robertoj Posted December 8, 2024 Posted December 8, 2024 Hello, I have a new LCD which I believe is an ili4988 (although the vendor says ili9486 and st7796) https://www.aliexpress.us/item/3256803856059047.html I have read somewhere, that I can use an ili9341 spi driver, only by changing the resolution and changing the initialization script. I looked in the waveshare website and github, they don't have anything for the ili9488 Then, I found some arduino code in http://www.lcdwiki.com/3.5inch_SPI_Module_ILI9488_SKU%3AMSP3520 (look for the "3.5 inch SPI Module Package(ILI9488)" link, then find the LCDWIKI_SPI.cpp The initialization sequence is in line 1697: Spoiler 0xF7, 4, 0xA9, 0x51, 0x2C, 0x82, 0xC0, 2, 0x11, 0x09, 0xC1, 1, 0x41, 0xC5, 3, 0x00, 0x0A, 0x80, 0xB1, 2, 0xB0, 0x11, 0xB4, 1, 0x02, 0xB6, 2, 0x02, 0x22, 0xB7, 1, 0xC6, 0xBE, 2, 0x00, 0x04, 0xE9, 1, 0x00, 0x36, 1, 0x08, 0xE0, 15, 0x00, 0x07, 0x10, 0x09, 0x17, 0x0B, 0x41, 0x89, 0x4B, 0x0A, 0x0C, 0x0E, 0x18, 0x1B, 0x0F, 0xE1, 15, 0x00, 0x17, 0x1A, 0x04, 0x0E, 0x06, 0x2F, 0x45, 0x43, 0x02, 0x0A, 0x09, 0x32, 0x36, 0x0F, 0x11, 0, TFTLCD_DELAY8, 120, 0x29, 0 I am currently trying to convert it to a DTS-format init string, so that it fits my ili9341-fb.dts, which I made earlier this year: Spoiler /* OrangePi Zero 3 -> ILI9341 LCD connections SPI CLOCK = PH6 SPI DO (LCD MISO) = PH8 (OPIZ MISO) SPI DI (LCD MOSI) = PH7 (OPIZ MOSI) LCD DATA/CONTROL = PC7 * LCD RESET = PC14 * could be any GPIO pin I want CHIP SELECT = PH9 VCC = 3.3V PIN 17 GND = GND PIN 20 */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun50i-h616"; /*what is the H618*/ fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PC7", "PC14"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 7 9 0>; /* PH9 chip select, H=7 */ num-chipselects = <1>; display: display@0 { /*compatible = "adafruit,yx240qv29","ilitek,ili9341";*/ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <40000000>; rotate = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <640>; width = <320>; reset-gpios = <&pio 2 14 1>; /* PC14 reset pin*/ dc-gpios = <&pio 2 7 0>; /* PC7 Data control pin */ debug = <3>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; I am unsure how to start the init line, can someone help me? Then, when I have that init string confirmed, I can use: https://github.com/notro/panel-mipi-dbi/wiki https://blog.csdn.net/CNflysky/article/details/125171176 To switch to the mipi-dbi driver, which would get me DRM (instead of FB) 0 Quote
robertoj Posted December 8, 2024 Author Posted December 8, 2024 If you want to help, the datasheet PDF is in the lcdwiki download link in the previous post I converted the arduino byte sequence into this: Spoiler init = < 0x10000F7 0xA9 0x51 0x2C 0x82 //adjust control 3 0x10000C0 0x11 0x09 //power control 1 0x10000C1 0x41 //power control 2 0x10000C5 0x00 0x0A 0x80 //voltage common control 0x10000B1 0xB0 0x11 //frame rate control 0x10000B4 0x02 //display inversion control 0x10000B6 0x02 0x22 //display function control 0x10000B7 0xC6 //entry mode set 0x10000BE 0x00 0x04 //HS lanes control 0x10000E9 0x00 //set image function 0x1000036 0x08 //memory access control 0x10000E0 0x00 0x07 0x10 0x09 0x17 0x0B 0x41 0x89 0x4B 0x0A 0x0C 0x0E 0x18 0x1B 0x0F //PGAMCTR positive gamma control 0x10000E1 0x00 0x17 0x1A 0x04 0x0E 0x06 0x2F 0x45 0x43 0x02 0x0A 0x09 0x32 0x36 0x0F //NGAMCTRL negative gamma control 0x1000011 //sleep out command 0x1000029>; //display on The 4.0 inch ILI9488 starts up with RGB noise (non moving) in the left 3/4 of the screen, and a blurry, noisy image in the right 1/4 of the screen. There's a TFTLCD_DELAY8, 120, which I don't know how to insert in the DTS, and the original ili9341-fb.dts has a 0x20000ff, which I don't know whether I need it in the ili9488 init string I inserted the: 0x10000b0 0x00 //interface mode control 0x1000011 //sleep out 0x20000ff //no idea At the beginning, and