Diego Dagum Posted May 21, 2025 Posted May 21, 2025 I'm on the most recent Armbian 25.2.3 Noble version. When I try the command $ yes | sudo apt dist-upgrade I get the following error: Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Get more security updates through Ubuntu Pro with 'esm-apps' enabled: ... Learn more about Ubuntu Pro at https://ubuntu.com/pro The following upgrades have been deferred due to phasing: gnome-shell gnome-shell-common ubuntu-drivers-common The following packages will be upgraded: thunderbird 1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. Need to get 68.6 MB of archives. After this operation, 453 kB of additional disk space will be used. Get:1 http://apt.armbian.com noble/noble-desktop arm64 thunderbird arm64 9:128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1 [68.6 MB] Err:1 http://apt.armbian.com noble/noble-desktop arm64 thunderbird arm64 9:128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1 File has unexpected size (68620562 != 68620660). Mirror sync in progress? [IP: 2a01:4f9:3b:4943::2 80] Hashes of expected file: - SHA512:e49ee18c96333c4dfbb188458a3fb8ce271874d1aaf830ce4aed2ff5b3f59220cc4ead01243323047a6d7ef7258b6f2f66f5d231ea83dfc53356e4d9aeeef0d6 - SHA256:581efd7ac140c5c416648efad6fcea96ed4cccc9db6e8300b6200860399d9f5c - SHA1:de05de93f62cf5b298bddbdc65fcb95fe0c4062e [weak] - MD5Sum:91c1809c8ca059ebdfb71787b02f3b4b [weak] - Filesize:68620660 [weak] E: Failed to fetch http://fi.mirror.armbian.de/apt/pool/noble-desktop/t/thunderbird/thunderbird_128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1_arm64.deb File has unexpected size (68620562 != 68620660). Mirror sync in progress? [IP: 2a01:4f9:3b:4943::2 80] Hashes of expected file: - SHA512:e49ee18c96333c4dfbb188458a3fb8ce271874d1aaf830ce4aed2ff5b3f59220cc4ead01243323047a6d7ef7258b6f2f66f5d231ea83dfc53356e4d9aeeef0d6 - SHA256:581efd7ac140c5c416648efad6fcea96ed4cccc9db6e8300b6200860399d9f5c - SHA1:de05de93f62cf5b298bddbdc65fcb95fe0c4062e [weak] - MD5Sum:91c1809c8ca059ebdfb71787b02f3b4b [weak] - Filesize:68620660 [weak] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? It seems like some checksum or some other validation data doesn't match the actual data. Thanks for any guidance on this matter. 0 Quote
Werner Posted May 22, 2025 Posted May 22, 2025 4 hours ago, Diego Dagum said: Mirror sync in progress? Tried a few hours later? Alternativly you can choose a fixed mirror from here: https://docs.armbian.com/Mirrors/ 0 Quote
laibsch Posted May 23, 2025 Posted May 23, 2025 @Diego Dagum are you using an apt caching mirror like apt-cacher-ng? 0 Quote
