11 minutes ago, gdm85 said:
@@lex I refuse to answer your posts if you do not read what I write. Thanks for your help, I will take the issue with other users/developers.
IMO this is the best way when you want to avoid help from others. Guess how motivated others are if you refuse the help which is provided.  Otherwise you might consider this idea:
On 20.9.2017 at 9:58 AM, tkaiser said:
Only alternative: waiting.
If you have a SBC which isn't that popular based on a SoC for which Armbian doesn't provide stable images (yet).  IMO, you should pick up all the help you can to solve your issues.  :)
Btw.:
Do we might have a conflict with the g_serial module? According to schematics, the data lines aren't attached to the microUSB so it doesn't make sense to have g_serial activated.
