Walter Zambotti Posted January 1, 2025 Posted January 1, 2025 (edited) After an update to Armbian 23.05.1 Ubuntu one of my Wifi adapters no longer sees any access point and can't be forced to connect blindly. The two adapters are very similar: The two adapters are very similar: Working Wifi Module 5B: |__ Port 2: Dev 9, If 2, Class=Vendor Specific Class, Driver=rtl8821cu, 480M ID 0bda:c820 Realtek Semiconductor Corp. /sys/bus/usb/devices/1-1.2 /dev/bus/usb/001/009 Not working Wifi Module 5A: |__ Port 4: Dev 10, If 0, Class=Vendor Specific Class, Driver=rtl88XXau, 480M ID 0bda:a811 Realtek Semiconductor Corp. RTL8811AU 802.11a/b/g/n/ac WLAN Adapter /sys/bus/usb/devices/1-1.4 /dev/bus/usb/001/010``` nmcli shows both devices nmcli device DEVICE TYPE STATE CONNECTION wlx200bd04dc584 wifi connected asuszamb 2 wlx40a5eff399ea wifi disconnected -- p2p-dev-wlx200bd04dc584 wifi-p2p disconnected -- p2p-dev-wlx40a5eff399ea wifi-p2p disconnected -- eth0 ethernet unavailable -- lo loopback unmanaged -- wlx40a5eff399ea is the device that has stopped working. if I display the access points visible to each device: nmcli device wifi list ifname wlx200bd04dc584 IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS SECURITY 3C:7C:3F:6B:EA:2C asuszamb Infra 36 540 Mbit/s 95 ▂▄▆█ WPA2 3C:7C:3F:6B:EA:28 asuszamb Infra 2 405 Mbit/s 74 ▂▄▆_ WPA2 32:46:9A:FF:E2:B9 asuszamb_EXT Infra 10 130 Mbit/s 64 ▂▄▆_ WPA2 4C:0F:6E:AD:AB:07 PS3-1880660 Infra 10 54 Mbit/s 39 ▂▄__ WPA1 6A:19:4D:28:72:DD -- Infra 161 540 Mbit/s 25 ▂___ WPA2 B0:92:4A:C7:E2:BD OPTUS_C7E2BBM Infra 11 540 Mbit/s 20 ▂___ WPA2 WPA3 72:19:4D:28:72:DC OPTUS_C7E2BBM Infra 11 130 Mbit/s 17 ▂___ WPA2 WPA3``` The other adapter should show the same access points but: nmcli device wifi list ifname wlx40a5eff399ea IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS SECURITY Attempting to make a connection via the not working adapter results in: nmcli con up 175a67a0-d58d-4ebe-8d02-6f3c741c460b ap 3C:7C:3F:6B:EA:2C ifname wlx40a5eff399ea Error: device 'wlx40a5eff399ea' not compatible with connection 'asuszamb'. Edited January 1, 2025 by Walter Zambotti 0 Quote
