sailorbg Posted March 27, 2025 Posted March 27, 2025 I've installed and run a/m OS. BUT i have a problem with MAK address changing at every reboot. How to avoid that ? Is it possible to install the OS on the emmc instead of SD card? 0 Quote
eselarm Posted March 27, 2025 Posted March 27, 2025 It all depends on that specific SBC and lowlevel init code. I don't know your board and maybe you changed U-Boot. But a high-level mitgation is to makes sure you set a MAC address in a NetworkManager connection file, see /etc/NetworkManager/system-connections Quote [ethernet] cloned-mac-address=xx:xx:xx:xx:xx:xx 0 Quote
SteeMan Posted March 27, 2025 Posted March 27, 2025 2 hours ago, sailorbg said: s it possible to install the OS on the emmc instead of SD card? From the Installation Instructions post ( https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus) "Note: It is not possible to install into emmc on boxes with the s905 cpu" 0 Quote
sailorbg Posted March 28, 2025 Author Posted March 28, 2025 In Quote "Note: It is not possible to install into emmc on boxes with the s905 cpu" In that case is there any instructions how to move ROOT fs to the external USB attached HDD? As far as I understood that running from the SD card is not a good. 0 Quote
SteeMan Posted March 28, 2025 Posted March 28, 2025 4 hours ago, sailorbg said: In that case is there any instructions how to move ROOT fs to the external USB attached HDD? As far as I understood that running from the SD card is not a good. I'd recommend looking at the script /root/install-aml.sh. This is the script that would copy from SD to emmc (if that was supported with your CPU). It is a pretty simple script and you can see the logic it uses to copy the root partition to another medium. 0 Quote
