v25.8 rolling for radxa cubie a5e 6.14.0-rc1-dev-sun55iw3: sed: -e expression #1, char 0: no previous regular expression
Go to solution Solved by laibsch,
Don't know where to report this as Armbian bug reporting form refused to accept community supported board, but it may not necessarily be board-specific.
When logging the first time there is a message: sed: -e expression #1, char 0: no previous regular expression
Generating locales: en_US.UTF-8
    _             _    _                                         _ _
   /_\  _ _ _ __ | |__(_)__ _ _ _    __ ___ _ __  _ __ _  _ _ _ (_) |_ _  _
  / _ \| '_| '  \| '_ \ / _` | ' \  / _/ _ \ '  \| '  \ || | ' \| |  _| || |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, |
                                 |___|                                 |__/
 v25.8 rolling for radxa cubie a5e running Armbian Linux 6.14.0-rc1-dev-sun55iw3
 Packages:     Debian stable (bookworm)
 Updates:      Kernel upgrade enabled and 2 packages available for upgrade
 Support:      for advanced users (rolling release)
 Performance:
 Load:         6%                Uptime:       17 min
 Memory usage: 7% of 1.93G
 CPU temp:     54°C                Usage of /:   15% of 6.7G
 Commands:
 Configuration : armbian-config
 Upgrade       : armbian-upgrade
 Monitoring    : htop
The second login does not show this message.
Hope this helps
  • Solution
Thank you for the report and this indeed does look like a general bug.  It appears as if this comes from the file 10-armbian-header and in particular line 199 or possibly line 214, but I cannot look into it further right now.  It's probably got something to do with network not being configured at the point at which you encountered this.
I do certainly encourage you to open a ticket on github with the first entry on the pulldown "bug report for the armbian build framework".
