Hello all,
I installed armbian on my TV box. It work correctly (I installed home assistant and It work properly).
however, I have a problem with bluetooth. It doesn't work. I do some investigation :
install the bluetooth support with apt-get update && apt-get install bluetooth
check if this work with : service bluetooth status and it return bluetooth is running
I try to connect device with bluetoothctl and it not working. It return No default controller available
version :
v25.02.0 for Aml.S912 running Armbian Linux 6.6.67-merry-christmas
Packages: Debian stable (bullseye)
I use this dtb file : meson-gxm-q201.dtb. I tried Different dtb file but it was not possible to install armbian. (I didn't try all files...)
TVBox : Bqeel K12 (I opened the box and it's write on mother card Mini M8S pro C (S912))
wirless module is Fn-link 8223A-SR
never heard of that one before. image name and source?
Edit: Found. You are not using Armbian but a fork. We cannot support 3rd party images. Ask at the place where you got the image from for help.
  • Werner locked this topic