there is no effect I have no idea about the parameters buswidth, bgr, regwidth... what do they mean? When I added regwidth=<16> (as shown in https://forum.armbian.com/topic/16536-35-screen-ili9486xpt2046-with-kernel-5914-sunxi/) I have a white-grayish screen When I change it to regwidth=<24> I get the same RGB noise as without this parameter When I swap the numbers in height and width like this: height = <320>; width = <640>; I get the RGB noise in the left 3/4 of the screen, but the noisy desktop image (partial) in the top right corner of the LCD I HAD A BIG TYPO: not 640, should be 480 height = <480>; width = <320>; Now, all the screen is mostly black, showing garbled text lines, then a garbled desktop on the top 2/3 of the screen Changing the buswidth to 18 had no effect... I changed the regwidth=16 (made it worse) and txbuflen=32768 (no effect), as seen in https://4pda-to.translate.goog/forum/index.php?showtopic=1041048&st=40&_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=wapp Using the ili9486 driver as suggested here: https://github.com/notro/fbtft/issues/582 gave me a white screen 0 Quote
robertoj Posted December 8, 2024 Author Posted December 8, 2024 Changin the parameter Interface Pixel Format (3Ah) to 0x55 (DPI=DBI=55=16 bits/pixel FIXED THE COLORS Insert this after 0x20000ff (I still have no idea what it is for) 0x100003a 0x55 //pixel format. DBI=DPI=16bits per pixel (from ili9341 init) Now, the problem is that the desktop image is reversed left to right... I changed the memory access control to vertical refreshed order direction=1 0x1000036 0x28 //memory access control (was 0x08 in arduino code) No effect, still reversed left to right (or up down if I rotated 180) Is there any difference if this parameter is written twice in the original ili9341 init byte sequence? Ok, it was register B6h Display function control. The bit SS shift direction control was set to 1 in the arduino INO, but it needs to be 0 Change 0x10000B6 0x02 0x22 //display function control 0x10000B6 0x02 0x02 //display function control (2nd param SS shift direction was 0x22 from arduino code) Also, change the rotate DTS parameter from 270 to 90 and the spi speed to 60 MHz Display works correctly in FBTFT mode... but not DRM yet, and not merged with the ADS7846 function (touch screen) 0 Quote
robertoj Posted December 9, 2024 Author Posted December 9, 2024 Posting the FBTFT DTS only... while I am having trouble merging it with ads7846: Spoiler /* OrangePi Zero 3 -> ILI9341 LCD connections SPI CLOCK = PH6 SPI DO (LCD MISO) = PH8 (OPIZ MISO) SPI DI (LCD MOSI) = PH7 (OPIZ MOSI) LCD DATA/CONTROL = PC7 * LCD RESET = PC14 * could be any GPIO pin I want CHIP SELECT = PH9 VCC = 3.3V PIN 17 GND = GND PIN 20 */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun50i-h616"; /*what is the H618*/ fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PC7", "PC14"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 7 9 0>; /* PH9 chip select, H=7 */ num-chipselects = <1>; display: display@0 { /*compatible = "adafruit,yx240qv29","ilitek,ili9341";*/ compatible = "ilitek,ili9341"; //compatible = "ilitek,ili9486"; reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <60000000>; //txbuflen = <32768>; rotate = <90>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<1>; fps = <15>; buswidth = <8>; regwidth = <8>; height = <480>; width = <320>; reset-gpios = <&pio 2 14 1>; /* PC14 reset pin*/ dc-gpios = <&pio 2 7 0>; /* PC7 Data control pin */ debug = <3>; init = < 0x10000b0 0x00 //interface mode control 0x1000011 //sleep out command 0x20000ff //no idea what this does 0x100003a 0x55 //pixel format. DBI=DPI=16bits per pixel (from ili9341 init) 0x10000F7 0xA9 0x51 0x2C 0x82 //adjust control 3 0x10000C0 0x11 0x09 //power control 1 0x10000C1 0x41 //power control 2 0x10000C5 0x00 0x0A 0x80 //voltage common control 0x10000B1 0xB0 0x11 //frame rate control 