Radxa Cubie A5E - NVMe support?
Go to solution Solved by Richard Klingler,
Hi,
is there currently support for NVMe storage in Armbian trunk?
I tried to flash the latest build, added nvme ssd storage - but it is not seen in the system.
What to check?
  • Solution
Posted (edited)
Nope..though nvme kernel modules are present in the file system but doing nothing when loading, not even a dmesg output.
Besides...u-boot version from the SD image has also no NVMe support...
Edited by Richard Klingler
Just flashed an u-bbot version from here which does support NVMe...well at least it recognizes the SSD (o;
https://github.com/cubie-image/sun55iw3p1/releases
=> pci enum
Speed change timeout
PCIe speed of Gen1
=> nvme scan
feng >>>> debug <<<<< nvme_probe
=> nvme device
IDE device 0: Vendor: 0x1dee Rev: 1.4.7.70 Prod: 2510194702629
            Type: Hard Disk
            Capacity: 488386.3 MB = 476.9 GB (1000215216 x 512)
It is documented there:
Zitat
"The SPI NOR image must be written to mtdblock0 after booting from SD card"
So when booted from SD you need to copy over the u-boot image to SD card and do from there:
dd if=cubie_a5e_spi_nor_raw_050624.img of=/dev/mtdblock0
But that won't you get NVMe support on Armbian as Cubie A5E NVMe support just isn't in the kernel, not even the dev version.
