el es Posted January 27, 2025 Posted January 27, 2025 (edited) Hi, I used multitool and installed Armbian_22.05.0-trunk_Xt-q8l-v10_jammy_current_5.15.35_xfce_desktop.img.xz onto a Hanspree AK01 miniPC. It does not boot and drops into a busybox shell: Starting version 249.11.0ubuntu3 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... BEgin: Running scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules: ls /dev) ALERT! UUID=90fc5c5eq-35fd-44dc-97d8-a8d0cbaba4ba does not exist. Dropping to a shell! Busybox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) Buid-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) What should I try now? I also tried pausing the boot in u-boot, and booting a xubuntu 22.04 live USB: U-Boot 2022.04-armbian *Apr 24 2022 16:31:34 +0000) Model: XT-Q8L-V10-RK3288 DRAM: 2GiB Core: 189 devices, 22 classes, devicetree: separate MMC: dvmc0ff0c0000: 1, dvmc0ff0c0000: 0 Loading environment from MMC: *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Model: XT-Q8L-V10-RK3288 Net: eth0: ethernet0ff290000 starting USB... Bus usb00ff5400000: USB DWC2 Bus usb00ff5500000: USB DWC2 Scanning bus usb00ff5400000 for devices... 5 USB device(s) found Scanning bus usb00ff5500000 for devices... 1 USB device(s) found Hit any key to skip autoboot: 0 =>usb storage Device 0: Vendor A1: Rev: Prod: Mass Storage Type: Removble Hard Disk Capacity: 15376.0 15GiB =>usbboot usb 0 Loading from usbdevice 0, partition 1: Name: ISO9660 Type: U-Boot Unknown Image Type How do I fix the ubuntu install fail? Is there something that can be done in busybox? How would I boot from the SD-card, or a USB? Thank you Edited January 27, 2025 by el es 0 Quote
el es Posted February 6, 2025 Author Posted February 6, 2025 (edited) No replies... First error is apparently due to different types of RK3288 which may not be compatible with the image. Post below recommends using a Tinkerboard image. For second error I wonder if it is a problem with whether ISO9660 is supported. Perhaps it needs the .img.xz image rather than .iso. Edited February 6, 2025 by el es 0 Quote
Igor Posted February 6, 2025 Posted February 6, 2025 29 minutes ago, el es said: No replies... Impossible to answer as there are thousands of different devices which single goal is to "sell them, forget about, sell another ...". This project lack millions to be able to have people to support such exotics, so you need to invest your own time into research. Use information about similar devices that exists on this forum and elsewhere. We will try to improve response ratio this way, but on more mainstream targets first - to assemble the team that will search for answers instead of you. No other way - too many devices out there. Make a donation and comment, what those people should do. Or apply for position. 30 minutes ago, el es said: Perhaps Everything you need to know is written here: https://forum.armbian.com/forum/189-faq/ Without this (and similar) projects contributions, this device would be in the trash bin long time ago. Or running horrible outdated original never updated software ... 0 Quote
el es Posted February 6, 2025 Author Posted February 6, 2025 (edited) Quote We will try to improve response ratio this way, but on more mainstream targets first - to assemble the team that will search for answers instead of you. No other way - too many devices out there. Make a donation and comment, what those people should do. Or apply for position. Had been thinking of doing so, as it happens. I'm not sure, can I be useful? I am familiar with Github, but I only have beginner Python/C/SQL so far. Do you need testers? Don't get me wrong - I do appreciate the project, and it is a good one. Thanks for the links to the FAQs. Edited February 6, 2025 by el es 0 Quote
Igor Posted February 6, 2025 Posted February 6, 2025 1 hour ago, el es said: Do you need testers? For every software target: https://docs.armbian.com/User-Guide_Armbian-Software/ And every config option: https://docs.armbian.com/User-Guide_Armbian-Software/ Open ticket https://github.com/armbian/configng/issues and improving documentation on the way. Some is in the config itself https://github.com/armbian/configng/tree/main/tools/include most at https://github.com/armbian/documentation With TV boxes you need luck, its hackers, trial and error world, as there is no docs, very little, usually no people behind each design. 0 Quote