0x10000B4 0x02 //display inversion control 0x10000B6 0x02 0x02 //display function control (2nd param SS shift direction was 0x22 from arduino code) 0x10000B7 0xC6 //entry mode set 0x10000BE 0x00 0x04 //HS lanes control 0x10000E9 0x00 //set image function 0x1000036 0x08 //memory access control 0x10000E0 0x00 0x07 0x10 0x09 0x17 0x0B 0x41 0x89 0x4B 0x0A 0x0C 0x0E 0x18 0x1B 0x0F //PGAMCTR positive gamma control 0x10000E1 0x00 0x17 0x1A 0x04 0x0E 0x06 0x2F 0x45 0x43 0x02 0x0A 0x09 0x32 0x36 0x0F //NGAMCTRL negative gamma control 0x1000011 //sleep out command 0x1000029>; //display on }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; Ok, now I was able to merge the ads7946 function: Spoiler roberto@orangepizero3:~/ili9341$ cat ili9488-ads7846.dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; //PH9=CS0 for lcd, PC15=CS1 for touch. ili9488: ili9488@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <60000000>; rotate = <90>; bgr = <1>; fps = <15>; buswidth = <8>; regwidth = <8>; height = <480>; width = <320>; reset-gpios = <&pio 2 14 1>; // PC14 dc-gpios = <&pio 2 7 0>; // PHC7 debug = <3>; init = < 0x10000b0 0x00 //interface mode control 0x1000011 //sleep out command 0x20000ff //no idea what this does 0x100003a 0x55 //pixel format. DBI=DPI=16bits per pixel (from ili9341 init) 0x10000F7 0xA9 0x51 0x2C 0x82 //adjust control 3 0x10000C0 0x11 0x09 //power control 1 0x10000C1 0x41 //power control 2 0x10000C5 0x00 0x0A 0x80 //voltage common control 0x10000B1 0xB0 0x11 //frame rate control 0x10000B4 0x02 //display inversion control 0x10000B6 0x02 0x02 //display function control (2nd param SS shift direction was 0x22 from arduino code) 0x10000B7 0xC6 //entry mode set 0x10000BE 0x00 0x04 //HS lanes control 0x10000E9 0x00 //set image function 0x1000036 0x08 //memory access control 0x10000E0 0x00 0x07 0x10 0x09 0x17 0x0B 0x41 0x89 0x4B 0x0A 0x0C 0x0E 0x18 0x1B 0x0F //PGAMCTR positive gamma control 0x10000E1 0x00 0x17 0x1A 0x04 0x0E 0x06 0x2F 0x45 0x43 0x02 0x0A 0x09 0x32 0x36 0x0F //NGAMCTRL negative gamma control 0x1000011 //sleep out command 0x1000029>; //display on }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; // PC10 - IRQ pendown-gpio = <&pio 2 10 1>; // PC10 // OPTIONS ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; WARNING: when the touchscreen is touched, a horizontal band (about 8mm) gets color-inverted around the cursor. Lowering the SPI speed does not help it ^ Does anybody have any idea why this is happening? It is bugging me horribly and the color-inversion is lasting until a whole screen refresh and it could stand garbled while doing nothing in lightdm+openbox... is this coming from the touch chip interrupts, or from the cursor animation? Would it go away with the panel-mipi-dbi-spi driver? Next step is to use the panel-mipi-dpi-spi driver as shown here: https://github.com/notro/panel-mipi-dbi/wiki , https://forums.raspberrypi.com/viewtopic.php?t=358240&hilit=Ili9341#p2165638and https://blog.csdn.net/CNflysky/article/details/125171176 0 Quote
robertoj Posted December 10, 2024 Author Posted December 10, 2024 My efforts to use the panel-mipi-dbi-spi driver: DTS Spoiler roberto@orangepizero3:~/mipi-dbi$ cat mipi-ili9488-ads7846.dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; /*PH9=CS0 for lcd, PC15=CS1 for touch. Trying <0> instead of <&pio 7 9 0> */ panel: panel@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; width-mm=<84>; height-mm=<56>; reset-gpios = <&pio 2 14 0>; // PC14 dc-gpios = <&pio 2 7 0>; // PHC7 write-only; debug = <3>; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; /* PC10 - IRQ */ pendown-gpio = <&pio 2 10 1>; /* PC10 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; Init sequence panel-mipi-dbi-spi.txt Spoiler command 0xB0 0x00 #interface mode control command 0x11 #sleep out command command 0x3A 0x55 #interface pixel format. DBI=DPI=16bits per pixel (from ili9341 