cannot boot from MicroSD - "failed to mount mmcblk0" and "cannot load volume /misc"
Hello guys,
it's day i'm trying everything to let my S905x TV Box run Armbian but i keep struggle at toothpick multiboot.
Android recovery stays with the green android with the ! out of its tummy and hang with the "Cannot load volume /misc!" error.
I opened the log and find out "failed to mount /dev/block/mmcblk0 on /sdcard by read-only (Device or resource busy)".
I downloaded the image and wrote it on a 32GB MicroSD card via Rufus,
Could someone please suggest me how to proceed?
Thank you,
Marco
As i wrote (and i remember well) i didn't install anything on the box.
Lakka boot from microSD, if i remove It the regular tvbox system will load.
I also tried using the tvbox update application but It doesn't find any file.
The instructions don't say install, they say run.  Running from SD card may/will change the boot environment on the mmc and prevent armbian from booting.  If you have ever *run* another distribution on the box armbian may not run.  You need to reinstall the original android firmware to reset things back to what armbian expects.
