Idly wondering if the .debs directory could be owned by the user rather than root ...
Recently output and userpatces directories were changed to be group-owned by "sudo" with the sgid bit set, so users should be able to edit/delete anything in them.
Changing owner to the actual user can be done either manually or by adding a special function to userpatches/lib.config, I'm not sure if it is a good idea to fiddle with the ownership at each run by default.