init) command 0xF7 0xA9 0x51 0x2C 0x82 #adjust control 3 command 0xC0 0x11 0x09 #power control 1 command 0xC1 0x41 #power control 2 command 0xC5 0x00 0x0A 0x80 #voltage common control command 0xB1 0xB0 0x11 #frame rate control command 0xB4 0x02 #display inversion control command 0xB6 0x02 0x02 #display function control command 0xB7 0xC6 #entry mode set command 0xBE 0x00 0x04 #HS lanes control command 0xE9 0x00 #set image function command 0x36 0x28 #memory access control command 0xE0 0x00 0x07 0x10 0x09 0x17 0x0B 0x41 0x89 0x4B 0x0A 0x0C 0x0E 0x18 0x1B 0x0F #PGAMCTR command 0xE1 0x00 0x17 0x1A 0x04 0x0E 0x06 0x2F 0x45 0x43 0x02 0x0A 0x09 0x32 0x36 0x0F #NGAMCTRL command 0x11 #sleep out command delay 120 command 0x29 #display on compile and install this init command byte sequence (I don't know how to use an arbitrary bin file in the DTS😞 ./mipi-dbi-cmd panel-mipi-dbi.bin panel-mipi-dbi-spi.txt sudo cp panel-mipi-dbi.bin /lib/firmware/ Make sure that the DTS was given to the kernel: look for "Applying user provided DT overlay mipi-ili9488-ads7846.dtbo" without errors before starting kernel Make sure that the panel-mipi-dbi.bin was read by the driver: dmesg|grep mipi , look for no errors like "No config file found for compatible 'ili9488-init,panel-mipi-dbi-spi' (error=-2)" Successfully loaded driver should look lije this: roberto@orangepizero3:~$ dmesg|grep mipi [ 5.690191] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 5.690338] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 5.713936] [drm] Initialized panel-mipi-dbi 1.0.0 20220103 for spi1.0 on minor 2 [ 6.205598] panel-mipi-dbi-spi spi1.0: [drm] fb0: panel-mipi-dbid frame buffer device The panel-mipi-dbi-spi driver in Linux 6.7.12.has the parameters described in: https://elixir.bootlin.com/linux/v6.7.12/source/Documentation/devicetree/bindings/display/panel/panel-mipi-dbi-spi.yaml Upgrading to Linux 6.11+ has more parameters, like BGR666 color format https://elixir.bootlin.com/linux/v6.12.4/source/Documentation/devicetree/bindings/display/panel/panel-mipi-dbi-spi.yaml The panel-mipi-dbi-spi wiki: https://github.com/notro/panel-mipi-dbi/wiki This is what I get so far I think I need to upgrade to Linux 6.12 and experiment with other "Memory Access Control 0x36" bit values in panel-mipi-dbi-spi.txt 0 Quote
Solution robertoj Posted December 13, 2024 Author Solution Posted December 13, 2024 THANKS TO USER KungFuPancake, who showed me his github repo, where he indicates to use the latest Armbian-edge, and provides the a command byte sequence for the ili9488 https://github.com/KungfuPancake/v0_ips_touch_display?tab=readme-ov-file If you see inverted colors, edit the panel-mipi-dbi-spi.txt and comment the line #command 0x21 before using the mipi-dbi-cmd If you have the cheap chinese clone LCD (see first post), use this DTS (change the gpio codes as needed): Spoiler roberto@orangepizero3:~/mipi-ili9488/v0_ips_touch_display$ cat orangepi-zero3-ads7846.dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; // PH9=CS0 for lcd, PC15=CS1 for touch panel: panel@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; width-mm=<84>; height-mm=<56>; reset-gpios = <&pio 2 14 0>; // PC14 dc-gpios = <&pio 2 7 0>; // PHC7 write-only; format = "b6x2g6x2r6x2"; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; /* PC10 - IRQ */ pendown-gpio = <&pio 2 10 1>; /* PC10 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; 1 Quote
robertoj Posted December 14, 2024 Author Posted December 14, 2024 Is anyone getting a jumpy cursor, and garbled image around the areas of window refresh? (only at times of touching the screen) I suspect it is caused by sharing the SPI bus with the ads7846 (XPT2040)... anyone knows? I don't have this issue when I use the USB mouse. I also experience the LCD going 3/4 black and frozen, when there are no input events. It restores to normal when I touch the screen or move the mouse (with a white washout/flash in the LCD). My app is continuosly painting pixels, and it happens after a few minutes of no input events. I already have: xset s off & xset s noblank xset s -dpms But it seems that I don't have "xset" installed in my debian bookworm. Fixed with apt install x11-xserver-utils 0 Quote
