I'm trying to run a DHT22 Temperature & Humidity sensor on my Cubieboard2 but I seem to fail at the beginning on how to use the GPIO Pins correctly :unsure:
What I have:
Cubieboard2
Armbian Linux version 4.11.6-sunxi (root@devel) (gcc version 7.1.1 20170510 (Linaro GCC 7.1-2017.05)
DHT22 (worked on a Raspberry Pi3 before)
What I've done so far:
According to this Overview (http://docs.cubieboard.org/cubieboard1_and_cubieboard2_gpio_pin) I connected the sensor on 3v3, GND and on PD25 (LCDDE). As far as I understood the LCD pins can be also used for other things.
Followed "Accessing the GPIO pins through sysfs with mainline kernel" (http://linux-sunxi.org/GPIO) =>
(position of letter in alphabet - 1) * 32 + pin number
(4 - 1)*32 + 25 = 121
The example says I have to add again +25 to the example "E.g for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter)." => So 121+25 = 146 should be my correct value
Since it's a sensor I guess I've to use "in" as direction.
root@cubieboard2:/sys/class/gpio# echo 146 > /sys/class/gpio/export
root@cubieboard2:/sys/class/gpio# echo "in" > /sys/class/gpio/gpio146/direction
bash: echo: write error: Unknown error 517
Tried it also with the 121 value as the formula mentioned it (no error), expected here another value than 1
root@cubieboard2:/sys/class/gpio# echo 121 > /sys/class/gpio/export
root@cubieboard2:/sys/class/gpio# echo "in" > /sys/class/gpio/gpio121/direction
root@cubieboard2:/sys/class/gpio# cat /sys/class/gpio/gpio121/value
1
Besides this I've seen that there are a lot of posts about attach DHT22 to Orange Pi or to BananaPi. Tried some of those but I'm completly lost to adapt those instructions with 1-wire or wiringpi to the cubieboard2.
I know that on Raspberri Pi it's necessary to load the library for the Adafruit modules which where supported for BeagleBone black & RasPi.
Does someone have some clues how to get this working or tried this by himself?
Thanks in advance.
In this example they add to the result again +18 so adapted to pin PD25:
E.g for PD25 this would be ( 4 - 1) * 32 + 25 = 121 + 25 = 146 (since 'd' is the 4th letter).
Did I missunderstood something at the example?
Anyhow I've tried it without adding the additional +25, result see above.
Thanks so far.
Edit:
Since I'm unsure what exactly is the mentioned Pin for the formular at the Cubieboard2 I've tried it also with using 32 as Pin.
In the GPIO Overview PD25 is located at 32 => (4-1) * 32 + 32 = 128
root@cubieboard2:/home/monkey# echo 128 > /sys/class/gpio/export
root@cubieboard2:/home/monkey# echo "in" > /sys/class/gpio/gpio128/direction
root@cubieboard2:/home/monkey# cat /sys/class/gpio/gpio128/value
0
Nope ! it should be read as :
PD25 this would be ( 4 - 1) * 32 + 25 = 96 + 25 = 121
No, it is not header pin number but GPIO name
Oops, I just went forward through the formular didn't validate the interim result
Thanks for clear the ment GPIO Pin, so I have to use 121
1
If I unplug the sensor I got the following:
0
So it seems that I'm talking with the correct Pin
Next step is how to get correct values of the sensor? :lol:
I tried the following
dht22.py
#!/usr/bin/env python
import Adafruit_DHT
sensor = Adafruit_DHT.DHT22
gpio = gpio121
humidity, temperature = Adafruit_DHT.read_retry(sensor, gpio)
print 'Temperature: {0:0.1f}*C Humidity: {1:0.1f}%'.format(temperature,humidity)
./dht22.py
Traceback (most recent call last):
  File "./dht22.py", line 7, in <module>
    gpio = gpio121
NameError: name 'gpio121' is not defined
gpio121 is the name of the GPIO-Pin to which I want to talk right?
Do I have to import some sort of GPIO map first?
Looking more deeply to the library, I found that it is a bit more complex than I thought to make it run on a A20 board.
Doing a bit more search, I found out something easier :
https://github.com/AiratNig/DHT22-DHT11_Orange-Pi_Python
installed on top of the PyA20 library from :
https://github.com/OLIMEX/OLINUXINO/tree/master/SOFTWARE/Python/pyA20/pyA20
EDIT : I found also that one, again on top of pyA20 : https://github.com/ionutpi/DHT22-Python-library-Orange-PI
CubieBoard2 is based on AllWinner A20 SoC, so it should work, although you maybe need to check/tweak the header pinout accordingly in pyA20/gpio/mapping.h, although the PD25 is already present.
