JamesCL Posted April 6 Author Posted April 6 (edited) I just created a new image and am reporting the following: - On the first boot, I don't have Ethernet (I don't use wireless) and - The eMMC is not detected. Thanks Quote root@orangepi-4a:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi-4a BOARD_NAME="Orange Pi 4A" BOARDFAMILY=sun55iw3 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=28862c7 LINUXFAMILY=sunxi64 ARCH=arm64 BOOT_SOC= IMAGE_TYPE=user-built BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image KERNEL_TARGET=edge KERNEL_TEST_TARGET= FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= OVERLAY_DIR="/boot/dtb/allwinner/overlay" VENDOR="Armbian-unofficial" VENDORCOLOR="247;16;0" VENDORDOCS="https://docs.armbian.com/" VENDORURL="https://duckduckgo.com/" VENDORSUPPORT="https://community.armbian.com/" VENDORBUGS="https://armbian.atlassian.net/" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=26.05.0-trunk REVISION=26.05.0-trunk BRANCH=edge root@orangepi-4a:~# root@orangepi-4a:~# root@orangepi-4a:~# dmesg | grep -i mmc [ 4.418379] sunxi-mmc 4020000.mmc: Got CD GPIO [ 4.418857] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 4.444666] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.444692] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.445215] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 4.487006] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.490389] mmc0: new high speed SDXC card at address aaaa [ 4.497740] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 4.522286] mmcblk0: p1 p2 [ 4.585097] mmc2: error -110 whilst initialising MMC card [ 4.592377] mmc1: new high speed SDIO card at address 0001 [ 4.596828] mmc2: Failed to initialize a non-removable card [ 7.193467] EXT4-fs (mmcblk0p2): mounted filesystem 757e37e7-0e5e-4683-8110-4a8276f032d5 ro with writeback data mode. Quota mode: none. [ 10.627502] EXT4-fs (mmcblk0p2): re-mounted 757e37e7-0e5e-4683-8110-4a8276f032d5 r/w. [ 12.277240] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.xunlong,orangepi-4a.bin failed with error -2 root@orangepi-4a:~# root@orangepi-4a:~# root@orangepi-4a:~# uname -a Linux orangepi-4a 7.0.0-rc6-edge-sunxi64 #2 SMP PREEMPT Sun Mar 29 22:40:00 UTC 2026 aarch64 GNU/Linux root@orangepi-4a:~# Edited April 6 by JamesCL 0 Quote
sergiyd Posted April 7 Posted April 7 @Werner I imagine there are plenty of people here who could help solve similar problems. In theory, I could provide a pair of an old RPI (master) and a 4A (slave), with the slave serial connected to the master and power controlled via the GPIO, and they are also on the same VLAN. However, if something goes wrong it needs control to the slave's SD card, all I've found is an SD card extender, and it needs something like an emulator that connects to the master via the same USB/SPI. 0 Quote
ioncube Posted April 15 Posted April 15 Anyone has a working image with GPU / VPU support? In the official Jammy I am using VPU is supported via gstreamer / CEDRA https://github.com/defencedog/orangepi4A/tree/main/GPU_VPU 0 Quote
Edmilson Santos Posted April 15 Posted April 15 @ioncube Were you able to use VPU with Jellyfin? 0 Quote
sergiyd Posted May 2 Posted May 2 (edited) Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration? Edited May 2 by sergiyd 0 Quote
Evgeniy evotronik Posted May 10 Posted May 10 (edited) extraargs=nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off to /boot/armbianEnv.txt fixes nvme detection the temperature is echo "$(( $(cat /sys/class/hwmon/hwmon0/temp1_input) / 1000 )) °C" if you copy the system to nvme and wanna boot with microsd (spi doesn't work for now): 1) it will actually boot but without boot mountpoint 2) mount /boot and /media/mmcboot manually 3) fix fstab Edited May 11 by Evgeniy evotronik 0 Quote
