JamesCL Posted April 6 Author Posted April 6 (edited) I just created a new image and am reporting the following: - On the first boot, I don't have Ethernet (I don't use wireless) and - The eMMC is not detected. Thanks Quote root@orangepi-4a:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi-4a BOARD_NAME="Orange Pi 4A" BOARDFAMILY=sun55iw3 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=28862c7 LINUXFAMILY=sunxi64 ARCH=arm64 BOOT_SOC= IMAGE_TYPE=user-built BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image KERNEL_TARGET=edge KERNEL_TEST_TARGET= FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= OVERLAY_DIR="/boot/dtb/allwinner/overlay" VENDOR="Armbian-unofficial" VENDORCOLOR="247;16;0" VENDORDOCS="https://docs.armbian.com/" VENDORURL="https://duckduckgo.com/" VENDORSUPPORT="https://community.armbian.com/" VENDORBUGS="https://armbian.atlassian.net/" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=26.05.0-trunk REVISION=26.05.0-trunk BRANCH=edge root@orangepi-4a:~# root@orangepi-4a:~# root@orangepi-4a:~# dmesg | grep -i mmc [ 4.418379] sunxi-mmc 4020000.mmc: Got CD GPIO [ 4.418857] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 4.444666] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.444692] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.445215] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.487006] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.490389] mmc0: new high speed SDXC card at address aaaa [ 4.497740] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 4.522286] mmcblk0: p1 p2 [ 4.585097] mmc2: error -110 whilst initialising MMC card [ 4.592377] mmc1: new high speed SDIO card at address 0001 [ 4.596828] mmc2: Failed to initialize a non-removable card [ 7.193467] EXT4-fs (mmcblk0p2): mounted filesystem 757e37e7-0e5e-4683-8110-4a8276f032d5 ro with writeback data mode. Quota mode: none. [ 10.627502] EXT4-fs (mmcblk0p2): re-mounted 757e37e7-0e5e-4683-8110-4a8276f032d5 r/w. [ 12.277240] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.xunlong,orangepi-4a.bin failed with error -2 root@orangepi-4a:~# root@orangepi-4a:~# root@orangepi-4a:~# uname -a Linux orangepi-4a 7.0.0-rc6-edge-sunxi64 #2 SMP PREEMPT Sun Mar 29 22:40:00 UTC 2026 aarch64 GNU/Linux root@orangepi-4a:~# Edited April 6 by JamesCL 0 Quote
sergiyd Posted April 7 Posted April 7 @Werner I imagine there are plenty of people here who could help solve similar problems. In theory, I could provide a pair of an old RPI (master) and a 4A (slave), with the slave serial connected to the master and power controlled via the GPIO, and they are also on the same VLAN. However, if something goes wrong it needs control to the slave's SD card, all I've found is an SD card extender, and it needs something like an emulator that connects to the master via the same USB/SPI. 0 Quote
ioncube Posted April 15 Posted April 15 Anyone has a working image with GPU / VPU support? In the official Jammy I am using VPU is supported via gstreamer / CEDRA https://github.com/defencedog/orangepi4A/tree/main/GPU_VPU 0 Quote
Edmilson Santos Posted April 15 Posted April 15 @ioncube Were you able to use VPU with Jellyfin? 0 Quote
sergiyd Posted May 2 Posted May 2 (edited) Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration? Edited May 2 by sergiyd 0 Quote
Evgeniy evotronik Posted May 10 Posted May 10 (edited) extraargs=nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off to /boot/armbianEnv.txt fixes nvme detection the temperature is echo "$(( $(cat /sys/class/hwmon/hwmon0/temp1_input) / 1000 )) °C" if you copy the system to nvme and wanna boot with microsd (spi doesn't work for now): 1) it will actually boot but without boot mountpoint 2) mount /boot and /media/mmcboot manually 3) fix fstab Edited May 11 by Evgeniy evotronik 0 Quote
Evgeniy evotronik Posted Saturday at 01:17 AM Posted Saturday at 01:17 AM (edited) to start ethernet #!/bin/bash echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/unbind 2>/dev/null echo 271 > /sys/class/gpio/export 2>/dev/null echo out > /sys/class/gpio/gpio271/direction 2>/dev/null echo 0 > /sys/class/gpio/gpio271/value 2>/dev/null sleep 0.1 echo 1 > /sys/class/gpio/gpio271/value 2>/dev/null sleep 0.3 echo 271 > /sys/class/gpio/unexport 2>/dev/null echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/bind 2>/dev/null just systemd it [Unit] Description=Fix ethernet PHY on cold boot After=multi-user.target [Service] Type=oneshot ExecStart=/usr/local/bin/fix-eth.sh RemainAfterExit=yes [Install] WantedBy=multi-user.target Edited Saturday at 01:19 AM by Evgeniy evotronik 0 Quote
JamesCL Posted Saturday at 01:28 AM Author Posted Saturday at 01:28 AM Hi ... Thanks @Evgeniy evotronik. Yesterday I downloaded the image "Armbian_community_26.2.0-trunk.886_Orangepi-4a_trixie_edge_7.0.5_minimal.img.xz", but the Ethernet and eMMC issues are still present. I will apply the Ethernet patch. Thanks again. 0 Quote
Evgeniy evotronik Posted Saturday at 01:42 AM Posted Saturday at 01:42 AM (edited) @JamesCl Sorry, It's ok with 100m, but 1000m also doesn't receive an ip with dhcp. Guess it is a dtb problem or maybe uboot Edited Saturday at 01:43 AM by Evgeniy evotronik 0 Quote
JamesCL Posted Saturday at 03:02 AM Author Posted Saturday at 03:02 AM The eMMC is still not detected. Kernel log: [ 4.621568] mmc2: error -110 whilst initialising MMC card [ 4.627066] mmc2: Failed to initialize a non-removable card Working devices: [ 4.502846] mmc0: new high speed SDXC card at address aaaa [ 4.508907] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 4.551951] mmc1: new high speed SDIO card at address 0001 The system boots correctly from the SD card, but the onboard eMMC (mmc2) is not initialized. There are also still Ethernet issues. After connecting through PuTTY, the system sometimes hangs when running dmesg, and the network connection becomes unstable or unresponsive. System information: Quote root@orangepi-4a:~# uname -a Linux orangepi-4a 7.0.7-edge-sunxi64 #1 SMP PREEMPT Thu May 14 13:31:20 UTC 2026 aarch64 GNU/Linux root@orangepi-4a:~# cat /etc/os-release PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.4 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie" root@orangepi-4a:~# Thanks 0 Quote
Evgeniy evotronik Posted Saturday at 04:50 PM Posted Saturday at 04:50 PM guess it kernel/driver issue The driver does not request the stmmaceth (emac1-25M) clock during probe. Without this clock the MDIO bus does not function on cold boot - PHY ID reads as 0x00000000 and kernel falls back to Generic PHY instead of YT8531. Ethernet does not work until warm reboot. 1 Quote
JamesCL Posted 47 minutes ago Author Posted 47 minutes ago @Evgeniy evotronik When I switch from 1 Gbps to 100 Mbps... Ethernet returns to normal. 0 Quote
