robertM Posted July 20, 2025 Posted July 20, 2025 I am Running Armbian 24.5.1 Jammy with Linux 6.1.115-vendor-rk35xx on Radxa Rock5b (and it works great!!) when running sudo apt dist-upgrade or sudo apt upgrade I get Die folgenden Pakete sind zurückgehalten worden: armbian-bsp-cli-rock-5b " Packages retained" apt list --installed | grep armbian-bsp-cli-rock-5b gives: armbian-bsp-cli-rock-5b-legacy/jammy,now 24.5.1 arm64 [installiert] armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1] ## installed, can be updated can/shall I force the the use of "armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1]" ? how? what is the correct procedure to update to 25.5.x? thanks 0 Quote
laibsch Posted July 21, 2025 Posted July 21, 2025 please provide the output of "apt policy armbian-bsp-cli-rock-5b" and "sudo cat /etc/apt/preferences.d/*" 0 Quote
robertM Posted July 22, 2025 Author Posted July 22, 2025 I was able to get the conflicting versions fixed: Zitat sudo apt remove armbian-bsp-cli-rock-5b armbian-bsp-cli-rock-5b-legacy now: Zitat apt policy armbian-bsp-cli-rock-5b armbian-bsp-cli-rock-5b: Installiert: (keine) Installationskandidat: 25.5.1 Versionstabelle: 25.5.1 500 500 http://apt.armbian.com jammy/main arm64 Packages 25.2.3 500 500 http://apt.armbian.com jammy/main arm64 Packages 25.2.2 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.11.3 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.11.1 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.8.4 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.8.3 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.8.2 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.5.1 500 500 http://apt.armbian.com jammy/main arm64 Packages 24.2.1 500 500 http://apt.armbian.com jammy/main arm64 Packages Zitat sudo cat /etc/apt/preferences.d/* cat: '/etc/apt/preferences.d/*': No such file or directory 0 Quote
robertM Posted July 24, 2025 Author Posted July 24, 2025 well I "solved" the package conflict but now on boot it shows: Welcome to 22.11.2 with Linux 6.1.115-vendor-rk35xx before it showed: Welcome to Armbian 24.5.1 Jammy everything works though - no pending updates. I guess I will leave it like this. Or any recommendations about getting it up to current version? 0 Quote
SteeMan Posted July 24, 2025 Posted July 24, 2025 You are most likely fine. But out of curiosity can you run the following: apt list --installed | grep armbian 0 Quote
robertM Posted August 4, 2025 Author Posted August 4, 2025 sorry for late reply. here is the output - thx armbian-config/unbekannt,unbekannt,jammy,jammy,jammy,now 25.8.0-trunk.380.0718.155006 all [installiert] armbian-firmware/jammy,jammy,jammy,now 25.5.2 all [installiert] armbian-plymouth-theme/jammy,jammy,jammy,now 25.5.2 all [installiert] armbian-zsh/jammy,jammy,jammy,now 25.5.2 all [installiert] chromium/jammy,now 9:126.0.6478.182-1~deb12u1+j1armbian1 arm64 [installiert] 0 Quote
SteeMan Posted August 4, 2025 Posted August 4, 2025 @robertM You really should have an armbian-bsp-* package installed for your appropriate box as well. If I reread your previous posts that should be: armbian-bsp-cli-rock-5b So I would suggest running: sudo apt install armbian-bsp-cli-rock-5b That should clean up your login info to be up to date and you will then pick up future changes as well. 0 Quote
robertM Posted August 4, 2025 Author Posted August 4, 2025 awesome: login screen now -> thx!! Zitat v25.5.1 for Rock 5B running Armbian Linux 6.1.115-vendor-rk35xx Packages: Ubuntu rolling (jammy), possible distro upgrade (noble) 0 Quote