robertoj Posted March 5 Author Posted March 5 I found that you can rotate the ili9488 display 180 degrees, by changing the LCD initialization command in panel-mipi-dbi-spi.txt: Change: command 0x36 0xE0 To: command 0x36 0x20 (changes memory access control row and column order from: starting from the corner near the VCC pin, to starting from the corner opposite from the VCC pin) Then, open /usr/share/X11/xorg.conf.d/99-calibration, and add: Option "InvertX" "1" Option "InvertY" "1" Reference: https://focuslcds.com/wp-content/uploads/Drivers/ILI9488.pdf https://forums.raspberrypi.com/viewtopic.php?t=173993 I hope it helps someone, or to myself in the future 0 Quote
le51 Posted March 5 Posted March 5 Hi @robertoj, it's really interesting.. For now I just can get my ili9488 display working exclusively on a RBPi using JUJ's fbcp https://github.com/juj/fbcp-ili9341 Tell me if I resume well: You got the display to work with the old fbtft driver, but touch seems unsure You're using the tinydrm and it's fully functionnal What is your kernel version ? 0 Quote
robertoj Posted March 5 Author Posted March 5 (edited) I have the ili9488 working in orange pi zero 3 with my DTS in https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-208446 and the panel-mipi-dbi-spi.txt from https://github.com/KungfuPancake/v0_ips_touch_display?tab=readme-ov-file My DTS file uses the new panel-mipi-dbi-spi driver, which is not fbtft, it is tinydrm. Kernel 6.12, built from https://github.com/NickAlilovic/build I can use X11 completely fine, but I havent tried wayland and h264 acceleration yet. Can you try it? The only problems I see: Cursor has some "jumpiness" when pressing the touch panel (ads7846). Graphic pixel noise appears when I am dragging an X11 window with finger. But it returns to normal after the dragging event. (doesn't happen when I drag with USB mouse). I think the noise won't happen if I can make a separate soft-SPI for the touch function. Has anybody tried xrandr? I learned to use it in my laptop, but I don't have my orange pi zero 3 available. Can anyone try: $ xrandr --output SPI-1 --rotate left Then replace left with: inverted, right and normal This should take care of the touch at the same time, but someone needs to try it. Edited March 8 by robertoj 0 Quote
le51 Posted March 8 Posted March 8 Hi, sorry for the delay. On 3/5/2025 at 7:22 PM, robertoj said: My DTS file uses the new panel-mipi-dbi-spi driver, which is not fbtft, it is tinydrm. I can't believe it ! This is just great. I will give it a try the next few days. Many thanks 0 Quote
robertoj Posted March 10 Author Posted March 10 I had time to test xrandr with my ili9488 and mipi-dbi-spi while the LCD is showing X11+lightdm+openbox, I logged in via SSH and typed: roberto@orangepizero3:~$ DISPLAY=:0.0 xrandr -q xrandr: Failed to get size of gamma for output default Screen 0: minimum 480 x 320, current 480 x 320, maximum 480 x 320 default connected 480x320+0+0 0mm x 0mm 480x320 0.00* roberto@orangepizero3:~$ DISPLAY=:0.0 xrandr --output default --rotate left xrandr: output default cannot use rotation "left" reflection "none" So, I can't rotate the LCD display with xrandr, and the only option is the 2 actions I shared on March 4 Note: the 4 rotate options are normal, right, left and inverted. None of them worked 0 Quote