Evgeniy evotronik Posted May 16 Posted May 16 (edited) to start ethernet #!/bin/bash echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/unbind 2>/dev/null echo 271 > /sys/class/gpio/export 2>/dev/null echo out > /sys/class/gpio/gpio271/direction 2>/dev/null echo 0 > /sys/class/gpio/gpio271/value 2>/dev/null sleep 0.1 echo 1 > /sys/class/gpio/gpio271/value 2>/dev/null sleep 0.3 echo 271 > /sys/class/gpio/unexport 2>/dev/null echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/bind 2>/dev/null just systemd it [Unit] Description=Fix ethernet PHY on cold boot After=multi-user.target [Service] Type=oneshot ExecStart=/usr/local/bin/fix-eth.sh RemainAfterExit=yes [Install] WantedBy=multi-user.target Edited May 16 by Evgeniy evotronik 0 Quote
JamesCL Posted May 16 Author Posted May 16 Hi ... Thanks @Evgeniy evotronik. Yesterday I downloaded the image "Armbian_community_26.2.0-trunk.886_Orangepi-4a_trixie_edge_7.0.5_minimal.img.xz", but the Ethernet and eMMC issues are still present. I will apply the Ethernet patch. Thanks again. 0 Quote
Evgeniy evotronik Posted May 16 Posted May 16 (edited) @JamesCl Sorry, It's ok with 100m, but 1000m also doesn't receive an ip with dhcp. Guess it is a dtb problem or maybe uboot Edited May 16 by Evgeniy evotronik 0 Quote
JamesCL Posted May 16 Author Posted May 16 The eMMC is still not detected. Kernel log: [ 4.621568] mmc2: error -110 whilst initialising MMC card [ 4.627066] mmc2: Failed to initialize a non-removable card Working devices: [ 4.502846] mmc0: new high speed SDXC card at address aaaa [ 4.508907] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 4.551951] mmc1: new high speed SDIO card at address 0001 The system boots correctly from the SD card, but the onboard eMMC (mmc2) is not initialized. There are also still Ethernet issues. After connecting through PuTTY, the system sometimes hangs when running dmesg, and the network connection becomes unstable or unresponsive. System information: Quote root@orangepi-4a:~# uname -a Linux orangepi-4a 7.0.7-edge-sunxi64 #1 SMP PREEMPT Thu May 14 13:31:20 UTC 2026 aarch64 GNU/Linux root@orangepi-4a:~# cat /etc/os-release PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.4 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie" root@orangepi-4a:~# Thanks 0 Quote
Evgeniy evotronik Posted May 16 Posted May 16 guess it kernel/driver issue The driver does not request the stmmaceth (emac1-25M) clock during probe. Without this clock the MDIO bus does not function on cold boot - PHY ID reads as 0x00000000 and kernel falls back to Generic PHY instead of YT8531. Ethernet does not work until warm reboot. 1 Quote
JamesCL Posted May 19 Author Posted May 19 @Evgeniy evotronik When I switch from 1 Gbps to 100 Mbps... Ethernet returns to normal. 0 Quote
sergiyd Posted May 20 Posted May 20 This device is currently an outcast here, and until someone with understanding sets out to fix at least the main problems, welcome to the official image on the 5.15 kernel. 1 Quote
bickns Posted June 25 Posted June 25 Greetings - just investigating an issue with the opi-4a Armbian 26.8.0 minimal (edge 7.0.12) build - not getting past starting kernel. The board has a T527 - Hopefully this information is useful ? ### [Bug Report] Orange Pi 4A - Silent Hang at 'Starting kernel ...' (Trixie Minimal) **Board:** Orange Pi 4A (Allwinner A523/T527) **Image used:** Debian Trixie Minimal (Built via armbian-imager) **Installation Media:** SD Card (Class 10) **Log Type:** UART Serial Console Output (115200 baud) --- #### Description of Issue The recent community build of Debian Trixie Minimal for the Orange Pi 4A successfully clears the U-Boot / SPL stages, loads the Ramdisk and DTB from the SD card, but hangs completely silently immediately after hitting `Starting kernel ...