Pinebook, Armbian Installed: Suspend on Lid Close?
i'm trying to make suspend on lid close work.
i saw in this thread that some people are aware that there's a problem.
i'd prefer to achieve this from within xfce4-power-manager.
here's the thing:
1. using the normal xfce desktop
     * for "when laptop lid is closed", only 'lock screen' and 'switch off diplay' are available
     * "System sleep mode" is completely grayed out, as well as security 'lock screen when system is going to sleep'
     * the 'Ask' option is available only for "Buttons". Choosing it, then choosing "Suspend" from the dialog, causes the ui to hang (desktop darkened), but after a minute i can 'escape' out of it.
     * 'systemctl suspend' suspends as expected (without locking the screen)
2. using plain openbox without display manager (i.e. console login & startx instead of nodm) or desktop environment, xfce4-power-manager autostarted
     * for "when laptop lid is closed", 'lock screen', 'switch off diplay', 'suspend' and 'hibernate' are available, but only the first 2 work
     * "System sleep mode" gives me a choice between 'suspend' and 'hibernate' - only suspend works (!) as expected.
     * security 'lock screen when system is going to sleep' is not greyed out, and un/checking it works as advertised
     * the 'Ask' option is available only for "Buttons". It does nothing.
in other words, choice nr. 2. works in all aspects except the lid switch!
i tried to let systemd handle the lid switch - to no avail.
i also tried to not use xfce4-power-manager at all, only systemd - to no avail.
reading `man logind.conf` i notice this:
  HandleLidSwitch=..... Only input devices with the "power-switch" udev tag will be watched for key/lid switch events.
Interesting...
'udevadm monitor' showed nothing for opening/closing the lid.
dmesg showed this:
    hall: (D) hall_isr
    hall: (I) HALL_CLOSE
    hall: (D) hall_isr
    hall: (I) HALL_OPEN
every time i open/close the lid...
so, where exactly would i have to add this "power-switch" udev tag?
phew, my head swims...
any ideas? maybe a secret solution already exists?
Works fine for me using an armbian build with mate installed on top. I didn't have to do anything to make it work. One thing that does catch me out is the machine powers up when you plug the dc in. I have to try and remember not just plug the connector in with the machine closed and suspended and wander off to bed.
11 hours ago, dahni said:
interesting.
does it use "mate-power-manager"?
what does 'systemd-inhibit' say?
mate-power-manager is running, so I guess so.
systemd-inhibit seems to confirm that:
    What: handle-power-key:handle-suspend-key:handle-lid-switch
     Why: Mate power manager handles these events
    Mode: block
mate-power-manager indeed works better in this respect.
i had to manually add screen locking via systemd though (not sure if installing mate-screensaver would have fixed that too).
one thing that doesn't work is automatic 'sleep' after a given amount of inactivity.
right now, it does nothing (just blanks the screen) unless i trigger the suspend with one of 3 configured methods (lid, power button, sleep button).
xfce4-power-manager let me define a "Sleep Action" - maybe there's something similar going on here, but no GUI dialog to set it?
