I use the OrangePi Zero.  But it is similar to other model.
It's very simple:
1) use the mainline 4.11.x kernel
2) enable the uart1 and pps-gpio in /boot/armbianEnv.txt  like this :
overlays=uart1 pps-gpio
param_pps_pin=PA7
3) edit /etc/default/gpsd  to use ttyS1 as gps device
# Devices gpsd should collect to at boot time.
# They need to be read/writeable, either by user gpsd or the group dialout.
DEVICES="/dev/ttyS1"
# Other options you want to pass to gpsd
GPSD_OPTIONS="-G -n "
4) If you use ntpd,  edit /etc/ntpd.conf like this:
# GPS Serial data reference
server 127.127.28.0 minpoll 4 maxpoll 4 prefer
fudge 127.127.28.0 time1 0.135 refid GPS
server 127.127.22.0 maxpoll 4         # ATOM(PPS)
fudge 127.127.22.0 flag3 1            # enable PPS API
5) Or if you prefer crony rather than ntp, install chrony instead of ntp, edit /etc/chrony/chrony.conf , add this to end of it:
refclock SHM 0 refid GPS precision 1e-1 offset 0.134 delay 0.2 noselect
refclock PPS /dev/pps0 lock GPS
6) connect GPS module to UART1
    GPS      Zero
   TXD        UART1_RX PIN10
   RXD        UART1_TX  PIN8
  PPS          IO-1  PIN12
7)  use ntpq -p  or chrony sources. to check it.
Edited by zador.blood.stained
Moved to the tutorials section
Works on a OPI One too :-)
https://forum.armbian.com/topic/703Q3-solved-orangepi-one-1-pps-ntp-server/
Thanx for the guide
/Bingo
