Murat Demirtas Posted March 17, 2025 Posted March 17, 2025 (edited) Hello, previously, after creating a patch file, (v24.11) I used to save it in the userpatches directory as zzzz_xxxx_whatever.patch to ensure it was processed at the bottom of the current patch list. But now, it seems that this no longer works, and therefore, I cannot apply the patch.zzzz_panel_mipi_dsi.patch thank you. here is the log file: https://paste.armbian.com/horamafuru Edit: tested with(trunk.239) latest armbian build( https://github.com/armbian/build/tree/v25.5.0-trunk.239 with zzz-patch-test.patch here is the log file: https://paste.armbian.eu/joyalusado zzzz_panel_mipi_dsi.patch Edited March 18, 2025 by Murat Demirtas 0 Quote
Solution IBV Posted March 18, 2025 Solution Posted March 18, 2025 Hi, your patch fails because the file rk3399-orangepi-4-lts.dts does not exist in the mainline kernel(s) you tried to build. Maybe previously you appplied it against the vendor kernel? 1 Quote
Murat Demirtas Posted March 18, 2025 Author Posted March 18, 2025 (edited) Hello, thank you for reply. I'm using build system v24.11 and latest, kernel version v6.6 and v6.12. Created fresh installation and trying to create patches with command ./compile.sh kernel-patch BOARD=orangepi4-lts BRANCH=current KERNEL_GIT=shallow ARTIFACT_IGNORE_CACHE=yes and that file exist in /home/oem/Desktop/ananki/build/cache/sources/linux-kernel-worktree/6.12__rockchip64__arm64/arch/arm64/boot/dts/rockchip You are right, because the series of patch files in build system creates this file. I patched non existent file but created with a older patches . Edited March 18, 2025 by Murat Demirtas 0 Quote
Murat Demirtas Posted March 18, 2025 Author Posted March 18, 2025 In latest build system, the board configuration file https://github.com/armbian/build/blob/main/config/boards/orangepi4-lts.conf using fdt file as BOOTCONFIG="orangepi-rk3399_defconfig" BOOT_FDT_FILE="rockchip/rk3399-orangepi-4-lts.dtb" how can i patch that file?. Because this file is not existing in mainline kernel, and creating with patches. interesting. 0 Quote
IBV Posted March 18, 2025 Posted March 18, 2025 22 minutes ago, Murat Demirtas said: You are right, because the series of patch files in build system creates this file. I patched non existent file but created with a older patches Indeed you are trying to patch a file that is created by an armbian patch. I suppose you can overwrite the armbian patch that creates the rk3399-orangepi-4-lts.dts with a patch that creates the dts with your modifications. 1 Quote
Murat Demirtas Posted March 18, 2025 Author Posted March 18, 2025 Should i edit the python scripts that creates that patches? or is there another way with build system? 0 Quote
IBV Posted March 18, 2025 Posted March 18, 2025 For the dts, I would take the patch/kernel/archive/rockchip64-6.12/dt/rk3399-orangepi-4-lts.dts , modify it according to your needs and put it in the user patches directory (using the recommended way to replace a patch). 1 Quote
going Posted March 18, 2025 Posted March 18, 2025 3 часа назад, Murat Demirtas сказал: Should i edit the python scripts that creates that patches? or is there another way with build system? To do this, you will need to open two sessions in the terminal. The test here is my configuration file 1 session ~/armbian$ ./compile.sh test kernel-patch ...... # build system printed: [✨] Starting [ interactive patching process for kernel ] [🌱] Creating commit to start from clean source [🌱] Patches will be created [ with the following maintainer information ] [🌱] MAINTAINER (Real name): [ The-going ] [🌱] MAINTAINERMAIL (Email): [ 48602507+The-going@users.noreply.github.com ] [🌿] If those are not correct, set them in your environment, command line, or config file and restart the process [🚸] Make your changes in this directory: [ /home/leo/armbian/cache/sources/linux-kernel-worktree/6.13__sunxi64__arm64 ] [🚸] Press <ENTER> after you are done [ editing files in /home/leo/armbian/cache/sources/linux-kernel-worktree/6.13__sunxi64__arm64 ] Press ENTER to show a preview of your patch, or type 'stop' to stop patching... The build system will apply all the patches and make a commit that will include all the changes. Leave this session alone. In the second session, you make your changes and record the results. 2 session leo@armbuild:~/armbian$ cd /home/leo/armbian/cache/sources/linux-kernel-worktree/6.13__sunxi64__arm64 ### open root session leo@armbuild:~/armbian/cache/sources/linux-kernel-worktree/6.13__sunxi64__arm64$ sudo su root@armbuild:/home/leo/armbian/cache/sources/linux-kernel-worktree/6.13__sunxi64__arm64# ls arch/arm64/boot/dts/rockchip/rk3399-* linux-kernel-worktree/6.13__sunxi64__arm64# nano arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts linux-kernel-worktree/6.13__sunxi64__arm64# git add --all linux-kernel-worktree/6.13__sunxi64__arm64# git commit -m "Add a comment" ###close root session: linux-kernel-worktree/6.13__sunxi64__arm64# exit linux-kernel-worktree/6.13__sunxi64__arm64$ git format-patch -1 -o /home/leo/armbian/userpatches/ /home/leo/armbian/userpatches/0001-Add-a-comment.patch linux-kernel-worktree/6.13__sunxi64__arm64$ cat /home/leo/armbian/userpatches/0001-Add-a-comment.patch From 4dad6a3fa967235ea7eef35f81733bdafd806b53 Mon Sep 17 00:00:00 2001 From: The-going <48602507+The-going@users.noreply.github.com> Date: Tue, 18 Mar 2025 12:54:11 +0000 Subject: [PATCH] Add a comment --- arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts | 1 + 1 file changed, 1 insertion(+) diff --git a/arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts b/arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts index 2ddd4da15..29eec7e65 100644 --- a/arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts +++ b/arch/arm64/boot/dts/rockchip/rk3399-orangepi.dts @@ -78,6 +78,7 @@ keys: gpio-keys { compatible = "gpio-keys"; autorepeat; + /* key-power */ key-power { debounce-interval = <100>; gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; -- 2.34.1 What should I do with the first session? Decide for yourself!! 1 Quote
Murat Demirtas Posted March 19, 2025 Author Posted March 19, 2025 thank you very much guys, both two method is works. i successfully patched. 1 Quote