`. The onboard status LED remains solid red with no flashing activity. #### The Technical Root Cause Looking closely at the UART initialization text, there appears to be a mismatch between the SoC detected by the low-level firmware and the Device Tree Blob (DTB) loaded by the Armbian boot script: 1. **Firmware/U-Boot Chip Detection:** TF-A and U-Boot explicitly identify the SoC as an **Allwinner A523**: ```text NOTICE: BL31: Detected Allwinner A523 SoC (1890) CPU: Allwinner A523 (SUN55I) ``` 2. **Script DTB Selection:** Immediately afterward, the automated script loads a **T527 DTB** profile: ```text Load fdt: /dtb/allwinner/sun55i-t527-orangepi-4a.dtb ``` Because the kernel tries to initialize the primary power rails and clock gates using a T527 map on an A523 layout, the CPU locks up silently at the execution handoff. --- #### Complete Boot Log (Up to the Hang) ```text U-Boot SPL 2026.01_armbian-2026.01-S127a-P60fe-Hc6a9-Vf757-Bd0d2-R448a (May 30 2026 - 05:53:33 +0000) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.13.0(debug):armbian NOTICE: BL31: Built : 05:52:43, May 30 2026 NOTICE: BL31: Detected Allwinner A523 SoC (1890) NOTICE: BL31: Found U-Boot DTB at 0xa0b8ac0, model: OrangePi 4A INFO: Configuring SPC Controller INFO: BL31: Platform setup done INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: BL31: Initializing runtime services INFO: BL31: cortex_a55: CPU workaround for erratum 1530923 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2026.01_armbian-2026.01-S127a-P60fe-Hc6a9-Vf757-Bd0d2-R448a (May 30 2026 - 05:53:33 +0000) Allwinner Technology CPU: Allwinner A523 (SUN55I) Model: OrangePi 4A DRAM: 2 GiB sunxi_set_gate: (CLK#35) unhandled Core: 94 devices, 24 uclasses, devicetree: separate WDT: Not starting watchdog@2050000 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1... In: serial@2500000 Out: serial@2500000 Err: serial@2500000 Net: No ethernet found. starting USB... USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 Bus usb@4101000: 1 USB Device(s) found Bus usb@4101400: 1 USB Device(s) found Bus usb@4200000: 2 USB Device(s) found Bus usb@4200400: 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 PCIe: Acquiring resources... PCIe: Failed to get switch-sel GPIO: -2 PCIe: Hardware init failed with error -2 Device 0: unknown device switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr 4641 bytes read in 2 ms (2.2 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 249 bytes read in 2 ms (121.1 KiB/s) Load fdt: /dtb/allwinner/sun55i-t527-orangepi-4a.dtb 33383 bytes read in 7 ms (4.5 MiB/s) Working FDT set to 4fa00000 Failed to load '/dtb/allwinner/overlay/sun55i-t527-fixup.scr' 16748327 bytes read in 814 ms (19.6 MiB/s) 41171456 bytes read in 1707 ms (23 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42a30000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16748263 Bytes = 16 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 49007000, end 49fffee7 ... OK Loading Device Tree to 0000000048f96000, end 0000000049006fff ... OK Working FDT set to 48f96000 Starting kernel ... ``` 0 Quote
bickns Posted June 25 Posted June 25 Greetings ### [Follow-up Update] Boot Deep-Dive via Cubie-A5E DTB Masking Following up on my previous boot freeze post, I (with some assistance from Gemini - who formatted this post) managed to force the Armbian kernel to initialize by masking the sister chip profile (`sun55i-a523-cubie-a5e.dtb`) over the broken `sun55i-t527-orangepi-4a.dtb` target and injecting `clk_ignore_unused` / `irqpoll` parameters. This got us past the initial handoff hang and successfully spawned the 8-core CPU array initialization and initramfs launch (`Run /init as init process`), but the system eventually hit a permanent deadlock during the device probe phase. I don't think I can get this to go any further without some many hours spent looking at how these things work and its currently 35 degrees C here in the UK so time for a beer methinks! #### Full Boot Log Paste Link: - this is the log before using irqpoll parameter (which eventually caused a deadlock) - I can post the irqpoll logs although i wouldn't have thought irqpolling is the way to go ? https://pastebin.com/TvxTxdbp ### Either way - having just