Apologies this isnt about Orange Pi Zero 2, but about a TV stick called Tronsmart Draco H3 which I have and am trying to repurpose into a light weight server with armbian. It obviously isnt well known, but I have tried a few H3 based builds, all of them boot fine, but I cant seem to get Wifi running.
I tried Orange Pi PC and Orange Pi but they dont have Wifi at all I believe, so it didnt ask to setup wifi.
I tried Orange Pi Zero 2+H3, but for some odd reason my keyboard didnt work on it, so I couldnt setup the users to be able to get further.
I tried Nano Pi R1, but that didnt have HDMI, so my hdmi didnt work and I had no idea how to view the output at that point.
I tried Orange Pi + as that had wifi as well, but the wifi wasnt able to be configured.
I then figured that I need to get a board with the same wifi chipset as mine, and settled on Banana Pi M2+ which matched on RAM, SOC and Wifi chipset, but it still had the same problem as Orange Pi+ in that it asked to setup wifi, but then fails immediately with unable to configure.
Any tips on how I can proceed? I understand that recovering esoteric TV boxes isnt looked on fondly here, but I am curious to see if I can make this work.
p.s. Ethernet does work with this box and the banana pi m2 + build, but I would need an ethernet to USB dongle, and ofc the cable.
Thank you so much for the response.
>Maybe you are missing the drivers for your wifi.
I assumed that, wouldnt Banana Pi M2 +, having the same chipset as mine,  use the same driver? Is it just a matter of turning it on somewhr?
> You can find the firmware in your original Android backup.
I really wish I hadnt written to emmc.. or had taken a backup before that 😐 let me try to do more research and see if I can find firmware for this thing.
If you are sure Banana Pi M2 + has the same wifi chip as yours then it should work. Can post your dmesg.
Edited by Nick A
@Nick A I am going based purely on the fact that the 2 sunxi links I posted above both reference `Ampak AP6212`. I am quite new to this level of armbian/linux, and am not sure if
1. The wiki is accurate. For the draco, I havent opened the case yet because it seems quite fiddly and might be destructive to open.
2. If there are differences between revisions/versions of the boards which means there is a difference from the build to my tv stick.
3. If Ampak AP6212 means the same firmware or if there are revisions within this chipset itself.
I will check and post the dmesg tonight.
Hey, @Nick A here is the dmesg https://pastebin.com/AKP6tdKX
The relevant bit is likely
[    7.668535] r8152 2-1.3:1.0: Direct firmware load for rtl_nic/rtl8153a-4.fw failed with error -2
[    7.668569] r8152 2-1.3:1.0: Falling back to sysfs fallback for: rtl_nic/rtl8153a-4.fw
[    7.679766] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430a0-sdio.clm_blob failed with error -2
[    7.679798] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43430a0-sdio.clm_blob
[    7.736675] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[    7.768622] systemd[1]: Reached target bluetooth.target - Bluetooth Support.
[    7.780124] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    7.780153] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    7.780892] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/0 wl0: Jul  1 2016 18:02:40 version 7.10.1 (A0 Station/P2P feature) FWID 01-bae8afee
[    7.784507] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[    7.816592] zram0: detected capacity change from 0 to 1020768
[    7.828732] Bluetooth: hci0: BCM: chip id 94
[    7.829421] Bluetooth: hci0: BCM: features 0x2e
[    7.831802] Bluetooth: hci0: 4343A0
[    7.831843] Bluetooth: hci0: BCM4343A0 (001.001.034) build 0000
[    7.837654] Bluetooth: hci0: BCM4343A0 'brcm/BCM4343A0.hcd' Patch
[    7.852062] Adding 510380k swap on /dev/zram0.  Priority:5 extents:1 across:510380k SS
[    8.092132] zram1: detected capacity change from 0 to 102400
[    8.143675] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[    8.173101] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[    8.258237] EXT4-fs (zram1): mounted filesystem a960efb7-2ddb-4b74-b890-02db439f3633 r/w without journal. Quota mode: none.
[    8.617334] Bluetooth: hci0: BCM: features 0x2e
[    8.620034] Bluetooth: hci0: BCM4343A0 26MHz AP6212_CL1 OTP_BD-0061
[    8.620075] Bluetooth: hci0: BCM4343A0 (001.001.034) build 0245
[    8.729100] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[    8.756443] systemd[1]: Starting systemd-journald.service - Journal Service...
[   12.827907] systemd[1]: systemd-rfkill.service: Deactivated successfully.
[   68.599453] r8152 2-1.3:1.0: unable to load firmware patch rtl_nic/rtl8153a-4.fw (-110)
[   68.634262] r8152 2-1.3:1.0 eth0: v1.12.13
[   68.634675] usbcore: registered new interface driver r8152
[   68.647431] usbcore: registered new interface driver cdc_ether
[   68.650104] usbcore: registered new interface driver r8153_ecm
[   68.708140] systemd[1]: Started systemd-journald.service - Journal Service.
[   68.768773] systemd-journald[388]: Received client request to flush runtime journal.
[   68.771384] r8152 2-1.3:1.0 enxa0cec873285e: renamed from eth0
[   70.227164] r8152 2-1.3:1.0 enxa0cec873285e: carrier on
[    7.279210] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430a0-sdio for chip BCM43430/0
[    7.284105] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430a0-sdio.sinovoip,bpi-m2-plus.bin failed with error -2
[    7.284142] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43430a0-sdio.sinovoip,bpi-m2-plus.bin
You need to rename "brcmfmac43430a0-sdio.bin" to "brcmfmac43430a0-sdio.sinovoip,bpi-m2-plus.bin"
Edited by Nick A
I did a symlink to a clm_blob that was present and the dmesg changed a bit.
[    7.548281] r8152 2-1.3:1.0: Falling back to sysfs fallback for: rtl_nic/rtl8153a-4.fw
[    7.608116] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[    7.633616] systemd[1]: Reached target bluetooth.target - Bluetooth Support.
[    7.653242] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[    7.678063] zram0: detected capacity change from 0 to 1020768
[    7.679530] ieee80211 phy0: brcmf_c_download_blob: clmload (4733 byte file) failed (-52)
[    7.680437] ieee80211 phy0: brcmf_c_download_blob: get clmload_status failed (-52)
[    7.680473] ieee80211 phy0: brcmf_c_preinit_dcmds: download CLM blob file failed, -5
[    7.680486] ieee80211 phy0: brcmf_bus_started: failed: -5
[    7.680513] ieee80211 phy0: brcmf_attach: dongle is not responding: err=-5
[    7.707369] brcmfmac: brcmf_sdio_firmware_callback: brcmf_attach failed
[    7.711698] Adding 510380k swap on /dev/zram0.  Priority:5 extents:1 across:510380k SS
[    7.947193] zram1: detected capacity change from 0 to 102400
Err... I have no idea what happened.. In all this resets I check `ip addr` and I see wlan0 thr.. I could swear I checked it and it wasnt before.. I installed `network-manager` and was able to get the wifi connected and working..