le51 Posted March 10 Posted March 10 (edited) So I've looked into my drawers and, unfortunately, I can't get my hands on the ili9488 display I own. I will order a new one. But I've got another display of the same type (with the red PCB and 14 pins and resistive touch) with ili9486 driver IC. In LCDWIKI_SPI.cpp, there's an init sequence for that chip, but I'm really confused. On 12/13/2024 at 6:11 AM, robertoj said: THANKS TO USER KungFuPancake, who showed me his github repo, where he indicates to use the latest Armbian-edge, and provides the a command byte sequence for the ili9488 Means that you have use this file: https://github.com/KungfuPancake/v0_ips_touch_display/blob/main/panel-mipi-dbi-spi.txt ? It's really different from what is in LCDWIKI_SPI.cpp around line 1697 (for ili9488) Edited March 10 by le51 0 Quote
robertoj Posted March 10 Author Posted March 10 Yes, you must use that panel-mipi-dbi-spi.txt, process it with the python script, copy it to the right folder, and use the DTS I shared last. I havent seen another command byte sequence for ili9488. Can you post the link to the download (to make sure I will see the same thing). Can you make a hypothetical byte sequence from the LCDWIKI_SPI.cpp? 0 Quote
le51 Posted March 11 Posted March 11 (edited) This is from panel-mipi-dbi-spi.txt command 0xE0 0x00 0x03 0x09 0x08 0x16 0x0A 0x3F 0x78 0x4C 0x09 0x0A 0x08 0x16 0x1A 0x0F command 0xE1 0x00 0x16 0x19 0x03 0x0F 0x05 0x32 0x45 0x46 0x04 0x0E 0x0D 0x35 0x37 0x0F This is from LCDWIKI_SPI.cpp for ili9488: 0xE0, 15, 0x00, 0x07, 0x10, 0x09, 0x17, 0x0B, 0x41, 0x89, 0x4B, 0x0A, 0x0C, 0x0E, 0x18, 0x1B, 0x0F, 0xE1, 15, 0x00, 0x17, 0x1A, 0x04, 0x0E, 0x06, 0x2F, 0x45, 0x43, 0x02, 0x0A, 0x09, 0x32, 0x36, 0x0F, They are other commands that differs slightly. I've found other sources for the init sequence which seems all to be close to panel-mipi-dbi-spi.txt : * Juj fbcp lib: https://github.com/juj/fbcp-ili9341/blob/master/ili9488.cpp#L28 * Bodmer eTFT_SPI lib for microcontrollers : https://github.com/Bodmer/TFT_eSPI/blob/master/TFT_Drivers/ILI9488_Init.h#L11 * Jarret Bucket Adafruit GLX lib : https://github.com/jaretburkett/ILI9488/blob/master/ILI9488.cpp#L378 * this one is for STM32 : https://github.com/RobertoBenjami/stm32_graphics_display_drivers/blob/master/Drivers/lcd/ili9488/ili9488.c#L219 In the same manner, we can found init sequences for other chips in these libraries, eg ili9486. There's already a driver in the kernel source : https://web.git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/gpu/drm/tiny/ili9486.c?h=linux-6.12.y but it is specific to Waveshare 35a or PiScreen displays (these with 4 kind of shift register ICs onboard). So for now, while waiting for a new ili9488 display arrives home, I'm digging further around the right init sequence for ili9486. Edited March 11 by le51 1 Quote
le51 Posted March 11 Posted March 11 For reference and as a bookmark reminder * https://github.com/bkosciow/gfxlcd/blob/master/gfxlcd/driver/ili9486/ili9486.py * https://github.com/ZinggJM/ILI9486_SPI/blob/master/src/ILI9486_SPI.cpp * https://github.com/RobertoBenjami/stm32_graphics_display_drivers/blob/master/Drivers/lcd/ili9486/ili9486.c * https://github.com/Bodmer/TFT_eSPI/blob/master/TFT_Drivers/ILI9486_Init.h * https://github.com/ZinggJM/ILI9486_SPI/blob/master/src/ILI9486_SPI.cpp * https://github.com/DeadReDeamed/Raspberry-Pi-LCD-ILI9486-Driver/blob/main/LCD_Driver/LCD_Driver.c 1 Quote
robertoj Posted March 13 Author Posted March 13 Those LCD parameters where you found differences are: PGAMCTRL (Positive Gamma Control) (E0h) NGAMCTRL (Negative Gamma Control) (E1h) (See the ILI9488 PDF I posted) I don't know what they do exactly, but I guess they control pixel voltage, given a R, G or B digital value. I think that you can worry about it, after everything else works. 0 Quote
