After many attempt to installs and remove various version of teamviewer, I finally was able to make it run successfully. I try to use many architecture package even if they were not supposed to work.
The running teamviewer is at the following link. I know it's not supposed to work but it is.
https://download.teamviewer.com/download/linux/teamviewer-host_armhf.deb
Here kind of command that I used randomly (I know, not really scientific approach!)
sudo dpkg --add-architecture amd64
sudo dpkg --add-architecture i386
sudo apt-get install -f
sudo apt-get update
sudo dpkg --remove-architecture amd64
It's really great, but I mess up my network parameters and my bluetooth. I can only use and change them via command line interface. This is not was I need. Everything else is fine. Unfortunately, I can't make a clean install again with teamviewer available. Is there a way to trace back how I can make teamviewer work again? I guess if it can run once, it may be able to run again.
I would be glad if someone is able to help.
EDIT:
I was able to manage the network problem so only my bluetooth isn't working properly.
I still would like to know how can I trace back the teamviewer install.
On a new and fresh install of armbian, Teamviewer launch and I see the interface, but I'm unable to have a Client ID. I believe this related to the teamviewer daemon since the command "teamviewer daemon status" do not output the same.
I am trying to get Teamviewer or any similar software to work on my Pine64.
From the instructions I am not fully able to install Teamviewer, can you dumb it down any further.
