Pat Byers Posted July 24, 2017 Share Posted July 24, 2017 I've installed the Armbian distro for Tinker Board, updated it, fiddles with PulseAudio settings, added Codecs but for the life of me I can't get any audio from the headphone jack. Hopefully someone can suggest a solution. TIA. Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 24, 2017 Share Posted July 24, 2017 Given the reboot/bt issues I haven't worked out how to make this default in the user space, it's part of the build system I'm not acquainted with. There's also a sampling issue of some sort, certain sources send horrible screeching garbage out of the jack. That's also happened to me using I2S with this board. I don't know what HDMI would do. Link to comment Share on other sites More sharing options...
Xalius Posted July 26, 2017 Share Posted July 26, 2017 On 7/24/2017 at 11:12 PM, TonyMac32 said: Given the reboot/bt issues I haven't worked out how to make this default in the user space, it's part of the build system I'm not acquainted with. There's also a sampling issue of some sort, certain sources send horrible screeching garbage out of the jack. That's also happened to me using I2S with this board. I don't know what HDMI would do. This sounds like a familiar issue I have with my Rock64 sample too, there seems something wrong with the sampling clock for the analog audio codec... Link to comment Share on other sites More sharing options...