le51 Posted March 15 Posted March 15 Excellent news here: I've finally found my ili9488 display and, even better, I've got it to work with https://github.com/KungfuPancake/v0_ips_touch_display/blob/main/panel-mipi-dbi-spi.txt I had to remove command 0x21 which is specific for IPS displays (mine is TN) to get a correct color rendering. But unfortunately all my attempts with the ili9486 display ends up with a blank screen (driver is registered, Xorg session start, but nothing on screen. I don't know how to debug further 😪 ...) I'm doing all of this with a Raspberry Pi4b 6.12.18-v8+. I will try to test later on a Radxa 5b 0 Quote
robertoj Posted March 17 Author Posted March 17 When the driver is configured correctly for the orange pi zero 3, everything will look correct from inside the operating system and the SPI port will be clocking out bits. But the LCD is a one-way communication device. The orange pi zero 3 will never know something has failed The ILI9486 LCD's default byte ordering, color format, etc, may be different from the ILI9488. You should find one example of ILI9486 running in raspberry pi, arduino, etc and find the initial byte command sequence. See how it differs from the KungFuPancake's txt file. Make changes to the txt file one by one line, toward being closer to the ili9486 byte sequence you find elsewhere. If you are starting with a DTS that uses the "ilitek,ilixxxx" driver, and change it to "mipi-dbi-spi", remember to change the RESET pin definition (see my other ILI9431 thread for explanation) 0 Quote
robertoj Posted April 18 Author Posted April 18 (edited) The DTS I posted before works for up to Linux 6.11 If anybody wants to use ili9488 in Linux 6.13, this is the modified DTS to use: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; pinctrl-names = "default"; //new for linux 6.13 pinctrl-0 = <&spi1_pins>; //new for linux 6.13 cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; // PH9=CS0 for lcd, PC15=CS1 for touch panel: panel@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; width-mm=<84>; height-mm=<56>; reset-gpios = <&pio 2 14 0>; // PC14 dc-gpios = <&pio 2 7 0>; // PC7 write-only; format = "b6x2g6x2r6x2"; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; /* PC10 - IRQ */ pendown-gpio = <&pio 2 10 1>; /* PC10 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; Notice the new lines commented with "new for linux 6.13" Remenber that the firmware file must be named panel-mipi-dbi-spi.bin and copied to /lib/firmware I will test this with Linux 6.12 shortly... update: it works with linux 6.12.20 (The Going's repo) and 6.12.11 (NickA's repo, self built, not downloaded image) For reference, I discuss the process of finding this solution here: https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-215554 Update: this DTS works for Linux 6.12 and 6.13... but make sure to add "-" before "patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch" in the build/patch/kernel/archive/sunxi-6.13/series.conf file then build your OS with ./compile.sh Edited April 21 by robertoj 0 Quote
robertoj Posted April 27 Author Posted April 27 (edited) Interesting effect of changing the ili9488 10cm (4.0 inch) for a 9cm (3.5 inch) LCD, same resolution https://a.aliexpress.com/_mMKRqan https://a.aliexpress.com/_mqk0Qbv (I bought a similar with touch) maybe I need a different spi frequency update: I changed 40 MHz to 60 MHz and my new LCD works perfectly:) update: with 60 Hz, full screen video has a lot of noise and distortion. With 70Hz, there’s only white dots on black background with 50hz, the console shows wrong colors and video is white noise with 30 hz, console text and video are ok… but video looks 10 fps the touch panel in the smaller 9cm LCD does not work. Do not buy it! Edited April 28 by robertoj 0 Quote
robertoj Posted May 12 Author Posted May 12 I received my new LCD today. It is a 9486 but luckily it worked with my 9488 dts HOWEVER: The touch xpt2046/ads7846 is not sending any events…checking with evtest… same dts works with the ili9488 4.0” I already tried changing the GPIO polarity (level and clock transition) has anyone worked with any of the red 3.5 lcd ili9488 or 9486 0 Quote
