Hello guys,
is it possible to build custom source code in customize-image.sh ?
Seems like /tmp/overlay is read-only, can I use another location to git clone my source code, make and install in target file system ?
My idea is to build & deploy sources using native gcc compiler.
Thanks
You can use any directory, i.e. you can create a new directory under /tmp and remove it afterwards.
/tmp/overlay is currently mounted as read-only, but I may revert it to rw later if it won't cause any problems.
Hello again,
I tried like you said but it didn't work.
My custom directory that I created in userpatches is not visible in /tmp during build, there are only customize-image and overlay folder visible.
I can use customize-image-host.sh to mount my own dir without readonly bu there is no way to unmount it without changing compilation.sh. Not sure if is critical to unmount it.
Any suggestions ?
Thanks
I meant that contents of userpatches/overlay will be visible in /tmp/overay inside, there are no other (easy) ways to transfer files between the host and chroot environment. You can create a temp directory from customize-image.sh to use for cross-compilation or building if you need to.
Any suggestions ?
What do you want to do exactly? Transfer files from chroot to host?
I want to build QT5 in chroot and then install it to /usr/local.
Ok, so I can create a folder like /tmp/build, git clone there, build and install, right ?  All this can be done from customize-image.sh ?
Yes, assuming there is enough RAM to do this (since temporary rootfs lives in tmpfs by default), if you encounter "out of space" errors you may need to use FORCE_USE_RAMDISK=no parameter.
I tried to compile QT5 from customize-image.sh using target gcc but it is way too slow than normal cross-compile using linaro toolchain...
And so I am going to stick with linaro cross-compile.
Can you give me an advice about the following scenario.
I want to cross-compile QT5 from customize-image-host.sh script, i.e. git clone and make (with linaro toolchain) in userpatches directory, then copy binaries to userpatches/overlay and install to target fs from customize-image.sh script.
So far so good but I in order to build QT5 I need a device SYSROOT (/usr/lib, /usr/include, etc) which is not prepared yet when customize-image-host.sh is executed.
SYSROOT is prepared with customize-image.sh and it does not contain all required libs & headers when customize-image-host.sh is executed.
customize-image-host.sh is called almost right before the customize-image.sh. If you are using customize-image-host.sh you may as well do everything in it, use $SDCARD variable to get a path to the rootfs and use chroot $SDCARD to execute anything in chroot
