compilation logging wrapper proposal
Hello,
When patching or generally compiling, "dialog" is not my friend for reading & testing
I would propose adding a wrapper in common.sh (as in branch "second")
dialog_wrapper () {
        ARGS=$(getopt -o b:p: -l "backtitle:,progressbox:" -n "$0" -- "$@");
        if [ $? -ne 0 ]; then exit 1; fi
        eval set -- "$ARGS";
        unset cmdl
        while true; do
                case "$1" in
                        -b|--backtitle)
                                shift; if [ -n "$1" ]; then cmdl="$cmdl --backtitle '$1'"; shift; fi
                        -p|--progressbox)
                                shift; if [ -n "$1" ]; then cmdl="$cmdl --progressbox '$1'"; shift; fi
                                shift;
                        break;
                esac
        done
        for args in "$@"
        do
                cmdl="$cmdl $args"
        done
        LOGFILE=/dev/null
         if [[ $DIALOG_LOGFILE != "" ]] ; then
                LOGFILE=$DIALOG_LOGFILE
                [ ! -f $DIALOG_LOGFILE  ] && touch $LOGFILE
                lines=$(wc -l <$DIALOG_LOGFILE)
                if [[ $lines -ge 2000 ]]; then
                        rm -f $DIALOG_LOGFILE.log
                        mv $DIALOG_LOGFILE $DIALOG_LOGFILE.log
                        touch $DIALOG_LOGFILE
                fi
        fi
        if [[ $DIALOG_WRAPPER == "" ]] ; then
                tee -a $LOGFILE | eval "dialog $cmdl"
        else
                tee -a $LOGFILE
        fi
and replacing the "dialog" with "dialog_wrapper" for compilation
in "compile.sh", 2 options:
#DIALOG_WRAPPER # use dialog as usual
DIALOG_WRAPPER=1 # dialog is not active
#DIALOG_LOGFILE # logfile is /dev/null
DIALOG_LOGFILE=compile.log
Implemented something similar: https://github.com/zador-blood-stained/lib/commit/8e1551e9faef962d4abca603fe6d8f88d377075b, Igor can merge this if he likes it.
Options are not documented in compile.sh for now and are not dependent on each other. Affect only kernel & u-boot compilation for now.
USE_DIALOG is enabled by default,
USE_DIALOG_LOGGING is disabled by default; writes to output/debug/compilation.log if enabled (also deletes this file before new compilation).
Zador,blood.stained,
Yes great!
it is far far simpler and far much better.
I wanted a wrapper to avoid Igor changes including "\" as well as to keep learning bash/scripting.
dealing with "dialog" non-standard parameters is pretty hard.
Thanks!