read that this post refers to irqpoll then this is the boot logfile with irqpoll added an an extraparm https://pastebin.com/TNS3DDTC #### Key Technical Takeaways from the Log Dump: 1. **PMIC / I2C Communication Failures:** The kernel initializes the AXP717 and AXP323 power chips but encounters standard timeout errors right away: ```text axp20x-i2c 0-0034: AXP20x variant AXP717 found axp20x-i2c 0-0034: Failed to set masks in 0x40: -6 axp20x-i2c 0-0034: failed to add irq chip: -6 ``` 2. **MMC / Storage Controller Deadlock:** Because the AXP717 framework drops out and the Cubie pin definitions do not line up with the Orange Pi 4A's physical board wiring, the kernel enters an endless loop waiting for internal voltage rails (`cldo3` and `bldo1`) to power up the storage controller: ```text platform 4020000.mmc: deferred probe pending: platform: wait for supplier /soc/i2c@7081400/pmic@34/regulators/cldo3 platform 4021000.mmc: deferred probe pending: platform: wait for supplier /soc/i2c@7081400/pmic@34/regulators/bldo1 ``` This prevents the storage device slot from spinning up, trapping the system right as it attempts to mount the root filesystem. Hopefully this helps isolate the unaligned power configuration loops and clock tables in the current `armbian-imager` source profile for the OPi 4A! 0 Quote
bickns Posted June 30 Posted June 30 Title: [Working Image + Patch] Orange Pi 4A (T527) - Fast Ethernet Fixed on Mainline 7.0 Edge Hi everyone, Since the Orange Pi 4A (Allwinner T527) is currently an unmaintained community target on the bleeding-edge Mainline 7.0 Edge branch, the default images boot up completely blind with cannot attach to PHY (error: -ENODEV) errors. After a lot of debugging, I (with assistance from Gemini - who wrote this post) managed to successfully compile a full, functional Debian Trixie image where Ethernet works perfectly (capped at 100M) and the green status LED pulses a native heartbeat. The secret sauce is that the board uses a Motorcomm YT8531 transceiver, but the kernel falls back to a Generic PHY driver which fails to calibrate the high-frequency RGMII clock skews required for Gigabit speeds. Dropping the link frequency down to 100 Mbps Full Duplex bypasses the timing sensitivity completely, allowing NetworkManager to instantly pull a stable IPv4 DHCP lease! (Note: Mainline 7.0 does not yet have internal C drivers for the T527 audio codec or the SDIO mmc1 bus clocks, so internal audio and onboard Wi-Fi remain offline. Use a USB sound/Wi-Fi dongle if needed). I can't vouch whether HDMI is working or not as I was debugging it using a serial cable. 📦 Download the Image https://drive.google.com/drive/folders/1ieu3TBn2nSP0BaJvJMIhLeLM6kt-x8bX?usp=sharing 🛠️ The Device Tree Patch File I managed to diff the radxa-cubie-5e.dts file and patch it to get it to kind of work with the opi 4a. The patchfile is also in the google drive folder and supplied as an attach here. To include this in your own Armbian build environment, delete any old patches and save this file exactly as: build/userpatches/kernel/archive/sunxi-7.0/zzzz-working-opi4a.patch It wipes out the broken default configurations and replaces them with clean, compiling mainline mappings. You can then build the image using this: ./compile.sh build BOARD=orangepi-4a BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=trixie USERPATCHES_ALLOWED=yes SYSTEM_VERBOSE=yes FORCE_REBUILD=yes 📝 Step-by-Step Instructions to Lock Down the 100M Connection Because the Generic PHY driver cannot process 1Gbps packets correctly, the interface will sit in an unconfigured DOWN loop upon initial boot. Run these steps via your serial terminal loop to bring it online and automate it: Force the hardware down to 100M to clear the packet queue: sudo ethtool -s end0 speed 100 duplex full autoneg off Tell NetworkManager to explicitly negotiate the port: sudo nmcli device connect end0 Make the 100M setting permanent so it survives