntu3) Provides: mail-reader Section: mail Priority: optional Description: Email, RSS and newsgroup client with integrated spam filter Thunderbird is a full-featured email, RSS and newsgroup client that makes emailing safer, faster and easier than ever before. It supports different mail accounts (POP, IMAP, Gmail), has a simple mail account setup wizard, one- click address book, tabbed interface, an integrated learning spam filter, advanced search and indexing capabilities, and offers easy organization of mails with tagging and virtual folders. It also features unrivalled extensibility. and there is no dependency for snapd. I will need to look closely when time permits. 0 Quote
