I know I need to find out which drivers to use... I just don't know where to start, I know I've seen some people having success with these displays - ili9488, and a couple others - I just don't know if this fits one of those overlays or not. (nothing I've tried so far has worked).
Any help identifying and pointing in the right direction, I would greatly appreciate. Trying to get this to work on my Orange Pi Zero 3 4gb.
(uploading images has failed.... so I guess I'll link them?)
https://imgur.com/a/NORYCj7
*edit 12/21  - renamed topic since I've Identified the display, going to track my (our?) progress with trying to get it to work.
Edited by Eric Johnson
identified first issue
I got a reply from the manufacturer.  ST7796.
Will this DTS work with the ST7796? (going to try it this weekend if no other solution mentioned beforehand)
  • Eric Johnson changed the title to ST7796 display w/ opiz3
Check here for the byte command sequence for st7796s and combine with the dts in my thread
https://forums.raspberrypi.com/viewtopic.php?t=380704
using the dts as is with your different touch controller likely wont hurt it, it may just throw error messages in dmesg|grep spi
or delete the touch part of the dts, or disconnect the spi pins to the touch controller if you want to be safer.
to be clear, do you mean the 9341 dts (which uses the xpt2046 touch control, which my display has) or the 9488 dts?
I haven't gotten as far as trying anything yet, I'm having trouble getting the SPI to work on my opiz3. Either that, or I'm having trouble getting wiringOP to work properly enough on Armbian in order to verify SPI is working. wiringOP verifies other GPIO as functional (and so does my meter) - but SPI seems to be a no-go. I've tried every SPI overlay in the armbian-config utility.
I meant the ili9488 DTS
Also avoid using any other SPI related DTS, when working with a LCD DTS. They will interfere with each other.
Use only the ili9488 DTS that I posted, only changing:
* the GPIO number codes, to make it fit your wiring connections
* the content of the *.txt file with the one in the raspberry forum
Ok. My efforts have been futile... but then again, I'm a noob at this. I'm thinking my pin numbers aren't matching up properly - I'm not 100% that I understand the <&pio 1 2 3> format. I have no clue what the first number is, I'm guessing the second number is the pin, and the third is high/low? (forgive my ignorance, I've tried researching this, but am not finding anything specific to this)
the changes marked in that raspberry pi forum I made to armbianEnv.txt (I'm assuming that's the armbian equivalent to the pi's config.txt?) - but it just occurred to me that the format is different. I don't think the armbian file uses "dtoverlay", rather just "overlay". I'll adjust that now and see if that  makes a difference. (edit - no matter what I do there, it doesn't load. absolutely nothing in dmesg about it one way or another)
This is what I've got:
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 24 0>,<&pio 2 26 0>; //chip select  pins 24 for LCD, 26 for touch
            panel: panel@0 {
                compatible = "panel-mipi-dbi-spi";
                reg = <0>;
                spi-max-frequency = <40000000>;
                width-mm=<79>;
                height-mm=<52>;
                reset-gpios = <&pio 2 22 0>; // pin 22, PC7
                dc-gpios = <&pio 2 18 0>; // pin 18, PC14
                write-only;
                format = "b6x2g6x2r6x2";
                panel-timing {
                    hactive = <480>;
                    vactive = <320>;
                    hback-porch = <0>;
                    vback-porch = <0>;
                    clock-frequency = <0>;
                    hfront-porch = <0>;
                    hsync-len = <0>;
                    vfront-porch = <0>;
                    vsync-len = <0>;
            ads7846: ads7846@1 {
                compatible = "ti,ads7846";
                reg = <1>;
                pinctrl-names = "default";
                spi-max-frequency = <1000000>;
                interrupt-parent = <&pio>;
                interrupts = <2 11 2>; /* PC6, pin 11 */
                pendown-gpio = <&pio 2 11 1>; /* PC6, pin 11  */
                /* OPTIONS */
                ti,x-min = /bits/ 16 <0>;
                ti,y-min = /bits/ 16 <0>;
                ti,x-max = /bits/ 16 <0xFFF>;
                ti,y-max = /bits/ 16 <0xFFF>;
                ti,pressure-min = /bits/ 16 <0>;
                ti,pressure-max = /bits/ 16 <0xFFF>;
                ti,x-plate-ohms = /bits/ 16 <400>;
                ti,swap-xy = <1>;
I know zero about display panels and near zero about device tree and its interactions.