robertoj Posted May 13 Author Posted May 13 (edited) Does anyone know if the spi-cpol and spi-cpha parameters are applicable in the ads7846 part of the DTS? I have seen cpol in an LCD discussion here: https://forum.armbian.com/topic/38896-orange-pi-lite-problem-with-latest-firmware/#findComment-191293 I am running out of ideas to try to make touch work... I can also try using gpio-spi.ko I need to check that the IRQ pin is changing from 3.3 to 0V... if I connect a LED to it, will it be a 0.0V pulse or held low while I press my finger? I learnt that /proc/interrupts can tell me if the IRQ input is seeing something... and I can see the number increase each time I press my finger on the screen: (see the line that ends with ads7846) Spoiler roberto@orangepizero3:~$ cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 12: 36456 16042 18786 33391 GICv2 30 Level arch_timer 15: 1 0 0 0 GICv2 74 Level 3002000.dma-controller 16: 0 0 0 0 GICv2 93 Level 30f0000.iommu 17: 0 0 0 0 GICv2 136 Level 7000000.rtc 18: 40 0 0 0 GICv2 123 Level sun8i-ce-ns 19: 0 0 0 0 GICv2 172 Level arm-pmu 20: 0 0 0 0 GICv2 173 Level arm-pmu 21: 0 0 0 0 GICv2 174 Level arm-pmu 22: 0 0 0 0 GICv2 175 Level arm-pmu 23: 0 0 0 0 GICv2 98 Level 6515000.lcd-controller 24: 0 0 0 0 GICv2 95 Level 6000000.hdmi, dw-hdmi-cec 25: 706 0 0 0 GICv2 137 Level mv64xxx_i2c 26: 7068 0 0 0 GICv2 51 Level ths 76: 1 0 0 0 sunxi_pio_level 41 Level axp313a_irq_chip 77: 19 0 0 1 sunxi_pio_edge 42 Edge ads7846 299: 2280 0 0 3649 GICv2 67 Level sunxi-mmc 300: 6 0 0 0 GICv2 32 Level ttyS0 301: 9691 0 0 0 GICv2 68 Level sunxi-mmc https://forums.raspberrypi.com/viewtopic.php?t=187023&start=25 Is there any way to debug the ads7846 kernel module? I have seen this J1jumper mentioned here: https://forum.arduino.cc/t/solved-3-5-tft-not-stable-at-power-up/684536/19 "if you jumper J1, you feed it with 3.3V" I power it with 3.3V and the J1 contacts are disconnected... so maybe the 7846 is undervolted... does anyone have experience with this? Edited May 13 by robertoj 0 Quote
robertoj Posted June 5 Author Posted June 5 (edited) I finally got time to test my new ili9488 4.0 inch LCD (red, version 2.1)... the graphic display works, but the touch doesn't I see the interrupts number increasing (with watch -n0.1 cat /proc/interrupts , focusing on the line with ads7846) I also see that some people in the arduino community short diode D1, or else the SPI second slave wont work https://github.com/Bodmer/TFT_eSPI/discussions/898 Is anyone here working with a new SPI LCD? How could I see logs specific for the ads7846 kernel driver? update: this LCD does not have a D1 diode, and it looks like this According to this Amazon link, this LCD board should have a flat cable through the "slot hole" near the top right. https://www.amazon.com/Display-Module-ILI9488-480x320-Equipped/dp/B0D92DSCMG Edited June 6 by robertoj 0 Quote
robertoj Posted June 15 Author Posted June 15 (edited) I just did some new experiments, trying to get touch working in ili9488 LCD v2.1 Increasing or decreasing the SPI MHz in both the LCD and touch section of the DTS DONT WORK... I couldn't get touch working Next is to use a software defined SPI with spi-gpio (based on my experience in my ili9341 thread) does anybody know a Python soft spi program which can talk to ads7846/xpt2046? update: I am getting some good touch results with Raspberry, which I hope I can transfer to opiz3. https://forums.raspberrypi.com/viewtopic.php?t=389230 Edited Monday at 06:42 PM by robertoj 0 Quote
robertoj Posted Wednesday at 09:35 AM Author Posted Wednesday at 09:35 AM (edited) Success story: https://forums.raspberrypi.com/viewtopic.php?p=2322591#p2322591 with the 3.5 inch ili9488, graphics (wayland) and touch in raspberry pi 3b I hope this helps with making it work in orange pi zero 3 and 2w (only touch missing) Edited Wednesday at 09:39 AM by robertoj 0 Quote
