Hello i have an Tanix tx3 mini,with s905w processor.
After a boot fail i can restore armbian, and i must to flash again android, and the box Is work again.
Now i can't flash armbian because the box don't boot from microSD,
any help?
Edited by tasknodes
  • tasknodes changed the title to Tanix TX3 mini unable to boot from Memory card
What build of armbian are you using?  Please provide the exact steps you are having problems with, your description of the problem is not clear.
@tasknodes as SteeMan requested, you should provide details and steps of how you installed Armbian. also provide details of what caused a boot failure and details of what error messages or logs that you saw on your tv/monitor.
I hope this helps... For the TX3 Mini, I used the distributions listed on https://www.armbian.com/amlogic-s9xx-tv-box/. Here's what I did:
* Create a bootable image using Rufus (following the instructions).
* Once the image was created, I went to the SD card's storage drive on a PC and made the following changes:
* In the root directory of the SD card, I copied the file u-boot-s905x-s912 and pasted it as u-boot.ext.
* In extlinux\extlinux.conf, on line 4, I changed it to "fdt /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb".
* I ejected the SD card, inserted it into the TX3 Mini, and turned it on.
If it doesn't work, try a different distribution.