But that i went googling around and found out where the source codes for some of the lcd panel drivers are found in the kernel source codes
apparently the 'new' drivers for the various LCD panels may be found under
 root/drivers/gpu/drm/panel
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/gpu/drm/panel
some of the 'older' drivers could be under
fbtft
https://github.com/notro/fbtft/wiki
implemented under fbdev
 root/drivers/video/fbdev
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/video/fbdev
apparently fbtft may no longer be in more recent kernels from 5.4
a 'compatible' statement match in the driver is found for ILI9341 lcd e.g.
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/gpu/drm/panel/panel-ilitek-ili9341.c#n563
I did not find a driver name that has 7796, some of them found has sitronix-st* file names e.g. for st7789
a 'compatible' statement is found here
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/gpu/drm/panel/panel-sitronix-st7789v.c#n672
take note that ST7796 may be using SPI rather than MIPI
http://www.lcdwiki.com/4.0inch_SPI_Module_ST7796
I've yet to try interfacing with ILI9341 which I've and I do not know how to configure SPI and in turn its driver with SPI
things found from random google searches
https://kernel.googlesource.com/pub/scm/linux/kernel/git/next/linux-next/+/refs/heads/akpm-base/Documentation/devicetree/bindings/display/ilitek%2Cili9341.txt
https://lore.kernel.org/lkml/20220618123035.563070-2-mail@conchuod.ie/
this is what is found so far
but there is still a lot more questions than there are answers, e.g. how to test if the spi is after all responding, how to test if the lcd is after all responding,
some hints can probably be found by reading the driver source codes, e.g. those embedded messages would likely show up in dmesg if after all the appropriate driver is loaded
Thank you for the links. I went down a rabbit hole, beginning with those, and ultimately decided to build my own Armbian image. It's building as I type this... results tbd. Hopefully this will eliminate the step referenced in the rPi forum.
Another relevant link or two:
https://github.com/armbian/build/pull/7550 (st7796 patch)(fbtft referenced, although I thought that was dated?)(does this mean I can reference this directly from a dts??)(nevermind, upon review, this is for a rockchip board, not allwinner. leaving link here in case it becomes relevant.)
http://www.lcdwiki.com/res/MSP4021/ST7796S-Sitronix.pdf (datasheet)
http://www.lcdwiki.com/res/MSP3525_MSP3526/ST7796_Init.txt (initialization script, relevant??)
*edit - sidenote - I ordered a rPi a couple weeks ago (as the screen is intended for a rPi) because I was going to give up on getting this screen to work with this board... also, because this board was installed in a 3d printer. Well. I also acquired another 3d printer and another opiz3, so, that opiz3 is running one of the printers, a laptop is running the other two, and THIS opiz3 is set aside specifically to get this damned screen to work with it. The rPi, I'll deal with that later. As things develop with these opiz3's, I'll probably acquire more of them, and continue to experiment. I come from a (amateur) background of server-side web programming and database management, then I got into 3d printers, and as a result, this. So, while I may not have a clue as to what I'm doing at the moment, I'll figure it out, and perhaps, be able to contribute in some meaningful way toward making stuff work with these boards in the future.
afterthoughts
my guess is if you build it from source, look in the same directory trees for the drivers you should find the patched kernel sources and may be there could be the drivers specific to st7796
the kernel sources I'd guess is normally found under
cache/sources/linux-kernel-worktree/
after a build
you could try looking in the further sub trees for panel drivers e.g.
