remolaan Posted November 28, 2024 Posted November 28, 2024 I have a SDMC DV8040 stb ,SoC-CPU-Quad-core 1.2 GHz,GPU-ARM Mali-450,RAM-1GB,Storage-8GB it currently runs custom made android 9, i tried various methods , none of them work , it doesnt boot with Amlogic S805X,, earlier i tried to boot armbian , nothing happen, i found a way to get the uboot shell , i soldered wires on uart pins , i can interrupt booting process ,i attached the printenv file , now i want is command to manually boot from sd card via uboot and write the os on flash memory permanently. i want to know what is the suitable .dtb file ,,all i know is s805X is low cost version of s905 Amlogic soc. its been 2 years im trying to boot amlogic to stb ;-/. need your help . thank you gxl_p241_v1#printenv - Copy.txt 0 Quote
SteeMan Posted November 28, 2024 Posted November 28, 2024 Have you tried what I suggested to you previously? https://forum.armbian.com/topic/27210-how-to-install-armbian-to-amlogic-s805-android-box/#findComment-163422 1 Quote
remolaan Posted May 13 Author Posted May 13 hey , i almost gave up installing armbian , thank you for your support , for last time , im gonna try this ,i can understand dtb stuffs but, could you please tell me what armbian image i should download ? or could you please share me the link , i think whole time i downloaded wrong image , 0 Quote
SteeMan Posted Thursday at 07:31 PM Posted Thursday at 07:31 PM @remolaan I think this is the most current info that may help you: 0 Quote