a reboot: sudo nmcli connection add type ethernet con-name eth-100m ifname end0 802-3-ethernet.auto-negotiate no 802-3-ethernet.speed 100 802-3-ethernet.duplex full ipv4.method auto ipv6.method disabled Automate the green status heartbeat LED: Open /etc/rc.local and add this line right above exit 0 echo heartbeat > /sys/class/leds/green:status/trigger Reboot, and you should have a 100% automated, maintenance-free, fully operational network target - with some tweaking will hopefully get you to the next stage as apt will be working. Hope this helps anyone else struggling to get this community board running on modern releases! zzzz-radxa-to-orangepi4a-fix.patch 0 Quote
bickns Posted July 9 Posted July 9 Just managed to distract myself some more in this outrageous heat here in the UK and can confirm that the RELEASE=stable (6.18) build (from compile.sh) boots ok after some tweaking. It got stuck on "Starting Kernel" but when I added these lines to /boot/armbianEnv.txt to see why it failed, then it booted ok - dunno why. I think keep_bootcon was the important bit. extraargs=earlycon=uart8250,mmio32,0x02500000 keep_bootcon ignore_loglevel loglevel=8 The other problem then was getting the ethernet to work which I did by creating a device tree overlay file - much the same as other here is it only seems be working at 100M unlike the 1000M in the 5.15 kernel. The extra problem seemed to be that the wifi driver would periodically crash and cause a kernel-panic. The following DTS file pulls the ethernet down to 100M and disables the wifi to stop it crashing. You then compile this into a .dtbo file, copy it to /boot/overlay-user and reference it in armbianEnv.txt with this line user_overlays=opi4a-network-fix The opi4a-network-fix.dts syntax to create it is as follows ... apart from that I can't get it to do much more, so will go down the 5.15 bookworm route until things change /dts-v1/; /plugin/; / { compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; /* Maintain working Ethernet at 100M address 1 */ fragment@0 { target-path = "/soc/ethernet@4510000"; __overlay__ { phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; status = "okay"; mdio { #address-cells = <1>; #size-cells = <0>; ext_rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; max-speed = <100>; }; }; }; }; /* Hard disable the unstable wireless MMC controller block */ fragment@1 { target-path = "/soc/mmc@4021000"; __overlay__ { status = "disabled"; }; }; }; 1 Quote
AurealNix Posted yesterday at 02:11 PM Posted yesterday at 02:11 PM (edited) Hi — I've been following this thread, the 100 Mbit ethernet cap and the silent mainline boot hang especially. I ended up doing a full mainline bring-up of the 4A on 6.18.38 and got gigabit ethernet working properly (RX/TX), plus the boot hang sorted, so I wanted to share the whole patch series in case it helps here. Full disclosure: I'm not a kernel developer by trade — I got most of this working with a lot of help from AI coding agents, leaning hard on the BSP 5.15 as the source of truth. In my own testing everything seems stable, but I'd genuinely welcome anyone who actually knows this stuff to review the patches and tell me what I got wrong or did in a hacky way. No egos here — I'm sharing it in case it's useful and to get feedback, not claiming it's perfect. 🙂 What works (confirmed on hardware): HDMI KMS display (DE33/DE3.5 + TCON-TV + DW-HDMI 2.0 + Inno PHY) — 720p/1080p, clean VSU8 scaling GPU Mali-G57 (Panfrost) — accelerated (KDE Plasma Wayland) HDMI audio (i2s2 → dw-hdmi) — PCM out to the TV Ethernet GMAC1 (YT8531 PHY, RGMII) — full gigabit RX/TX WiFi AP6256 (BCM43456, brcmfmac, SDIO) — 2.4/5 GHz scan + assoc reboot / poweroff (sunxi_wdt / AXP717) AFBC scanout (v350 AFBD decoder) USB — the 4 rear ports (all USB 2.0; the board doesn't wire the SoC's USB3) — HID + mass storage, hotplug THS thermal sensors (5 zones: cpu_l / cpu_b / gpu / npu / ddr) + 110 °C critical trip CPU cpufreq/DVFS (little cluster up to 1.416 GHz, big cluster up to 1.8 GHz) + thermal throttling GPU devfreq/DVFS (Panfrost, 150–600 MHz) + thermal throttling HDMI HPD / hotplug (native, no force) Known not working / help wanted: eMMC — not tested (I don't have a module). I saw the mmc2: error -110 reports earlier in the thread; happy to dig into it with anyone who has eMMC. Hardware video decode (VPU) — no driver in 6.18 yet (software decode works). Suspend/hibernate — untested. 