Baloven Posted January 24 Posted January 24 Hi I have installed an image from the SD - "Armbian_community_25.2.0-trunk.337_Aml-s9xx-box_noble_current_6.6.71.img" installed in EMMC now the question is - how to run WiFi on it? 0 Quote
Tomas Catone Posted April 24 Posted April 24 Take apart your tv box. Take pictures of all the components inside. Looking for your exact part number of your wifi module - mine was AP6330. Then I googled and found this person solved it on their tv box. But the procedure might work for other wifi chipsets. Just have a look in /lib/firmware/brcm and you will see plenty of them. Plus I believe that is the broadcom designs. Going up one level there are even more. WARNING - Not an expert... but this trick worked for me. Good Luck. 1 Quote
