Alex Trezvy Posted January 7, 2025 Posted January 7, 2025 (edited) I have "x96 mini" TV box with seemingly broken eMMC chip (unable to write firmware by USB). S905W SoC. First I've tested if it can boot from SD-card, made with Amlogic Windows utility "Burn Card Maker". The answer is: yes (see the logs below). Spoiler GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;0.0;CHK:0; no sdio debug board detected TE: 197450 BL2 Built : 20:32:17, Sep 8 2017. gxl g6296b83 - xiaobo.gu@droid12 set vcck to 1120 mv set vddee to 1070 mv Board ID = 2 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 792MHz Rank0: 2048MB(auto)-2T-11 DataBus test pass! AddrBus test pass! Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x0002c600 Load bl33 from SD, src: 0x00050200, des: 0x01000000, size: 0x00065e00 NOTICE: BL3-1: v1.0(release):a625749 NOTICE: BL3-1: Built : 11:25:15, Aug 25 2017 [BL31]: GXL CPU setup! NOTICE: BL31: BL33 decompress pass mpu_config_enable:ok [Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07] OPS=0xa4 b4 6d 77 fb b7 65 f0 73 5a c7 83 46 [0.547161 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01-g2d1a155-dirty (Oct 08 2017 - 12:02:50) DRAM: 2 GiB Relocation Offset is: 76eb3000 register usb cfg[0][1] = 0000000077f5a960 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 Second, I've followed the manual. I've copied the file 'u-boot-s905x-s912' to 'u-boot.ext'. I also edited the file 'extlinux.conf', pointing it to 'meson-gxl-s905w-p281.dtb'. The result is in the logs. Spoiler GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:1;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:2;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:3;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:4;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:5;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8;LOOP:6;EMMC:800;NAND:81;SD:0;READ:0;CHK:A7;USB:8; The question is: how to boot the device from the SD card? Should I use somehow the original's firmware u-boot (as it works with the the factory firmware)? The SD card was made with 'Balena etcher'. Armbian image was build from gitub repo ("Armbian-unofficial_24.11.1_Aml-s9xx-box_bookworm_current_6.6.62_minimal.img"). Edited January 7, 2025 by Alex Trezvy 0 Quote
SteeMan Posted January 7, 2025 Posted January 7, 2025 10 hours ago, Alex Trezvy said: TV box with seemingly broken eMMC chip If your emmc isn't working you won't be able to run the aml-s9xx-tvbox Armbian builds. Those builds use the original boxes uboot on emmc to boot from. So you need an intact working emmc with the original android uboot working. 0 Quote
Alex Trezvy Posted January 7, 2025 Author Posted January 7, 2025 (edited) 50 minutes ago, SteeMan said: Those builds use the original boxes uboot on emmc to boot from. Sounds weird: 1. We have a couple of "u-boot" files in Armbian img. Including the one that must be copied into "u-boot.ext". 2. There is manual that explains how to make a bootable SD-card with original firmware manually. It should be possible to run Armbian's "u-boot.ext" from SD-card, like it is possible to run original u-boot extracted from an image. Why not? Edited January 7, 2025 by Alex Trezvy 0 Quote