4GB variant — expected to work out of the box (the bootloader auto-detects the RAM size and fills in /memory at boot; verified over UART on the 2GB board). I only own the 2GB variant, so if you have the 4GB one, a free -h confirmation would be very welcome. NVMe SSD — untested, no drive here. Everything so far has only run from microSD. Freshness note: the cpufreq/thermal/GPU-devfreq block landed this very week and is still under soak testing on my board — everything else has more mileage. I'll report anything that shakes out in this thread. Repo / patches: https://github.com/ut-slayer/orangepi-4a-mainline It's a git format-patch series (~106 patches) on top of 6.18.38 vanilla, plus a defconfig and the board .dts. The README groups the patches by intended destination: generic sunxi fixes (pinctrl, watchdog vs PSCI, AXP717 poweroff, a RESET_GPIO/mmc-pwrseq bug affecting any sunxi board with SDIO WiFi), the HDMI KMS display series (largely ported/adapted from the minimyth2 / Justin Suess H728 work, with original authorship kept in the patch headers), the A523 CPU CCU + thermal + DVFS, board integration (dts + defconfig), and a few U-Boot BSP workarounds that go away with mainline U-Boot. Coming next: a ready-to-flash Debian 13 (Trixie) image with accelerated Panfrost and KDE Plasma on Wayland — I'll share it in this thread once it's had a bit more soak testing. Happy to open a PR against armbian/build (sun55iw3 family) with the board dts + defconfig + patches if there's interest. Feedback and testers welcome! Credits: minimyth2 / Justin Suess for the H728 display groundwork, and the linux-sunxi community. Cheers. Edited yesterday at 02:16 PM by AurealNix 0 Quote
AurealNix Posted 19 hours ago Posted 19 hours ago Update: the ready-to-flash Debian 13 + KDE Plasma image is now available: https://github.com/ut-slayer/orangepi-4a-mainline/releases/tag/v0.1 Boots straight to an accelerated Plasma desktop. Feedback welcome! 0 Quote
bickns Posted 52 minutes ago Posted 52 minutes ago @AurealNix - great effort and thanks for putting me in touch with Claude 5, I was just using Gemini and it was struggling a fair bit!! In fact I had just put this board on ebay as it was causing too much distraction so your last two posts looked hopeful. Sorry my spanish isn't that great so I'll stick with English. I was hoping to just put these 106 patch files directly into the userpatches/kernel/archive/sunxi-6.18 folder and then run compile.sh with USER_PATCHES=yes, but that didn't work as patch files in that location seem to be tempremental and it couldn't find a lot of the targets. I tried removing the ones with errors which didn't work either, so went down the route of adding running compile.sh with kernel-patch parameter then copying your sun55i-t527-orangepi-4a.dts into ./cache/sources/linux-kernel-worktree/6.18__sunxi64__arm64/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts to get a new patch file, but this failed to compile likely because it doesn't have the changes you made to the .dtsi and other files . It would be good to know how you and Claude were building the kernel - I can see in your README that you are doing it directly into linux 6.18.38 tree, whereas I was working out of a clone of armbian in github. I would like to spend more time on this but need to get onto the real reason I bought the board (an outdoor noise cancelling project) so I'm going to use another board in the meantime. Cheers 0 Quote
