Posted (edited)
So first I want to change my Armbian STB IP settings to Static with the command
source /etc/network/interfaces.d/*
#Network is managed by Network manager
#auto lo
#iface lo inet loopback
auto eth0
iface eth0 inet static
             address 10.10.10.10
             subnetmask 255.255.255.0
             gateway 10.10.10.1
             broadcast 10.10.10.255
             hwaddess ether MAC Address
and i save the setting when i reboot the config i cant access the IP address in SSH nor CasaOS Web UI. i need help
Edited by Muhammad Satria
Hi!
You should use netmask 255.255.255.0 instead of subnetmask.  If NetworkManager is managing your interfaces, it might override manual settings. Try disabling it or configuring the static IP within nmcli.
Let me know if you need more help!
Thanks, Eloi.
