Constantin Gatej Posted February 4 Posted February 4 Hi I have an HK1 MAX with RK3218 CPU. I tried to install Armbian with multitool. I erased the flash from multitool flashed Armbian and the board won't boot at all It doesn't boot from an sd card and when I press the reset button is not entering mask mode, it is just stuck with the red light on Is 100% dead or is anything I can do? 0 Quote
