XU4 next + nand-sata-install + USB disk --> rootfs not found
I'm struggling with XU4/HC1 and the try to have the rootfs on a connected USB disk. All attempts end up with:
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/sda1 does not exist.  Dropping to a shell!
Rebooting automatically due to panic= boot argument
I tried USB disks on USB3 and USB2 ports, according to leds and spin-up sound the SSDs/HDDs get power but device doesn't show up. I remember vaguely that we had such issues on other platforms where it was just a small missing bit in kernel config. But I don't get it even after spending an hour on searching around.
2 times boot log with high verbosity, maybe someone else has a clue: https://pastebin.com/ffnQK2Pm
I beleve it was CONFIG_CHR_DEV_SG, and it is set to built-in on xu4-next. And even if it was a module it would be loaded from initrd.
You can try investigating it further by replacing "panic=10" with "break=premount" in the build script kernel command line, it should give you a minimal shell.
5 minutes ago, zador.blood.stained said:
somewhere it tried to use BTRFS mount options
Yes, that's due to
mount -o compress-force=zlib $2 ${TempDir}/rootfs || mount $2 ${TempDir}/rootfs
On 7.9.2017 at 6:51 PM, zador.blood.stained said:
Just tested XU4 next, install to USB drive (new board support package but an older boot script) and it worked fine for me.
Sorry for the late feedback. In the meantime I tested a new build with latest bootscript and it didn't boot at all. Was too lazy to connect serial console (since running a test on HC1 in parallel where the adapter was connected to) and thought 'Seems Zador is preparing whole switch to armbianEnv.txt so let's wait for this happen'. But now I wonder whether you're still preparing stuff or not?
Didn't boot before nand-sata-install or after?
Currently a bit busy, but since I bought a bunch of fresh SD cards for tests several days ago at least I won't be having a problem with finding a good card for the test.
Before. And highly frustrated that day since wasted hours already due to stupid mistakes I made and some unfortunate decisions (build host related). Boot failure --> putting XU and HC1 in the drawer waiting for you finalizing armbianEnv.txt vs. boot.ini stuff.
Only positive result from this day back then was the finding that symlinking cache/sources and cache/toolchains from a btrfs force-compression=zlib partition doesn't hurt performance wise (while savong over 100% needed storage)
Unfortunately currently there is a "hack" for all boot.ini based configurations that deletes armbianEnv.txt, and we can either getting rid of it all together (requires tests on Odroid C1/C0 boards which use a very old u-boot) or introducing more hacks on top of existing ones.
Well, I would prefer the least hackish attempt but fear I can't help much since I've no serial cable for my C1+ / C2 (as I understood the serial cable for XU4/HC1 is not compatible to the other boards since 1.8V vs. 3.3V)?
The wiki suggests that it's compatible (it has a 4th wire for voltage reference)
_____UART____
|Pin 4 - GND|
|Pin 3 - RXD|
|Pin 2 - TXD|
|Pin 1 - VCC|
\___________|
1.8V LVTTL for ODROID-U3/XU3/XU4/X2/X
3.3V LVTTL for ODROID-C1/C1+/C0/C2/W
RxD pin is input and TxD pin is output.
The VCC pin is not a power source but a reference voltage input.
It is used for detecting the IO voltage like a VIO or a VDDIO.
Support for I/O interface voltages down to 1.8 V is provided via a VIO pin.
Ok, will try this out soon! Thank you.
Maybe this has something to do with it
Processing file /home/zador/armbian/patch/u-boot/u-boot-odroidxu4-next/cfgload-support-ext4.patch
1 out of 2 hunks FAILED -- saving rejects to file cmd/cfgload.c.rej
I'll update the patch and push the fixes a bit later.
2 hours ago, zador.blood.stained said:
3 attempts with freshly built images, the first two with btrfs (no boot but panic), now with ext4 I've no network. And a f*cked up screen setup so serial console logs are trashed too. Will look into it tomorrow. And thanks for the diagnose/fix!
