kwell Posted September 12, 2017 Share Posted September 12, 2017 i cannot figure out how to get sound working, what i am coming up with is its not in the kernel i have? Thank you in advance. Link to comment Share on other sites More sharing options...
guidol Posted September 15, 2017 Share Posted September 15, 2017 If you decide to use the expermental MAINLINE kernel 4.x , then its possible that it hasnt sound-drivers If you want to use sound by now please use the Server-Image with the legacy Kernel 3.x On my Opi Zero with legacy kernel audio is useable and alsa-base and alsa-utils (incl. alsamixer) is installed: ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.31 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i System load: 0.12 0.06 0.05 Up time: 7 days Memory usage: 8 % of 494MB IP: 192.168.x.x CPU temp: 75°C Usage of /: 12% of 15G [ 0 security updates available, 1 updates total: apt upgrade ] Last check: 2017-09-15 00:00 [ General system configuration: armbian-config ] Last login: Fri Sep 15 16:07:08 2017 from 192.168.x.x root@orangepizero:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: audiocodec [audiocodec], device 0: SUNXI-CODEC sndcodec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 root@orangepizero:~# Link to comment Share on other sites More sharing options...
geotravel Posted September 16, 2017 Share Posted September 16, 2017 Hi I have use Armbian5.31 z mainline kernel 4.11.5 https://dl.armbian.com/orangepizero/Debian_jessie_dev.7z and I have seen internal sound card / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.11.5-sun8i System load: 0.05 0.03 0.00 Up time: 11:13 hours Memory usage: 13 % of 496MB IP: 172.16.1.155 CPU temp: 43°C Usage of /: 20% of 7.2G [ 0 security updates available, 1 updates total: apt upgrade ] Last check: 2017-09-16 08:21 [ General system configuration: armbian-config ] Last login: Sat Sep 16 15:02:36 2017 from 172.16.1.2 root@EchoLink:~# cat /proc/asound/cards 0 [Codec ]: H3_Audio_Codec - H3 Audio Codec H3 Audio Codec 1 [Loopback ]: Loopback - Loopback Loopback 1 ## aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 .... Link to comment Share on other sites More sharing options...
geotravel Posted September 16, 2017 Share Posted September 16, 2017 I forgot to add that if use Armbian with kernel 4.11.5 you must add i /boot/armbianEnv.txt line overlays=analog-codec and reboot Orange PI Zero Link to comment Share on other sites More sharing options...
Alexandre Prates Dias Posted October 27, 2017 Share Posted October 27, 2017 Thanks @geotravel, adding this line to armbianEnv.txt fixed the audio for me on 5.34 stable Debian GNU/Linux 8 (jessie) 4.13.8-sunxi Link to comment Share on other sites More sharing options...