I'm not too sure if it isn't there that if you could patch your files there for the build, I'd think there are other related matters
e.g. how to integrate that in the makefiles, config etc
and there is likely armbian specifics on how to appropriately create the patch
a thing would be to check if st7789 driver works for st7796, st7789 is in the kernel but nothing specific to st7796 at least from the origin source tree.
you could perhaps try the compatible string from the st7789 driver
fbtft may no longer work in the recent kernels e.g. 6.x (i'm not sure about this one)
however, you may nevertheless want to try it out just in case it works after all
https://github.com/armbian/build/blob/bab9b3fbe383a2a2b1224d2bd4ca4d26142ed020/patch/kernel/archive/sunxi-6.6/patches.armbian/Add-FB_TFT-ST7796S-driver.patch#L142
^ note that this is for st7796s
and the relevant github repo is fbtft wiki itself
if you build from source, you could find that under drivers/staging/fbtft in cache/sources/linux-kernel-worktree/
do check if you may need to enable that during config for the kernel build itself
Well, naturally,  I ran into problems building.  I'm building on Ubuntu 24.04 from windows wsl,  and apparently that comes with it's own set of problems.  Chroot wasn't working properly. Found a fix,  implemented, then ran into qemu not working properly. Had to build qemu from source,  then forgot to refix the chroot problem (because I did fresh install of Ubuntu,  thinking that might fix qemu. It didn't. ). Will attempt again tonight and hunt for your references in the process.
you can probably run it directly in the shell that wsl presents, which has to be in Ubuntu itself. But that PREFER_DOCKER=no runs the build directly in that shell without spawning another docker instance.
root (via sudo called internally) is needed to run it, but that it mostly stays within the build folder. root is needed due to the use of loop devices which is used to create the image.
it can be run as root without much fanfare and it should complete a build and leave your image in output/images
flashing that image is the same as how you would when you downloaded it say from Armbian
https://www.armbian.com/orange-pi-zero-3/
building from source opens up all the knobs and switches that you can tweak, I think it is even possible to change the kernel version. standard selections offers current and 'edge'. 'edge' is what I mostly choose as that would be a more recent kernel than stock.
you may need to explicitly 'enable', rather select your board (i.e. orange pi zero 3) from the menu presented during the build
Hi Eric,
if you want to go down the wsl route then have to install windows terminal rathern and run wsl from there as from my own previous attempts got it compiling before running it some strange issue. For any kernel related patching you will need to run ./compile.sh with kernel-patch.
The first number is the port number as Allwinner SOCs have there pins arranged into banks of ports where for example C = 2. The second number is the pin on that port and the third is indeed the active state of the pin.
Indeed, please see here: https://docs.armbian.com/User-Guide_Armbian_overlays/
Dated but not yet removed. Although the patch is specifically target at rockchip, with some adjustments it could be to work with Allwinner. The core display driver will be same regardless of what SOC is driving it, The only thing that differs is the underlying spi implementation. You would need make sure that it is configurable as a loadable module within the sunxi configuration.
Just checked the config menu and under staging/fbtft/ there is an option to configure the ST7796S.
Hope you find this useful
Ryzer
Edited by Ryzer
Additional details
If you are going to build your own armbian, choose linux edge. It provides a recent enough Linux with improvements in the mipi-panel-spi driver.
I didn't say anything about it before, because the latest improvement is for the ili9488, when working in MIPI protocol mode, but you might have a better chance of success with your ST7796.
The GPIO codes are as follows:
PA0= <&pio 0 0 0>
PA1= <&pio 0 1 0>
PB0= <&pio 1 0 0>
PC0= <&pio 2 0 0>
PB1= <&pio 1 1 0>
PC14= <&pio 2 14 0>
There are 2 driver options: staging/fbtft/st7796s, which gets you a classic framebuffer device, and X11 will work
Another is the panel-mipi-dbi-spi driver, which gets you "Direct Rendering Manager", and allows smoother 3D and video acceleration.
Depending on the driver, be aware of the parameter differences: rotate/rotation, active high reset vs active low reset. See my other LCD threads.
Thanks all for the info.  I intend to work on this and have a solution by weeks end, as I think I have all of the info I need to do so.