So, simply grab a ZIP snapshot, unzip it, and install it using "cd pyA20-master ; sudo python setup.py install" ...
DHT22-Python-library-Orange-PI/pyA20# ls -l
total 40
drwxr-xr-x 4 root root 4096 Aug 17 00:09 build
-rwxr-xr-x 1 root root  330 Jul 14 15:53 CHANGES.txt
drwxr-xr-x 2 root root 4096 Aug 17 00:09 examples
-rwxr-xr-x 1 root root  283 Jul 14 15:53 __init__.py
-rwxr-xr-x 1 root root  591 Jul 14 15:53 MANIFEST
-rwxr-xr-x 1 root root   40 Jul 14 15:53 MANIFEST.in
drwxr-xr-x 6 root root 4096 Aug 17 00:09 pyA20
-rwxr-xr-x 1 root root 4345 Jul 14 15:53 README.txt
-rwxr-xr-x 1 root root 3038 Jul 14 15:53 setup.py
DHT22-Python-library-Orange-PI/pyA20# python setup.py install
running install
running build
running build_py
running build_ext
Detected processor:  Allwinner sun7i (A20) Family (Probably Allwinner A20)
building 'pyA20.i2c' extension
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c pyA20/i2c/i2c_lib.c -o build/temp.linux-armv7l-2.7/pyA20/i2c/i2c_lib.o
In file included from pyA20/i2c/i2c_lib.c:34:0:
/usr/include/linux/i2c-dev.h:37:8: error: redefinition of ‘struct i2c_msg’
 struct i2c_msg {
In file included from pyA20/i2c/i2c_lib.c:33:0:
/usr/include/linux/i2c.h:68:8: note: originally defined here
 struct i2c_msg {
/usr/include/linux/i2c-dev.h:89:7: error: redefinition of ‘union i2c_smbus_data’
 union i2c_smbus_data {
/usr/include/linux/i2c.h:128:7: note: originally defined here
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
DHT22-Python-library-Orange-PI# ls -l
total 24
-rwxr-xr-x 1 root root  620 Aug 17 00:29 dht22_example.py
-rwxr-xr-x 1 root root 6153 Aug 17 00:22 dht22.py
-rw-r--r-- 1 root root    1 Aug 17 00:13 __init__.py
drwxr-xr-x 5 root root 4096 Aug 17 00:31 pyA20
-rw-r--r-- 1 root root  819 Aug 17 00:13 README.md
DHT22-Python-library-Orange-PI# ./dht22_example.py
  File "./dht22_example.py", line 3, in <module>
    from pyA20.gpio import gpio
  File "DHT22-Python-library-Orange-PI/pyA20/__init__.py", line 5
    import < Something >
SyntaxError: invalid syntax
"""<Some description>
__author__ = "Stefan Mavrodiev"
__copyright__ = "Copyright 2014, Olimex LTD"
__credits__ = ["Stefan Mavrodiev"]
__license__ = "GPL"
__version__ = "2.0"
__maintainer__ = __author__
__email__ = "support@olimex.com"
./dht22_example.py
from pyA20.gpio import port
from pyA20.gpio import connector
#import RPi.GPIO as GPIO
import dht22
import time
import datetime
# initialize GPIO
#gpio.setwarnings(False)
#gpio.setmode(GPIO.BCM)
PIN2 = port.PA6
gpio.init()
#gpio.cleanup()
# read data using pin 14
instance = dht22.DHT22(pin=gpio121)
while True:
    result = instance.read()
    if result.is_valid():
        print("Last valid input: " + str(datetime.datetime.now()))
        print("Temperature: %.2f C" % result.temperature)
        print("Humidity: %.2f %%" % result.humidity)
    time.sleep(1)
What does " < something >" expect?
Well ! you first need to figure out about pyA20 library, don't try the other libraries until you get the fist one done !
On my OLIMEX board (I don't have any Cubieboard ...) both include coming from the same kernel tree, so they should have the same timestamp. If your are not the same timestamp, you have done ugly kernel updates ... Maybe a fresh images could help !
root@micro:~# ll /usr/include/linux/i2c*
-rw-r--r-- 1 root root 2427 Jun 26 16:14 /usr/include/linux/i2c-dev.h
-rw-r--r-- 1 root root 6772 Jun 26 16:14 /usr/include/linux/i2c.h
